Welcome to the North American Subaru Impreza Owners Club Monday July 4, 2022
Old 08-06-2010, 12:27 AM   #126
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by achavez View Post
the light wheels are the kosei k1 ts right? 14.6lbs $196 from tirerack.com
no the wheels are konig daylites 14.2 lbs in the color black
Old 05-22-2011, 01:53 AM   #127
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Sorry for bumping 6 months old thread, but I am glad I came across this thread.
Interesting results on weight of both rotor and wheel/tire leading to increased amount of power.
I went from heavy LGT rotors/calipers, 17" Prodrive P1 and 225/45/17 RE070 (heavy tire) to:
Rotora slotted front rotors, JDM 4 pot aluminum calipers, 17" STI 5x100 BBS wheels and Michelin PS2 tires.
Total saving in weight per corner was around 30 lbs.
txl146 is offline   Reply With Quote
Old 05-22-2011, 11:47 AM   #128
LittleBlueGT
Member#: 96204
2013 STI GR
First time I saw this thread.
Did you ever trap faster?
FWIW I always measure the tires as they can be off a lot more then .25 inch like Ron said. I have seen them off by .7 of an inch. So that could explain some of your whp. I am sure though that you gained some form the lighter set rims.
LittleBlueGT is offline   Reply With Quote
Old 05-22-2011, 12:59 PM   #129
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
So, is the claim that the lighter wheels helps the engine MAKE more power? I dont quite understand the concept, since Juan claims to have adjusted for the weight difference.
I keep going back to what maxpowr said regarding gearing, and what LittleBlueGT said about the tire diameter being off.
I do not see how wheels would play any role in engine power production.
The gains have to be merely from faster acceleration, which will show more power on airboy, similar to a dynojet, correct? Is it possible that airboy is simply not accurate enough to compensate for the small weight differences?
langsbr is offline   Reply With Quote
Old 05-22-2011, 01:03 PM   #130
CatfaceType-R
Member#: 81102
^^simple, it's less rotating mass, it's takes less torque to make the wheels spin
you can see powerloss on the dyno from heavier wheels/bigger brake kits...etc. fyi research sprung and unsprung weight for a further read
Old 05-22-2011, 01:08 PM   #131
09SLOWRX
Member#: 282044
The engine makes the same power. It makes let's say X crank hp or brake hp. When the power is sent from the motor through the drivetrain and to the wheels, it will have an X % parasitic loss to put the power to the ground. Removing unsprung weight or rotational mass from the drivetrain will result in lowering the parasitic loss of power to the ground. So in turn yield a higher whp or wtq which is measured after the parasitic loss. Someone correct me if I'm wrong
09SLOWRX is offline   Reply With Quote
Old 05-22-2011, 01:09 PM   #132
efaroh
Member#: 166947
2006 WRX Sedan
Crystal Gray Metallic
subscribed for future reference! Thanks for the experiment and contribution!
efaroh is offline   Reply With Quote
Old 05-22-2011, 01:57 PM   #133
STiPOW3R
Member#: 276368
I dont get it obviously it will be faster with lighter wheels.
STiPOW3R is offline   Reply With Quote
Old 05-22-2011, 03:39 PM   #134
maxpowr
Member#: 159243
5/01 bugeye
Hakt Ecu is back!
wastes less power to get her movin...simple as that.
maxpowr is offline   Reply With Quote
Old 05-22-2011, 03:40 PM   #135
mowgli29
Member#: 203438
Word. How do people NOT understand this concept?
mowgli29 is offline   Reply With Quote
Old 05-22-2011, 07:28 PM   #136
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
The concept of lighter wheels making a car FASTER should not be debated.
However, Juan said that he input the different weight of the vehicle after swapping wheels. If that's the case, if the airboy dyno were indeed accurate, it should have demonstrated the SAME power, not an increase. Do you not agree?
I'd like to see what the "gain" would have been had he kept the weight the same on both.
FWIW, if I fudge the weight of my car on an airboy/virtual dyno run by 300lbs, it only gains 20 hp.
The wheel diameter will have a similar effect - by changing the tire diameter, the power will change nearly 25 hp.
This leads me to believe that the majority of the gain Juan was seeing was due to the overall tire diameter difference, and not necessarily the weight.
Old 05-22-2011, 07:35 PM   #137
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Changing the weight of the vehicle is different vs wheel weight as wheels are rotational weight and change the drivetrain loss. He didn't gain any power, he freed it up.
LIQUIDSK8S is offline   Reply With Quote
Old 05-22-2011, 07:38 PM   #138
treystoys
Member#: 97436
05 Legacy GT
white
Wrong and simply because your after wheel horsepower which is decided by how fast the motor can accelerate a car or specific values (weight, tire diameter...)...engine power did not change WHEEL horsepower did. The car as a whole is putting more power to the ground, not the engine.
Trey
Tey
treystoys is offline   Reply With Quote
Old 05-22-2011, 10:43 PM   #139
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
so why did a guy on the first page not see a difference on a dynojet with his Rav4? someone said dynojets cant read like a mustang for weight bearing or load or something i dont get but to me if lighter wheels are put on and the motor can move faster and build up speed then it shouldnt matter what dyno your on, gain should still be seen because its not as hard to get them up and moving.
synolimit is offline   Reply With Quote
Old 05-22-2011, 10:58 PM   #140
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Dynojets use a drum that weighs about 3000lbs simulating a vehicles weight. It is what you call an inertia dyno. That is why you dont get great results on them. A mustang and a dyno dynamics dyno or a load cell dyno allows you to set the load electronicly. Allowing you to more acurately simulate the vehicles weight of the vehicle being tested.
CUNNINGHAM is offline   Reply With Quote
Old 05-22-2011, 11:19 PM   #141
synolimit
Member#: 225225
11 WRX
i understand the difference in the dynos. so if the drum weighs 3000lbs and wheels/tires/rotors etc weigh 45lbs each for example, then the motor trying to moving 3180lbs. if you lose 30-40lbs off wheels and tires then the motor is now only moving 3140lbs which is nothing and wont show up on a dynojet??
this kinda blew my mind if anyone can understand it...enjoy
Originally Posted by Buffy
When we accelerate the car, we're actually accelerating two things; the car, with an essentially linear force, and the rotating parts with an angular force. This is most of what accounts for the difference between flywheel horsepower and rear wheel horse power as measured on an intertial dynomometer. Friction losses in the drive train are a much smaller factor. [quote]
HP going to friction losses are a larger factor than HP going to inertia losses for a dyno run done in 4th gear on an inertia dynamometer (there's no such thing as an "inertial" dynamometer...inertial designates a frame of reference). As the HP level goes up, the HP going to inertia losses increases but so does the the HP going to friction losses. On absorption type chassis dynos, HP going to inertia losses can be held constant no matter how much HP level increases (within reason).
Conventional wisdom puts drivetrain loss on an intertial dyno at about 15% for a C6, and in terms of accelerating the car this is wasted power. Unfortunately, modelling how much energy goes into what rotating part is quite complicated. And to make it more complicated remember that some of these parts - the flywheel, clutch, drive shaft and half the transmission - are accelerated more than once as we shift gears during a run. [quote]
Convential wisdom is like common sense in that it's the least common of the senses. (And you're killing me with that "inertial" dyno thing.) There is no percentage loss that can be stated for every drivetrain or any one particular drivetrain. A stock LS2/M6 seems to have ~55 HP loss through the drivetrain. Also, the clutch/flywheel is included with the 400 FWHP rating and the driveshaft only has to be accelerated "once" in a 1/4 mile race. But you came close to a big factor in that the rate of acceleration is different in each gear which will make a big difference as you'll see later.
But as a first-order estimate, let's assume that a C6 weighs 1500 kg (3360 lbs), a brake, wheel and tire assembly 32 kg (about 72 lbs) and a run ends with a terminal velocity of 51.4 m/s (115 MPH). This gives us a linear kinetic energy at the end of the run (1/2mv^2) of 1.98e+6J.
Further assuming that the brake, wheel and tire assembly approximates a uniform disc we get a momemt of intertia of about 1/2 x 32 x .334^2 or 1.78 kg m^2. At the end of the run the wheels are turning 1470 RPM, for an angular velocity of about 154 rad/s, so rotational energy per wheel at the end of the run (1/2Iw^2) is 66.8e+3J, or 267e+3J for all four. [quote]
While I know you're trying to make the calculations easy, assuming the brake (rotor), wheel, and tire assembly to approximate a uniform disc with "X" diameter introduces a huge error into the calculations. The HP to accelerate the C6 is the sum of the HP to going to translational inertia and the HP going to rotational inertia. To express HP going to rotational inertia as a percentage of total inertia, you have to know the amount going to rotational inertia. Your calculation for rotational kinetic energy is incorrect. I came up with 21.2e+3J for one or 84.4e+3J for all four using your numbers in your correct formulas.
The rotational energy in the wheel assemblies is about 7% of the total energy, and they account for around 15% of the total mass. So reducing mass in the external rotating parts - brakes, wheels and tires - is roughly half again as effective as reducing the mass of non-rotating parts. But still, reducing the wheel weight by 1 kg (2.24 lbs) per corner by switching to, say, PS2s is only about a 0.4% gain, or the equivalent of about 1.6 more HP! [quote]
I came up with 4% for the wheel assemblies part of the total kinetic energy added to the system in a 1/4 mile run and 2% of the total mass of the car. Then all of a sudden, you pull a 1.6 HP number from somewhere. If you want to convert to HP, you have to analyze the problem from the perspective of kinetic energy added to the system. The sum of the translational kinetic energy and rotational kinetic energy from above is 2064000 J. One Joule=.737 FT-LB giving us 1522000 FT-LB of energy (not to be confused with torque which is a force). To solve for HP, you have to know the time it took to add the kinetic energy to the system...we'll say 12.5 seconds for a nice round 1/4 time for a C6 LS2 (not the best time nor the worst time). Dividing 1522000 FT-LB by 12.5 seconds gives us 121800 FT-LB/sec. One HP=550 FT-LB/sec so 121800 FT-LB/sec becomes 221 HP. Now before anyone begins to cry foul by citing the 400 FWHP of the LS2, remember this is only the HP required to add the kinetic energy to the car to get to 115 MPH in 12.5 seconds and includes the total weight of the car for translational inertia but only includes the tire/wheel/rotor for the rotational inertia. All the rest of the rotating components are not included nor is the effect of wind resistance. Now to tie in my comment above about the gear you're in and how it affects rotational kinetic energy and HP, you can see how the time factor affects HP above. The faster you get to speed (or the faster you accelerate), the higher the HP number will become. Now think of how quick you accelerate through 1st gear vs how long a 4th gear pull is...there is quite a bit of time difference there and the higher speeds in 4th mean more air resistance too. Therefore, the lower the gear you run in, the bigger the effect rotational weight has on HP. A one pound difference at each wheel would be impossible to feel 4th gear (and most likely immeasurable) while a 6 LB difference at each wheel would would be noticeable in 1st gear to the "seat of the pants" and take a very sensitive device to measure the difference in 4th. For road racing where speeds vary from 60-150 MPH, a pound or two at each wheel for bigger rotors or wheels or tires is going to affect acceleration performance only slightly while it substantially improves braking/cornering.
Old 05-23-2011, 05:28 AM   #142
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
TLDR
Old 05-23-2011, 07:54 AM   #143
juanmedina
Member#: 133146
Originally Posted by Phatron View Post
TLDR
Me too
Old 05-23-2011, 08:50 AM   #144
maxpowr
Member#: 159243
5/01 bugeye
Hakt Ecu is back!
Old 05-23-2011, 05:00 PM   #145
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^^^^^Yeah im lost lol
Paidfor is offline   Reply With Quote
Old 03-30-2013, 09:35 PM   #146
chrispsti
Member#: 342676
11' lexus isf
sti sold 2011 Lexus isf
Interesting info in this old thread
chrispsti is offline   Reply With Quote
Old 01-15-2022, 10:28 AM   #147
karina.novikova764
Member#: 528369
Over 30 lbs in rotating mass > temp difference. I love that the lighter wheels still outperformed despite the increase in ambient temperature. You can read more about it here https://gtd-review.com/
karina.novikova764 is offline   Reply With Quote
Old 01-15-2022, 10:07 PM   #148
K3rm1tth3fr0g
Member#: 508105
Link tuned 02 WRX
EJ205 20G-XTR JDM 6MT E85
This thread is 9 years old my friend. Look at post date before bumping ancient threads.
K3rm1tth3fr0g is online now   Reply With Quote
Old 02-15-2022, 11:36 AM   #149
jeremiahgerald321
Member#: 528857
It can be overwhelming to choose from so many options on the market. We can help you narrow down your options to the top 10 best vacuum for car detailing.
https://gtd-review.com/10-best-vacuu...etailing-2022/
jeremiahgerald321 is offline   Reply With Quote
Old 02-15-2022, 11:37 AM   #150
jeremiahgerald321
Member#: 528857
Here's an overview and buying guide for the best single din head units currently on the market. https://gtd-review.com/10-best-singl...tereo-in-2022/
List all light weight wheels Icon25rs Tire & Wheel 6 03-03-2007 09:37 AM
Light Weight Wheel Poll, SSR, Racing Hart, Buddy Club 2-quick4u Tire & Wheel 6 02-10-2006 10:42 PM
WTB: 16" light weight wheels moforose3.0 Private 'Wanted' Classifieds 6 04-08-2004 01:22 PM
The most light weight wheels? Lightning Jack Newbies & FAQs 13 04-08-2003 10:21 AM
New 5Zigen Light weight wheel Accurit Performance Brakes, Steering & Suspension 9 01-05-2002 01:28 AM
