Welcome to the North American Subaru Impreza Owners Club Sunday March 24, 2019
Old 01-30-2019, 06:08 PM   #1
WhiteZombie
Member#: 338863
2005 WRX Wagon
Platinum Silver Metallic
Default Best value radiator that just might see some HPDE action?
Hey everyone,
My stock radiator sprung a leak recently and need to replace ASAP.
I mayyyyyy possibly do some open track HPDE and/or autocross in my WRX wagon, but mostly just daily duty and twisty touge runs. I already have a dedicated track car, so if it's only a few more bucks for a more efficient radiator that would perform better at the track, I'm about it, you know, just in case.
I had a very strong recommendation from someone that was Koyo or Mishimoto, but can't remember which one was good and which he said was not good.
Thoughts? Are those overkill for a stock thermostat car that may never actually see a 20-30 minute session?
Thanks!
WhiteZombie is offline   Reply With Quote
Old 01-30-2019, 07:08 PM   #2
kwiksti
Member#: 480195
2014 STI Hatch
Can't go wrong with either Koyo or Mishi. The latter does have lifetime warranty if I recall. I would def upgrade if you have to replace a leaking OEM. Why not?
kwiksti is offline   Reply With Quote
Old 01-31-2019, 07:42 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I'd recommend Koyo over Mishimoto.
I had a brand new Mishimoto radiator leak. Tiny hole/gap in the weld. Switched to a Koyo and no problems at all.
Old 01-31-2019, 10:19 AM   #4
Kostamojen
Member#: 2272
2018 Type-RA 196/500
1999 OBS Camo Wagon
Go with Koyo.
Old 01-31-2019, 12:51 PM   #5
WhiteZombie
Member#: 338863
2005 WRX Wagon
Go with Koyo.
Thanks! Pretty sure it was Koyo that was strongly recommended to me over the Mishimoto.
Dialed fitment on the Koyo? No special mods needed? I've read may have to trim the upper rad hose a bit, only because it's thicker overall?
Have you guys seen any appreciable decrease in coolant/oil temps on track between a stock and Koyo, all else being equal?
Old 01-31-2019, 02:16 PM   #6
jamal
Member#: 71875
Generally with any aftermarket radiator you'll want to make sure there's sufficient clearance between the upper hose, fans, and p/s pulley. So yes maybe a little trimming, especially for driving on track. Stiffer drivetrain mounts, especially a pitch stop, also help.
Also the koyo vh does use a higher quality core that is a little thinner than the old version and mishimotos which will improve clearance to the fans.
jamal is online now   Reply With Quote
Old 02-01-2019, 12:01 PM   #7
WhiteZombie
Member#: 338863
2005 WRX Wagon
Thanks everybody!
A buddy hooked me up with a Koyo, out for delivery today. Hopefully the UPS driver leaves it on the stoop with nobody home......
Old 02-02-2019, 10:26 AM   #8
WRXnick16
Member#: 447898
2019 STI
Crystal White Pearl
Good choice. I've had both and the Koyo was definitely better quality and fitment.
WRXnick16 is offline   Reply With Quote
Old 02-04-2019, 10:26 AM   #9
WhiteZombie
Member#: 338863
2005 WRX Wagon
Radiator and thermostat install went well, but unfortunately it turns out the water pump is completely locked up, causing my overheating issue. Timing belt just slips across the WP pulley! Luckily head gasket gas tester still shows no exhaust in coolant. Going to be doing the timing belt/water pump kit about 10k early, but could be worse!
Old 02-12-2019, 08:19 PM   #10
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Koyo!
-mike
Paisan is offline   Reply With Quote
