05-14-2014, 07:31 PM | #26 |
Member#: 387281
Vehicle:2015 WRX WRB |
I just figured out the stock crossover for the tweeter can be separated from the tweeter/bracket. You'll still need a bracket, but this would allow you to use the same connection and not run a separate wire to the crossover with the door component.
05-14-2014, 07:38 PM | #27 |
Member#: 390730
Vehicle:2015 WRX Limited CWP |
Slick, so you removed the x-over from the setup, thus allowing you to use the pre-run wires from your JL crossover from the component speakers straight to the stock location. Then just use the same wiring harness as the doors and get a mounting bracket and you are good to go.
05-14-2014, 07:49 PM | #28 |
Member#: 390730
Turns out putting the amp under the seat is not the greatest idea around. Airbags, electronics, etc... re-thinking again... need a notebook or something to keep all this information straight.
05-14-2014, 08:41 PM | #29 |
Member#: 387281
If you go with an alpine hu you could get the power pack and put it in the glove box.
05-14-2014, 08:42 PM | #30 |
Member#: 390730
05-14-2014, 08:44 PM | #31 |
Member#: 387281
I need to double check but I think the power pack only connects to the head unit; you don't have to run a separate power, ground or remote. It's all wired in.
05-15-2014, 12:44 AM | #32 | |
Member#: 208409
Vehicle:2012 WRX Sedan WRB |
EDIT: Saw you might go with the JL C2-650 and you have Amazon Prime. I was in the same boat a few weeks back, and I wanted to compare those components with my Alpine Type Rs. Ended up here: http://www.tacomaworld.com/forum/aud...ou-prefer.html (post 4 is very informative). Anyway, save $40 by getting the SPR-60C, and you'll have $40 left over to spend on an amp is my vote. Last edited by jadawgis732; 05-15-2014 at 12:53 AM. |
05-15-2014, 05:45 AM | #33 |
Member#: 390730
I cleaned up my original post with my current plan. Decided to go ahead and do the amp, and the JX360 seems like the smart cost effective choice which still sounds great.
05-15-2014, 05:59 AM | #34 | |
Member#: 390730
As far as the amp, I was thinking a very small Class AB for better sound quality as opposed to Class D like the RF you suggested. Right now I am looking at the JL JX360/4 for $249... Focal makes a nice 4 channel but its $400 and a Class D, last one I was checking out was an Alpine MRP-F300 which is $150 and a Class AB. I worry about quality at that point. |
05-15-2014, 06:03 AM | #35 |
Member#: 390730
Consolidated Class AB Amplifier Options:
Comparison Link for the top 4 options: http://www.crutchfield.com/App/Produ...X3604&g=347050 Last edited by ronaldvalente; 05-15-2014 at 06:06 AM. Reason: comparison link |
05-15-2014, 08:45 AM | #36 |
Member#: 390730
Maybe this is stupid, but I could throw these speakers in and the AVH and not have to run the amp... not sure I keep second guessing the amp install, it shouldn't be too difficult. I guess the decision will be a lot easier when I see the car in person.
Fronts: http://www.amazon.com/JBL-GTO608C-6-5-Inch-Component-System/dp/B0024JARH6/ref=sr_1_5?ie=UTF8&qid=1400157701&sr=8-5&keywords=jbl+car+speakers Rears: http://www.amazon.com/JBL-GTO638-6-5-Inch-3-Way-Speakers/dp/B003KN2TF8/ref=sr_1_1?ie=UTF8&qid=1400157701&sr=8-1&keywords=jbl+car+speakers Thoughts on the JBL GTO Series Speakers for a stock replacement without a dedicated amp run from the AVH 4000NEX? Last edited by ronaldvalente; 05-15-2014 at 08:45 AM. Reason: cleanup |
05-15-2014, 08:38 PM | #37 | |
Member#: 208409
EDIT: Ah, I see you clarified your stance towards class d below. My bad. Yeah, distortion was my only concern, but I cannot tell that any is occurring, if indeed it is. The Alpines are actually loud enough that the Pioneer 10" sub in the trunk is completely dwarfed when bridged on channels 3 and 4. Thank God for adjustable gains... |
05-15-2014, 08:42 PM | #38 | |
Member#: 390730
http://www.amazon.com/Rockford-Fosgate-R400-4D-Full-Range-4-Channel/dp/B004T0WFVE/ref=sr_1_1?ie=UTF8&qid=1400200811&sr=8-1&keywords=R400-4D More research needed. :-) |
05-15-2014, 09:20 PM | #39 |
Member#: 390730
Also going to take a look at the PPioneer GM-D8604, it is right in my price range.
05-15-2014, 10:27 PM | #40 |
Member#: 390730
So considering heat concerns I am going to re-think my decision about not looking at Class D amps... seems silly as they are actually getting fairly decent reviews.
HU: Pioneer AVH-4000NEX Front: JL-Audio C2-650 Rear: JL-Audio C2-650X Amp: Pioneer GM-D8604 or R400-4D |
05-16-2014, 06:01 AM | #41 |
Member#: 390730
Anyone put subwoofers in the rear doors? Kicker 40CWRT672
05-16-2014, 11:16 AM | #42 |
Member#: 390730
Ok so I actually have done quite a bit of reading/research... I have decided to go with a class D amp to ensure I have no heat issues.
Below are some well regarded amplifiers for under 300 which are all pretty nice. The JBL (if I can find it, is most likely the best choice). All are full class D amplifiers. Pioneer GM-D8604 $220 Rockford Fosgate R400-4D $150 Rockford Fosgate P400X4 $220 JBL MS-A1004 $290 I was toying with the idea in my head to put in woofers only in the rears to circumvent the need in the future for sub's but I am concerned about the low frequency in the door will just sound muddy, rattly, and terrible. But I refuse to pay 600 or more for a huge 6 channel amp, that is the opposite of where I want this setup to end up. That leaves me with needing a great in-door setup with low-enough bass. I think the head unit alone will help out, and then the new speakers with an amp will sound an order of magnitude better than the stock setup. If subs in the doors will work, then maybe I will entertain that, but I don't think the JL C2's can be beat in their price range. Combine them with a solid AMP from the list above and I have a pretty solid setup. |
05-16-2014, 11:20 AM | #43 |
Member#: 127208
Vehicle:2011 STI Black |
based on what kind of music you primarily listen to, door speakers alone will most likely not produce a sufficient amount of bass to provide a full range of sound to your liking.
05-16-2014, 12:38 PM | #44 | |
Member#: 390730
1. Stick with the JL speakers, don't want to sacrifice speaker quality, esp. if I am investing in an amp. C2-650 Components $250 Fronts, C2-650x $135 Rears. 2. Get a 4 channel amp, either the Pioneer GM-D8604, Rockford Fosgate P400X4, or the JBL MS-A1004. $220, $220, and $280 respectively. 3. Get the Pioneer AVH-4000NEX Head Unit $700 4. Get all the necessary harnesses, SWC, and dash kits etc. $150 5. Get a small slim sub, thinking about the JL Micro Sub or similar. $300 Installation Run the Fronts off Ch 1 and Ch 2, Run the Rears off the Head Unit, and Run the Sub off Ch3+Ch4 bridged. Boom. Problem solved. ~$1600 give or take (albeit for a MUCH nicer setup than the stock and the HK option) |
05-16-2014, 01:20 PM | #45 |
Member#: 127208
I would even consider dropping the rears entirely and getting a nicer set of component fronts only. This option imo would sound better than muddying the clarity with a lesser quality underpowered set of rears. Or just get woofers for the rears. I am running Focal K2P components up front with just Focal KF woofers in the rear and You would never be able to tell it was just the front 2 tweeters doing the work.
05-16-2014, 01:23 PM | #46 | |
Member#: 390730
I'll take a look at crutchfield and see what they have in the way of 6.5" woofers. Thanks! |
05-16-2014, 01:28 PM | #47 |
Member#: 390730
Here is an interesting thought;
Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker in the rears. 50 bucks a pop. 35 to 800 Hz http://www.parts-express.com/tang-ba...eaker--264-919 |
05-17-2014, 12:52 AM | #48 |
Member#: 387281
I successfully mounted JL tweeters with the stock connector and built in crossover. Sounds amazing.
05-17-2014, 06:31 AM | #49 | |
Member#: 390730
So if you are using the stock wires and xover what are you doing with the one that shipped with the JL components? |
05-17-2014, 08:37 AM | #50 |
Member#: 390730
Ok, so I wasn't looking at the Alpine Head Unit amp because I thought it needed to be installed only with an Alpine head unit. Wrong! My mind is blown.
So now I can get the amplifier if needed, without all the mess of installing it in the trunk AND still use the stock wiring! This is HUGE! http://www.crutchfield.com/p_500KTP4...ower-Pack.html |
