10-30-2013, 11:45 PM | #151 |
Member#: 171948
Vehicle:19 Sti Crystal white |
its fine. i see 22 psi on my vf52 with the yellow.
10-31-2013, 12:14 AM | #152 |
Member#: 338312
10-31-2013, 12:32 AM | #153 |
Member#: 312048
NESIC
Vehicle:2011 BMW e92 335i BSM |
Thanks for the responses guys! My BPV seems to be venting correctly now. I guess that the car just had to get used to it lol. Again, xluben, thank you for inadvertently helping me out (again)!
10-31-2013, 06:08 AM | #154 |
Member#: 287450
SWIC
Vehicle:2011 Impreza WRX Satin White Pearl |
The yellow spring with no shims will in theory hold more boost than you could possibly be making... Xluben has stated this several times in this thread....
10-31-2013, 06:45 AM | #155 |
Member#: 344329
Vehicle:2008 Wrx, 6mt |
Huh? The spring is for how much vacuum you have, not boost...
10-31-2013, 07:33 AM | #156 |
Member#: 347348
Vehicle:2013 WRX DGM |
Is the goal to get to the amount of spring and shims needed until you get compressor surge then back down a shim?
06-13-2014, 10:14 AM | #157 |
Member#: 328682
Just installed mine, tuned for 18lbs which with the stock bpv reached that point fine but now with the forge bpv and yellow spring it takes longer i hit boost and taps out at 14-15lbs?
09-09-2015, 12:08 PM | #158 |
Member#: 281522
Vehicle:05 Outback 2.5XT Silver |
Old Thread but do any US vendors stock the rebuild kits? My top o-ring tore so i need to get the kit. Buying direct costs more for shipping and it's not a set price and probably no arrival date.
09-12-2015, 07:35 PM | #159 |
Member#: 171948
go to some auto stores. match one up. i needed one for the bottom of mine that mounts to the tmic. i found one at my job from a caterpillar o-ring set.
09-13-2015, 11:45 AM | #160 |
Member#: 281522
I had zero luck with any of the auto part stores local. i ended up ordering it direct from Forge.
09-13-2015, 07:43 PM | #161 |
Member#: 292225
Vehicle:08 WRX (16g) OBP |
All it would take is for someone to post the exact oring dimensions.
Then you could go online and get some proper orings that are meant for oily environments. The stuff from autoparts stores might degrade overtime due to blow-by. |
FS : JNA front lip for 08+ wrx's, brand new | jonnylin1 | NWIC Private Classifieds | 9 | 10-11-2010 02:12 AM |
Forge BPV for sale | DohcVtec | NESIC Private Classifieds | 7 | 04-21-2008 02:10 PM |
WTT: Forge BPV for a BOV | o2sys | Engine/Power/Exhaust | 11 | 05-05-2007 10:59 AM |
Forge BPV for sale | Adrenalin Rush | Private 'For Sale' Classifieds | 2 | 06-22-2006 12:56 PM |
