Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 11-27-2018, 10:07 AM   #51
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
No love on those images. I'm curious to see what you did. Also, what's your strategy for the old positive terminal?
JourdanWithaU is offline   Reply With Quote
Old 11-27-2018, 10:45 AM   #52
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Not working for you? They show up on my browser but I'm using google chrome and hosting with google photos.
I'll be completely eliminating the original wiring and running an insulated bulkhead stud on the firewall. So the positive will go from the battery to the cabin side of the stud, then from the engine bay side of the stud to the starter, alternator and fuse box.
Turpid Porpoise is offline   Reply With Quote
Old 11-27-2018, 10:54 AM   #53
Calamarii
Member#: 492826
2000 Impreza L Wagon
BRP
Yeah not seeing those last few either. Seen the same image error a few times today, something with the image hosting must have changed recently.
Calamarii is offline   Reply With Quote
Old 11-27-2018, 10:55 AM   #54
Turpid Porpoise
Member#: 476573
Ever since photobucket became image hosting has been a crap shoot.
Old 11-28-2018, 12:37 AM   #55
PDXREALTOR
Member#: 468393
2017 STI
All you latest pics are showing up broken in the nasioc app fyi.
Nice manifold! What color are you going to have it coated?
PDXREALTOR is offline   Reply With Quote
Old 11-28-2018, 06:08 AM   #56
Turpid Porpoise
Member#: 476573
I did all my IC piping in a brighter than stock wrinkle red, Im in between that or satin black.
Old 11-28-2018, 09:04 PM   #57
PDXREALTOR
Member#: 468393
2017 STI
Match the manifold to the pipes, black silicone couplers and throttle body. JMO - and I've looked at what feels like over 1k under hood setups in the last week.
Old 11-29-2018, 06:00 AM   #58
Turpid Porpoise
Member#: 476573
Thats the direction I was leaning but I didnt want to overwhelm the bay with the same color.
Old 11-29-2018, 09:04 AM   #59
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Your last major picture post is showing no pictures loading *sad*.
Btw, something I don't think has been asked but is relevant for a DD: how is the gas mileage? Obviously you're not getting mid 20's making that kind of power, but what are you getting on average pump to pump?
SirBrass is offline   Reply With Quote
Old 11-29-2018, 09:06 AM   #60
Turpid Porpoise
Member#: 476573
I was seeing about 19.5mpg while I was daily driving it and tracking it. I reset my trip meters for every oil change so it should be fairly accurate.
Old 11-30-2018, 07:57 AM   #61
Turpid Porpoise
Member#: 476573
I tried reposting those pics elsewhere, can you see them now?
Old 12-01-2018, 02:42 AM   #62
PDXREALTOR
Member#: 468393
2017 STI
The only pics that are showing up broken are post 7 and 15. All other pics work, unless they simply aren't there at all. I tested them in IE and Chrome.
Old 12-03-2018, 09:33 AM   #63
Turpid Porpoise
Member#: 476573
Somewhat large surprise update coming later this week but for now I have completed fabbing the battery mount plate and I'm just waiting on some countersunk hardware to mount the tie down to the plate and then I'll drop it all off for powder before I start the wiring side of things.
I made two more mounting points using the factory car seat tether locations inside the hatch to make sure this thing never budges in the event of a crash. The last thing I want is this 30# sheet of steel and the 35# battery flying at the back of my head.
Old 12-03-2018, 01:01 PM   #64
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Pictures on Post 50 work. I don't see the pictures on Post 63 though.
That's a big box for the battery.
Old 12-03-2018, 01:33 PM   #65
Turpid Porpoise
Member#: 476573
I'll rehost the ones in post 63 elsewhere, I've had it with Google photo.
I'm just going overboard to ensure that I am SCCA/NASA legal and don't have to drive home to fix something after my first tech inspection. I shouldn't need the box since it is an AGM battery but I'd rather be safe than sorry.
Old 12-03-2018, 02:09 PM   #66
Turpid Porpoise
Member#: 476573
Updated posts 7 and 63 with images hosted in alternate web page so hopefully those pics are visible now.
Old 12-03-2018, 04:34 PM   #67
PDXREALTOR
Member#: 468393
2017 STI
Battery box is looking good. I like how secure it is.
Got me excited about your big news later this week.
Old 12-06-2018, 07:49 PM   #68
Turpid Porpoise
Member#: 476573
I'll make this one short and sweet.
Perrin Rotated "Tuner" Kit
GT3076R (I need to swap the turbine housing to a 3" GT 4 bolt .82)
Tial MVR 44mm
FIC1650 Injectors (to go with my flex fuel setup)
Old 12-06-2018, 08:30 PM   #69
PDXREALTOR
Member#: 468393
2017 STI
Nice! What do you think it will make... Ballpark?
Whats the tuner part all about?
Old 12-06-2018, 08:53 PM   #70
Turpid Porpoise
Member#: 476573
Im hoping for 450 on E85, the injectors may end up being tol big for the application but I got a great deal on them.
I think the tuner part just means it doesnt come with the turbo or wastegate, I had to buy those elsewhere. I got the perrin kit second hand and the turbo and wastegate used with very low miles so all in all Iíve spent less than $1800.
Old 01-15-2019, 07:33 AM   #71
Turpid Porpoise
Member#: 476573
Been a little while, still waiting to get my longblock back from IAG but I think I'm about 2 months away from that day.
I've made a bunch of progress on the intake manifold; I welded a bracket to the back of it to mount my radium FPR, I tapped two holes under the TB for 1/8 NPT fittings and I will be running my IAT sensor in the OEM PCV hole. I also welded the brake booster and boost gauge nipples shut and grounds them smooth. After all of that I started polishing the runners; no porting, just a clean up of the internal casting marks with some flapwheels. I also drilled and tapped one of the threaded bosses on the underside of the manifold for my new brake booster line.
Old 01-16-2019, 08:13 AM   #72
Turpid Porpoise
Member#: 476573
Here is the finished product with the return lines plumbed in.
Old 01-16-2019, 09:37 AM   #73
zugu
Member#: 77863
2013 WRX
I'm hoping for 450 on E85....
Question: Wouldn't the Blue have made that on E considering it did 400 on 93?
PS - Pics in post #72 don't work.
zugu is offline   Reply With Quote
Old 01-16-2019, 10:09 AM   #74
Turpid Porpoise
Member#: 476573
Yes it probably would have made 450 on E but I have never been a fan of OEM location turbos due to the restrictions on inlet sizing, spacing for oil lines, routing of charge piping and the fact that you are limited to fairly small turbine housings which can really push the powerband further to the right once you start going bigger. The GTX3076R is also ball bearing where the Blue was journal bearing and it gives me the ability to pick from just about any T3 snail I want in the future if I decide I want more.
I'll rehost those pictures elsewhere and try again.
Old 01-16-2019, 01:11 PM   #75
PDXREALTOR
Member#: 468393
2017 STI
Radium is so sexy. Do you plan to monitor fuel pressure on the access port also?
