Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 09-19-2007, 11:15 AM   #1
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
Default Track Day Oil Recommendation
What engine oil do you guys use for your WRX or STi for doing track day lapping?
I have a Stg. 2 STi and do track days in MSR Cresson, TX (Dallas/Ft.Worth Area)
So far, for the past 2-3 years, I have been using Mobil 1 5W-40 Diesel Synthetic Truck Oil to protect my engine.
Recently I figured out that Mobil 1 isn't grp IV oil anymore.
There are better oils off the shelf at local Auto Parts out there for the price such as:
German Castrol 0w-30 (as thick as 37 weight)
Shell Rotella Full Synth 5W-40.
(Off the shelf = local parts store)
Is it really necessary to go w/ THICK 20W-50 on a Stg.2 STi which only laps every 30 mins session or so in a non competitive environment? I'm trying to find all around oil if available.
Inputs from track day whore is appreciated..
salaki is offline   Reply With Quote
Old 09-19-2007, 11:29 AM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
I use Motul 8100 5w40 and it works great. Very minimal consumption, I usually end up adding half a quart or less over the course of a full weekend event. I had similar results with Motul 300V 5w40 but it wasn't worth more than twice the cost. When I was using Mobil 1 I was burning a lot of oil, now I won't go near that stuff. Although I know a lot of people that use it in Porsches, BMWs, etc. with very good results.
boost junkie is offline   Reply With Quote
Old 09-19-2007, 11:29 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I use 15W-50 Mobil 1 and have been very happy. Doesn't eat oil at all and oil temps seem to be slightly lower.
Old 09-19-2007, 11:30 AM   #4
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Do you use that weight in the winter too, Tim?
Old 09-19-2007, 12:02 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 09-19-2007, 01:09 PM   #6
mav1c
Hoodbridge!
Member#: 560
I'll probably go back to 5W-30 in the winter, but honestly, I doubt the car will be out of the garage much at all anyway.
Old 09-19-2007, 01:53 PM   #7
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Cool, I might give a heavier weight a try next summer. At my power level now the 5w40 is fine but in the off season I'll be adding close to 100whp so everything will run a bit hotter on the track. I was a little worried that 15w50 was too heavy but maybe I'll switch to Motul 300V 15w50 for the summer.
Old 09-19-2007, 03:05 PM   #8
tdm74
Member#: 65464
god damn these
electric sex pants
Originally Posted by Uncle Scotty View Post
wow 10w-60.
tdm74 is offline   Reply With Quote
Old 09-19-2007, 05:19 PM   #9
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
i've been running Eneos 0w-50w for the past year and a half. car sees mostly track days, never any problems. of course, AZ. climate is different.
i just switched to Motul 300v 5w-40, so we'll see how that does.
WgnWheel is offline   Reply With Quote
Old 09-19-2007, 09:18 PM   #10
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
Hmm 0W-50....
Seems like the best to protect both cold and hot..
How much is it per 1 qt?
Edit..
Seems like I can find one local:
http://www.eneos.us/web/dealer_locator.aspx
Old 09-19-2007, 09:31 PM   #11
blue blurr
Member#: 51111
10w30 here in cali, running it in about 4 cars and no problems... Royal Purple, Red Line, and Mobile 1. Haven't noticed a difference between them.
blue blurr is offline   Reply With Quote
Old 09-19-2007, 10:32 PM   #12
misterau
Member#: 108434
05 sti
Dam tank is almost empty
mobil 1 0w-40
misterau is offline   Reply With Quote
Old 09-19-2007, 11:01 PM   #13
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Motul 300V 5w-40 here, will get the UOA back from the 300V 5w-30 with ~4K miles and 50 minutes of lapping probably next week. This run of oil will have 81 autocross/ProSolo laps and ~6K miles
Should be sufficient for a trackday. If you need a place to get NASIOC deals on Motul, PM me
JamesWilson is offline   Reply With Quote
Old 09-19-2007, 11:46 PM   #14
MaxSTi05
Member#: 110957
05 STi Stg 2 Cobb
HBspeed, Autopower, KW
I've been using the same with similar positive results like mav1c. Oil temps are steady and very little burn, car has ~30K. This is including SoCal summers.
MaxSTi05 is offline   Reply With Quote
Old 09-20-2007, 09:38 AM   #15
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
I noticed my oil temps were about 10 degrees higher with Mobil 1 15w-50 than with the 5w-30. 5w-40 sounds like a good compromise.
CTKAG is offline   Reply With Quote
Old 03-28-2009, 06:48 PM   #16
scottjua
Member#: 2937
2013 2019 Type R
2006 STi Aspen White
bump Salaki's post for new input and experience...
scottjua is offline   Reply With Quote
Old 03-28-2009, 07:26 PM   #17
dunk
Member#: 15359
I've run quite a few oils in my track car.
Castrol Syntec 5w50
Mobil 1 - 15w50
Valvoline Racing 20w50
Shell 15w40 (non synthetic)
No issues with any of them. Car sees no street time at all. Oil changes every other event (roughly)
-Duncan
dunk is offline   Reply With Quote
Old 03-28-2009, 09:48 PM   #18
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
another rotella 15w40 user here as well
nhsilversti is offline   Reply With Quote
Old 03-29-2009, 01:57 AM   #19
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
No more track car for me
I use German Castrol (BMW Long Life Approved) on my current car.
I also use Shell Rotella T on both Saab 92X Aero and Triumph Sprint ST 1050 w/ Purolator Pure One Oil Filter (3.25" length PL14610 - about .75" longer than OE length)
Old 03-29-2009, 08:48 AM   #20
Jack8888
Member#: 206996
Default How about Penzzoil?
How do we use Penzzoil?
Jack8888 is offline   Reply With Quote
Old 03-29-2009, 12:55 PM   #21
XmanSTi
Member#: 65206
1986 Brat
Red
I use Rotella T in the NA rally car, it sees as much high RPM hot weather use as any track car plus all the dust of a rally car. good stuff.
XmanSTi is offline   Reply With Quote
Old 03-29-2009, 03:05 PM   #22
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
www.ClintonRacing.com
Anyone using the Rotella T non-synthetic 15w40 on the track? Or just the synthetic 5w40?
generalee69 is offline   Reply With Quote
Old 03-29-2009, 05:08 PM   #23
dunk
Member#: 15359
I ran the non synthetic this last track weekend. I haven't sent the sample off to get checked though, so I can't really give you any data on how well it did.
-Duncan
Old 03-29-2009, 09:32 PM   #24
flycaster
Member#: 60142
2011 WRX
Grey
Seriously, if you're dropping it every couple of engine hours, do you really think it matters? Moreover, I don't imagine you're firing it up and competing in really frigid conditions where a synthetic truly shines.
flycaster is offline   Reply With Quote
Old 03-30-2009, 08:16 PM   #25
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
am I retarded.. sorry -- For some reason I didn't read the posts from the 2 people before me stating they use the 15w40 non-synthetic!
AutoX/Track Day Oil Level 68Cadillac Motorsports 7 02-06-2008 08:49 PM
Track day oil temp data, N/A Subie Patrick Olsen Motorsports 8 04-29-2006 04:30 PM
Recommendations for swaybar setting at track day MattSTi Motorsports 25 09-08-2005 02:17 PM
STI track day recommendations?. WRX 2002 STi Forum Archive 5 08-07-2003 09:16 PM
Track Day Tires-recommendations please. SFsube Technical Forum Archive 16 08-09-2000 05:55 PM
