Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 03-22-2012, 10:20 PM   #51
Jessekrs123
Member#: 236927
2015 BRZ 93 LEGacy33
1984 BRAT
Originally Posted by dirtcrazy View Post
Haven't seen an EG33 in pieces like that. Looks like Subaru added the cylinders to the front. Interesting....they did the same thing in the ER27 too.
Yeap, just like the ER27 was essentially an EA82 with an extra pair of pistons, the EG33 is essentially an EJ22 with an extra pair of pistons.
Originally Posted by Gr3en View Post
Subscribed. This is going pretty well.
Thanks
Jessekrs123 is offline   Reply With Quote
Old 03-26-2012, 01:43 PM   #52
bigd003
Member#: 233285
2008 Forester
Great work so far, very nice harness work too. Did you save all the PN's for the gaskets and seals etc? If so, please post them for reference- sitting on the phone with parts department forever sux.
bigd003 is offline   Reply With Quote
Old 03-26-2012, 01:55 PM   #53
vipers
Member#: 298020
2002 RS-TI
Whitey
very well done so far! subscribed
vipers is offline   Reply With Quote
Old 03-26-2012, 03:23 PM   #54
Jessekrs123
Member#: 236927
1984 BRAT
I just ordered an entire re-seal kit which is one part number. If you need it let me know.
PN - 10105AA060 - for the entire engine gasket kit. Few things like some valvetrain components missing, but everything else is pretty much accounted for.
Thanks!
Removed the valves and their components today.
Cleaned up one head.
Ran out of time to clean the other head though, I'll get around to it when I have some spare time.
After I clean off the heads, intake ports, exhaust ports and what have you, the heads will be resurfaced and heat bathed.
I will be re-lapping the valves and replacing the oil seals as well once I get everything cleaned up.
So far everything looks really good. Heads are very straight for what they are, and the valve seats are very clean with no notches or anything, smooth as butter.
I am very happy with how well everything looks, now time to make it look even better.
Old 04-01-2012, 05:33 PM   #55
Jessekrs123
Member#: 236927
1984 BRAT
Got a chance to lap up all the valve seats.
Old 04-21-2012, 11:27 PM   #56
ClassicPurcell
Member#: 299709
1999 Toyota Camry
Subbed!
Got any recent updates about it?
ClassicPurcell is offline   Reply With Quote
Old 04-21-2012, 11:46 PM   #57
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
This is awesome. That is all.
T Wrex--OH is offline   Reply With Quote
Old 05-01-2012, 11:24 AM   #58
Jessekrs123
Member#: 236927
1984 BRAT
No updates recently. It is almost the end of the semester so I have to muscle through crunch time, and a lot of people at work have been going on vacation so I've been having to cover a lot at work.
I did get myself a dremel kit which is pretty nice, I cleaned up some of the engine components like fuel stacks and intake manifold with it. I need a gouging tool for the dremel so I can gasket match some things like the fuel stacks, intake ports and the throttle body can be shaved a little.
More recent updates in the next coming months once full time school is done and I'll have a lot more free time on my hands.
Old 05-17-2012, 03:29 PM   #59
Jessekrs123
Member#: 236927
1984 BRAT
Pulled all the valve oil seals off today. The engine seal kit came with new ones so might as well replace all of those while I have everything apart.
Old 06-02-2012, 02:51 PM   #60
Jessekrs123
Member#: 236927
1984 BRAT
My Whiteline ball joints and tie rod ends came in today.
These will be going in once I take the Legacy apart for the new motor, passenger's side ball joint is shot and clunking so it needs replacing.
Got my gouger tool for the dremel, but it is too big to fit into my dremel so I'll have to shave it down on a lathe when I get the chance.
That is all for now...
Old 06-12-2012, 05:43 PM   #61
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Updates pls!
Gr3en is offline   Reply With Quote
Old 06-16-2012, 10:26 PM   #62
Jessekrs123
Member#: 236927
1984 BRAT
Replaced the ball joints and tie rod ends today. Boy that was a ton of fun
Just have to get everything aligned now and the Legacy will be taking the backseat for a while, just got the BRAT registered so I've been tearing up the streets and waking up any house within a 5 mile radius of the car.
Old 07-13-2012, 12:45 PM   #63
Jessekrs123
Member#: 236927
1984 BRAT
I've been looking for a nice flat red to paint various engine parts with, and that has proven to be quite difficult. I've been through about 4 different reds and I finally decided to settle with this VHT Flat Red stuff, which is near impossible to find. I wanted to do wrinkle red, but I don't want to have to use my oven to cure the pain, my mother would ring my neck...
Been using my coolant crossover as a "test" part for all the colors. This will be the fourth type of red it has seen (all the other reds were too glossy) and I am going to stick with this color.
I plan on painting the intake manifold, throttle bodies, valve covers, and fuel stacks this flat red.
Various brackets and fuel rails/lines will be painted black.
Since I will be painting a lot of stuff while I have everything apart, I have been prepping the living snot out of everything I plan on painting. Piss poor prep produces piss poor performance, especially with painting, so I've been wire brushing, cleaning, using a small wire wheel with the dremel to get every particle of dirt off of everything. Didn't feel like taking a picture of everything prepped so far, but right now I'm cleaning off my fuel rails and lines.
Valve covers and throttle bodies have been prepped, now I just need to prep the intake manifold which should take a generous amount of time because it is rather big. I also need to buy more paint, I'd hate to run out halfway through laying down coats...
The heads are being shaved right now as I type this, so once I get them back, I will be re-assembling the heads, throwing them on the block and I should pick up a lot of momentum with this swap at that point.
Old 07-14-2012, 03:07 PM   #64
Jessekrs123
Member#: 236927
1984 BRAT
Got my fuel rails all nice and painted today!
As previously stated, brackets and fuel rails will be painted black. I chose caliper paint black with the ceramic coating to give it that "rough" look. I think it looks really good. If you can't tell, I'm not really a fan of glossy finishes...
Prepped
I decided to tape off the part number stickers to give it that madd tyte OEM look yo.
All nice and painted
And for that madd tyte OEM look
I'm leaving them out in the sun to dry and cure.
Heads are finished, machine shop is closed until monday... So I have to wait around for monday to come, but then everything gets put back together.
Old 07-14-2012, 05:24 PM   #65
Jester808
Member#: 166085
1989 Skyline GTR
2005 Forester XT
Jester808 is offline   Reply With Quote
Old 07-14-2012, 09:37 PM   #66
Raptor89
Member#: 285405
2013 WRX Hatch
This is so awesome!
Raptor89 is offline   Reply With Quote
Old 07-16-2012, 01:48 AM   #67
dirtcrazy
Member#: 220831
2000 Impreza RS Sdn
Drk Blue
Lookin' good, man!
dirtcrazy is offline   Reply With Quote
Old 07-16-2012, 06:42 PM   #68
Jessekrs123
Member#: 236927
1984 BRAT
Got my heads back from the machine shop, all nice and resurfaced.
The heads still need to be heatbathed, I will be addressing that hopefully this week.
Old 07-20-2012, 11:56 PM   #69
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
2003 Subaru Legacy L..ame
Any updates? I've been following your thread for some time now, I love it.
I'll be picking up an 87 Brat on Sunday, and I hope to see you updating that thread as well!
Great work so far can't wait for more!
future_subaru_owner is offline   Reply With Quote
Old 07-24-2012, 02:16 PM   #70
Jessekrs123
Member#: 236927
1984 BRAT
Did some more paint prep today.
Not Prepped / Prepped
Couldn't finish all of the intake manifold, still have to do the bottom side. Fuel stacks are prepped, and I still have to prep the block itself for paint.
I'm pulling wires out of various parts of my body from the wire wheel/dremel combo
Old 07-24-2012, 03:11 PM   #71
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Very cool build so far.
RALLYT-WRX is offline   Reply With Quote
Old 07-27-2012, 12:53 PM   #72
Jessekrs123
Member#: 236927
1984 BRAT
Prepped the entire engine for paint.
I also painted the waterpump flat red. The waterpump that was on the engine looked relatively new, but I don't want to take any chanced. I cannot afford to skimp on the cooling system for this engine...
Old 07-27-2012, 05:35 PM   #73
dirtcrazy
Member#: 220831
2000 Impreza RS Sdn
Drk Blue
One cannot skimp on the cooling system in any engine.
The H2O pump looks nice, but wont it be hiding behind the valve covers?
Old 07-27-2012, 11:07 PM   #74
Jessekrs123
Member#: 236927
1984 BRAT
Very true, I'm just trying to find the best way to lay on the coats so the color stays nice and flat. Good to test on parts that won't be seen.
Old 07-30-2012, 12:59 PM   #75
Jessekrs123
Member#: 236927
1984 BRAT
Prepped some more crap today. The bed/tailgate of my BRAT make a perfect work bench.
Had to re-tape most of the parts since the old masking tape is beginning to peel and is all dirty from wire brushing and cleaning.
Using old injector o-rings wrapped in tape make blocking off the injector holes really easy.
And I painted the valve covers as well.
3 light coats and 2 moderate/heavy coats seem to do well. The paint looks orange until you let it set in the sun for about 10 minutes, then it darkens into red.
Rare Subaru for Sale: 1993 Subaru Legacy Turbo 5MT MattDell Private Vehicle 'For Sale' Classifieds 14 06-08-2008 05:38 PM
Gauging interest...1993 Subaru Legacy LSi jetfan8178 Tri-State Area Forum 12 09-18-2004 02:59 AM
Gauging interest: 1993 Subaru Legacy turbo engine (EJ22T), FMIC, turbo, etc. marcus12 Private 'For Sale' Classifieds 11 09-04-2004 05:37 PM
1993 Subaru Legacy Turbo (EJ22T) 5 speed, extras mtnboy Private Vehicle 'For Sale' Classifieds 37 04-04-2004 11:14 AM
1993 Subaru Legacy Turbo Sport Sedan FS MugenNeuspeed Legacy Forum 8 02-10-2003 08:59 PM
