Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 01-15-2019, 09:56 PM   #226
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
Originally Posted by Stija View Post
You can get them at Chinese eBay sites for fraction of price, 10 pieces for 10$.
I did buy from ballenger, but that wasnít my question. Either way I think I found them.
Now all thatís needed is a small water tight enclosure for the arduino, ideas? Are you just following this thread or have you actually built one too?
Yes, I found many. Little box, two screws in the top with rubber gasket. I'd probably drill and silicone the through the side. Maybe... MAYBE use a grommet and make it look good.
Something like this:
https://www.makexyz.com/3d-models/order/9508558ffb033561b1bae6dedb56658a
fbi is offline   Reply With Quote
Old 01-15-2019, 10:03 PM   #227
Stija
Member#: 492861
18 WRX Stg 2 tuned
That looks good, although Iíd change it a bit and have only one hole with a grommet.
I was thinking Velcro and attach it to top or side of fuse box?
Stija is offline   Reply With Quote
Old 01-16-2019, 10:33 PM   #228
Stija
Member#: 492861
18 WRX Stg 2 tuned
We’re getting there..
I ordered wrong oxygen connectors so this will be tested by manually connecting it to battery with car running. If it works, I will order proper connectors for a plug and play application. Waiting on fuel lines and then testing some time next week.
Old 01-18-2019, 11:57 AM   #229
Stija
Member#: 492861
18 WRX Stg 2 tuned
Fuel lines readily available at Oreillys for 15$ with tax included for a pack of 5, 6.99$ for a pack of 2. That is if you want to use nylon lines 3/8”.
Can someone post or help with correct oxygen sensor connectors, both sides. The ones posted before will NOT plug into our oem MY15+ OEM connectors for a true plug and play application. But they will work for any application where one is not running their oxygen sensor and can sacrifice cutting one of their oem connectors, like OP did, if that makes sense.
Old 01-18-2019, 07:01 PM   #230
Stija
Member#: 492861
18 WRX Stg 2 tuned
So had a chance to try it out today. Found out I also have wrong fuel connectors. The sensor is 3/8” steel and the car is 5/16” steel. Didn’t work.
Ordered dorman 800-119 and 800-092.5 (box of five). These will work for MY15+ application on the CAR side. Sensor side requires previously referenced dorman quick connectors.
Took me all 15 min to install it first time and 5 to get it back to oem.
ADDENDUM: I went with 5/16 lines and corresponding connectors except for ones that connect to the flex sensor because those have to be 3/8 steel line to 5/16 barb for nylon hose. Oem is 5/16 so I figure I would like to keep it oem and also avoid any potential issues with the flow because of going from 5/16 to 3/8 then back to 5/16 two feet later.
Old 01-19-2019, 12:14 PM   #231
Stija
Member#: 492861
18 WRX Stg 2 tuned
I just tested mine with 3/8” cuz I had to find out whether it would work and it did.
I’m getting a 0.80-0.82v reading on my left tgv and also two codes, most likely due to the signal going into the tgv. Gonna return car to normal and off to work.
It works!
Old 01-19-2019, 03:36 PM   #232
Stija
Member#: 492861
18 WRX Stg 2 tuned
I canít believe Iím the only one getting excited about this, it works I said. There is 7.5% ethanol in my Costco 91oct.
Next up making it all pretty and using oxygen connectors for a power source. Also I should test the fuel somehow to make sure itís reading correctly or calibrate it.
Old 01-19-2019, 03:52 PM   #233
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
yep we know it works, many have benefited from this
Totally understand the excitement!
ShinjiML is online now   Reply With Quote
Old 01-19-2019, 04:23 PM   #234
Stija
Member#: 492861
18 WRX Stg 2 tuned
So psyched, can hardly contain it.
Has it been reliable? How has the arduino coped with engine heat? I mean I have 4 extra...
Old 01-22-2019, 01:00 PM   #235
Stija
Member#: 492861
18 WRX Stg 2 tuned
Conn-85988 is the proper extension for (MY15+ WRX) a plug and play flex fuel system at Ballenger motor sports, for anyone hunting connectors down.
Old 02-09-2019, 06:49 PM   #236
mxm64
Member#: 464557
Arduino Flex Fuel Kit Installed Today on my 17 WRX. Many thanks to Stija for the 15+WRX connectors and fuel line part numbers. Now need to get a E30 tune![IMG]
mxm64 is online now   Reply With Quote
Old 02-09-2019, 06:54 PM   #237
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
Very nice looking!
Old 02-17-2019, 08:29 PM   #238
brecks
Member#: 435142
2004 STi
Java Black Pearl
Iíve had mine going for about 8 months now, no issues. Protuned as well, no issues there either. I mounted my box up under the dash in the drivers foot well, so I canít speak to it withstanding engine heat. As long as you have it mounted somewhere out of the way you should be fine!
brecks is offline   Reply With Quote
Old 02-19-2019, 03:10 PM   #239
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
One of these days I'll have to get into Arduinos and try this out for my old 16-bit ECU.
Old 02-19-2019, 03:32 PM   #240
fbi
Member#: 236464
2005 Forester XT
Blue Regal Pearl
I bought knock off / rebranded Arduino Nano. It's not plugged into the car yet, but everything seems to be working fine.
Old 03-07-2019, 10:52 PM   #241
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
So I got my arduino all set up and ready to go for the most part. But I'm having some trouble deciding on the length of the wire leads. Did you guess and cut the wires to a decided length? Did you crawl under the car plug everything in then cut the wires to length before soldering them to the arduino. Anyone have the lengths they chose for each lead?
HyperBSTI is offline   Reply With Quote
Old 03-07-2019, 11:19 PM   #242
Bowezz84
Member#: 498759
2018 WRX Premium
Default List
Fuel lines readily available at Oreillys for 15$ with tax included for a pack of 5, 6.99$ for a pack of 2. That is if you want to use nylon lines 3/8Ē.
Can u send me a list of everything you are using?
Bowezz84 is offline   Reply With Quote
Old 03-07-2019, 11:21 PM   #243
Bowezz84
Member#: 498759
2018 WRX Premium
Where did u get all your parts!
Old 03-08-2019, 08:09 AM   #244
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
-Got arduinos, resistors & regulator from Amazon.
-Connectors from Bmotorsports per the first post.
-Got the GM Flexfuel connector from Amazon. Skipping the modification to the sensor to use the delphi connector.
Also got the enclosure and wire sheathing from Amazon.
If you need specifics I can dig them out. I just need wire lengths to finish it up. Was kinda hoping not to go crawl under my car with the freezing temps.
Old 03-08-2019, 08:40 AM   #245
Bowezz84
Member#: 498759
2018 WRX Premium
That would be awesome if itís not to much trouble. Are u doing a straight plug and play like Cobb setup?
Old 03-08-2019, 08:44 AM   #246
Bowezz84
Member#: 498759
2018 WRX Premium
Also do u have the part number of the enclosure and wire sheathing u used?
Old 03-08-2019, 09:33 AM   #247
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
ELEGOO for Arduino Nano V3.0, Nano Board CH340/ATmega328P Without USB Cable, Compatible with Arduino Nano V3.0 (Nano x 3 Without Cable)
Flex Fuel Composition Sensor E85 13577429 for 12-13 GM Impala
NTE Electronics HW233 Metal Film Flameproof Resistor, 1/2W, 2% Tolerance, Axial Lead, 3.3K Ohm (Pack of 6)
NTE Electronics NTE964 Integrated Circuit 3ĖTerminal Positive Voltage Regulator, TO-220 Package, 1 Amp Output Current in Excess, 8V Output Voltage
NTE Electronics HW247 Metal Film Flameproof Resistor, 1/2W, 2% Tolerance, Axial Lead, 4.7K Ohm (Pack of 6)
Boost Monkey E85 Flex Fuel Sensor Connector Pigtail Plastic Body Flex Fuel Composition Ethanol for GM (Connector only)
25ft - 1/4 inch Flexo PET Expandable Braided Sleeving
Eightwood Extruded Aluminum Box Electronic Project Enclosure Case DIY Box- 1.97"x0.98"x0.98" (LWH)
As far as the TGV and O2 sensors go look at the connectors linked on the first post. I pretty much followed his word for word as far as components go. The only thing I did differently is I bought the O2 sensor extension. It has both plug ends and 12" of wire between them already. I will be splicing my wires into the power and ground wires of that extension. Depending on whether you have a EJ25 or a FA20 your connectors may be different as well.
Also I just want to note that I have no guarantee that these components will work. I have the arduino sketch loaded but have not been able to test the system so purchase this stuff at your own risk.
Old 03-11-2019, 04:07 PM   #248
Bowezz84
Member#: 498759
2018 WRX Premium
Got it... when will you test it out?
Old 03-13-2019, 07:22 AM   #249
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
I dunno right now. Been really busy installing the AOS and a new inlet because I broke the crank vent nipple off the oem one. Plus getting everything else ready for my protune.
Old 03-13-2019, 09:57 AM   #250
redrexmeister
Member#: 111692
04 WRX wagonette
SRR
Just found this thread, quite awesome to see this DIY option. i am strongly considering to try it out.
I have a question about tuning with this setup. Is it fully equivalent to Cobb FF kit? In other words, if I communicate with a tuner do I just say that my car has XYZ mods plus a Cobb Flex Fuel kit?
or do I need to offer any specific details about this set up as an equivalent to Cobb's kit?
What company or tuner do you use for tuning your cars with FF kit?
redrexmeister is offline   Reply With Quote
