03-25-2003, 10:54 PM | #1 |
Member#: 33931
Vehicle:2001 Impreza RS Black |
Rough Idle in Park
Hey all! Last week my dream came true when I bought a 2001 Impreza RS sedan. But there is someone thing that I question about the car when it idles. It seems kinda rough when the car sits in park. Its kinda a choppy, inconsistent idle. As soon as i put it in drive, its fine. The car only has 12,000 miles on it, i just did an oil change, and added fuel injector cleaner. Is this normal? Should I check the Plugs? If anyone has any suggestions or thinks this is normal, please let me know. If you live in the Philly area let me know, Im looking to get together and show off our rides.
Peace, Matty S.
03-26-2003, 02:15 AM | #2 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Boxer engines have inherently rough idles. What rpm level is it idling at?
03-26-2003, 02:59 PM | #3 |
Member#: 32846
Vehicle:1998 Impreza L-SOLD Arcadia Green |
My girlfriend's Nissan was idling rough and low at around 400 rpms, and would stall the car if I turned the A/C on. I removed the throttle body boot and cleaned the throttle bottle, plate, and inside the TB with Throttle body cleaner. It’s critical that you use an approved Throttle body cleaner and not just a carburetor cleaner. The throttle body has parts that are Teflon coated and pure carb cleaner will eat this coating off. I used Valvoline SynPower Throttle Body and Carburetor Cleaner for $2. I wouldn't think that after 12,000 miles you would need to do this, but usually rough idling is a result of a dirty throttle body, fuel filter, air filter, or faulty injector. If all these check out o.k., check your distributor cap and rotor. You can check your injector(s) by using a long screwdriver and putting the tip against the injector. Put your ear against the handle while touching the injector with other end of the screwdriver and you should hear swishing and clicking if the injector is working. Or you could get a stethoscope. With only 12,000 miles on your car this is kind of mysterious. Most cars have a idle screw that can be adjusted but this would be my last resort. I'm not a mechanic but this is what I would do to troubleshoot if it were my car.
-Charles- |
03-26-2003, 07:22 PM | #4 |
Member#: 33931
I think im idling round 800, ill have to double check.
03-27-2003, 02:27 AM | #5 |
Member#: 2272
BAIC
ok, ~700 is what it should idle at. Dont see any problems there...
03-27-2003, 02:50 AM | #6 | |
Member#: 7101
Vehicle:00RS I want to fill your mouth with spiders |
Similar Threads | ||||
Rough idle, intermitent and rough cold starts... | carter_wrx | Pre-2002 Factory Turbo Powertrain | 26 | 10-28-2009 01:03 PM |
How Rough is a Rough Idle | Go350zGo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 10-22-2009 11:28 PM |
Slightly Rough Idle in New XT | XT_Mike | Forester Forum | 12 | 04-12-2004 09:57 AM |
99 outback rough idle when in drive | limey60 | Newbies & FAQs | 1 | 03-01-2004 10:29 PM |
Sputtering and rough idle in the cold? EEK! | GooseMan | Normally Aspirated Powertrain | 6 | 02-15-2002 11:50 AM |
