06-14-2007, 11:02 PM | #1 |
Member#: 52088
Vehicle:07 limited URBAN GRAY |
Going to check out a used 2000RS tomorrow. What should I look for when inspecting it
The car is a 2000 with <40,000 miles. Anything in particular I should keep an eye out for when checking it out? thanks
06-15-2007, 12:01 AM | #2 |
Member#: 149392
Vehicle:2007 2.5i Wagon New Port Blue |
make sure its got a engine
ok well look for rust, scrapes dents da da da. listen to the engine for knocking and other bad sounds. Look for oil on the engine, and in the ground as sign of leaks. If test driving feal out the transmissions, especially if standard. |
06-15-2007, 02:30 AM | #3 |
Member#: 7119
Vehicle:2000 impreza rs blue ridge pearl |
is it stock or modded? also check under the hood for possible damage with the paint being off
06-15-2007, 05:09 AM | #4 |
Member#: 120002
RMIC
Vehicle:2000 2.5 RS, '95 Legacy w/325k mi (RIP) |
Check under the oil filler cap for any signs of sludge buildup also.
06-15-2007, 07:39 AM | #5 |
Member#: 52088
aside from a cai and cbe its stock
06-15-2007, 09:55 AM | #6 |
Member#: 90596
Vehicle:2010 WRB STD MWSOC tuner |
look for corrosion around the engine (from salt) and don't forget to kick the tire.
06-15-2007, 10:11 AM | #7 |
Member#: 149392
Ya oil filter. Note if you see a white ish sort of pasty cream stuff there DON'T buy. Head gaskets need to be done. The coolant and the oil are mixing some ware.
Also look at the muffler, look for holes and rust on it. Basically the idea is look at items that do go over time and see if they are gone now or ready to go. I don't mean brakes, and ware items but things like the muffler that usually gets replaced over the life of the car. |
06-15-2007, 10:21 AM | #8 |
Member#: 126157
Vehicle:2020 WRX STI Limited CWP |
Wheel bearings, wheel bearings, and oh yeah wheeel bearings
06-15-2007, 11:19 AM | #9 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Look on the top of the block where the head meets it (HG). The SOHC engines blow the HG's outward and often seep onto the deck prior to fully blowing. Regardless, I personally wouldn't make that a deal breaker. At 40K mi, it is still under the WP99 service notice warranty that was issued because of the head gasket problems...
06-15-2007, 12:52 PM | #10 |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
+2 on the head gaskets... MY99 has weaping HG and i don't see anything from the top, nothing on the ground, but if you look under near the exhaust ports, it's easy enough to spot.... wait i think i ahas a pic...
Please pardon her condition, she's lived a HARD salt filled life... |
06-15-2007, 01:47 PM | #11 |
Member#: 149392
as long as it never lived in Newfoundland then its all good. I am from newfoundland and its known as the rustest place in the world.
We (family) had a pontiac 6000, great car in all honesty in its time, especially as a family car. 3.1 L engine was bullet proof (same engine basiclay as my 1994 olds acheave, and again bullet proof). I was just getitng licence and we where working on the car doing rust work to realize the 1/2 chassey these things had was for all intensive purposes missing. Rusted away. Got rid of it soon after lol so car location has somthing to do with it to. |
06-15-2007, 08:49 PM | #12 |
Member#: 136144
RMIC
Vehicle:2010 STi SWP |
When I bought my car, I was told that this whiteish cream can also be found on the underside of the coolant cap. So I would check that as well.
06-15-2007, 10:12 PM | #13 |
Member#: 52088
06-15-2007, 11:26 PM | #14 | |
Member#: 2234
SCIC
Vehicle:2019 Outback 3.6R ISM |
Bring a OBD2 scanner if you have one... Just in case there's CEL while running... And < 40k miles?.... If the exterior/interior condition doesn't match the mileage... or the floor mat has a nicely 'worn' look to it... or tires look older... most likely the instrument panel has been replaced... Something that can be done < 10 minutes... Average mileage ~80k.... Why car so low mileage? multiple to choose from on a daily basis? |
06-16-2007, 05:52 AM | #15 |
Member#: 53558
NWIC
Vehicle:2005 Baja Turbo White/Silver/Black 3tone |
My family usually takes a prospective car to a dealership for a full inspection (last step before initiating payment). The dealership should note if the HG is good or not, wheel bearings, muffler condition, etc. And be fair about it, pay for the inspection yourself. You can get the seller to knock off the price of the inspection if you end up buying it, and the seller doesn't feel like they get ripped if you don't.
06-17-2007, 01:06 AM | #16 |
Member#: 120002
RMIC
Take the car for a test drive and get it up to 50-55mph. Your listening for a out of round sound, like a repeating throbbing sound. If you hear something then start swaying the car side to side and listen to see if the sound increases and then decreases. What you're doing is loading and unloading the bearings side to side to help determine which side has the bad bearing. If the sound increases when you start decelerating then the bad bearing is in the front. If you hear the sound, but it doesn't change w/ loading the bearings then it is tire noise.
06-17-2007, 12:57 PM | #17 | |
Member#: 52088
Well I checked out the car the other day and it looked great. Aside from a large dent on the hood from when he took took tight of a turn with the motorhome while towing the RS, we loved it. It looks like my girlfriend will be buying it once we have time to meet him again. Then I asked about the headgasket problem he says there were 2 different problems, some engines had an internal leak and others had the external leak. he said his car is the one that is supposed to have the external leak. So should we go ahead and take it to a dealership for the headgasket fix? Or wait later down the road when/if we have problems with it? |
What should i look for when buying a used 2.5i? | kaotewei | Vancouver Impreza Club Forum -- VIC | 3 | 05-20-2009 01:03 PM |
What should I look for when I want to buy a Suby in AK | MrRicH | Alaskan Impreza Club Forum -- AKIC | 6 | 06-26-2007 04:27 AM |
Goin to check out a used 04 STi on tuesday...what to look for? | SoGardSuby | Newbies & FAQs | 19 | 06-09-2007 05:18 PM |
Looking to buy 2003-04 WRX with mods. What should I look for? | 01jeepxj | Newbies & FAQs | 4 | 05-10-2006 05:05 PM |
My car is here, what do I look for when I inspect? | banghado | STi Forum Archive | 4 | 06-02-2003 10:48 PM |
