Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 10-06-2010, 01:07 AM   #1
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Default 800+whp and 9's here we come! The BFB
Well I figured it is about time I make a thread about my build I started a month or so ago. My block and heads are currently down at the machine shop awaiting sleeves along with p+p/valve work.
Parts list is as follows:
BLOCK/BOTTOM END
-ej257 block
-AEBS sleeves- o ringed
-custom ross 10:1 pistons
-Carillo H-beam 3/8" carr rods
-ACL race bearings
-Manley crank (v2 79mm stroke)
-ARP case bolts
HEADS/TOP END
-ej257 heads
-ported polished
-+1mm supertech intake valves
-+1mm supertech exhaust valves (inconel coating)
-Supertech dual valve springs
-GSC S3 cams
-P+L motorsports modified oil pump
-Killer Bee oil pick up
-Killer Bee oil pan
-Cosworth oil baffle
-JC Fab custom turbo kit.
-Exedy tripple plate clutch
-AEM ems
-FIC 2150 injectors
-DSS level 5 rear axle kit
-DSS front axle bar upgrade
-Turbo smart e-boost2 boost controller
-JC Fab double pumper
-Torque Solutions motor and tranny mounts
-Beatrush rear diff mount
[color=black]Im sure I am leaving stuff out but if i remember something ill update it. In the mean time
osirissirhc is offline   Reply With Quote
Old 10-06-2010, 02:38 AM   #2
king01
Member#: 178271
1999 Legacy GT
Red
Do you have a local tuning this?
king01 is offline   Reply With Quote
Old 10-06-2010, 02:52 AM   #3
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
yes local tuner
Old 10-06-2010, 04:32 AM   #4
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Nice goodies.
Old 10-06-2010, 12:25 PM   #5
king01
Member#: 178271
1999 Legacy GT
Red
May I ask who locally is doing the tuning?
Old 10-06-2010, 12:37 PM   #6
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Will @ Elevated Tuning
Old 10-08-2010, 11:00 AM   #7
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
This is going to be the real deal. There are a few parts on there we haven't disclosed yet. It should hoot and scoot.
E85+10:1+45psi=
project_skyline is offline   Reply With Quote
Old 10-08-2010, 11:29 AM   #8
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
You will at least a 6765 or a very light car with a 6262, how high are you planing to rev? Long ratio 6 speed or 5 speed?
Good luck in your quest
Old 10-08-2010, 12:26 PM   #9
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Turbos he is looking at are HTA86, HTA3794, PTE 6765. Revs 8.5-9k and probably end up doing a 5 speed dogbox or long ratio 6 speed.
And yes we will be doing some significant weight reduction. lol
Old 10-08-2010, 02:01 PM   #10
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Im looking into getting cf decklid, doors, roof and fenders, will be removing almost everything from the interior on my first few runs. Also looking into swaping out some stuff under the car for lighter products. I'll post up pictures as work get done on the block and heads.
Old 01-27-2011, 02:31 PM   #11
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Block has finished being sleeved
Old 01-27-2011, 02:33 PM   #12
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
are those AEBS?
cnstman is offline   Reply With Quote
Old 01-27-2011, 02:35 PM   #13
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Indeed they are.
Old 01-27-2011, 08:22 PM   #14
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
E85+10:1+45psi=
45 psi!!!
binjoau is offline   Reply With Quote
Old 01-27-2011, 08:51 PM   #15
MartinSTi05
Member#: 145145
2006 wrx STi
45 PSI, may I suggest o-rings and larger head studs, lol
MartinSTi05 is offline   Reply With Quote
Old 01-27-2011, 09:09 PM   #16
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Oh dont your worry I have it under controll.
Old 01-27-2011, 09:20 PM   #17
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Very nice list.
It's weird we have almost idential builds but im in a 2000 rs instead.
This is all on a 05 sti huh?
Only difference is that my 6765 is mounted in my grill.
mtcs is offline   Reply With Quote
Old 01-27-2011, 09:36 PM   #18
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Correct this is all in my 05' STi. I was looking into a possible front mount turbo set up but am still undecided on turbo set up.
Old 01-27-2011, 09:40 PM   #19
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Could always go rotated 6765 w/ an AWIC setup. Would be pretty intense. I almost did it.
Old 01-27-2011, 09:48 PM   #20
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Are you running the L19 head studs on your set up?
Old 01-27-2011, 10:23 PM   #21
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Hell yeah. I sold my old std ARPs a few months ago.
Old 01-28-2011, 12:37 AM   #22
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
O-rings going in on the sleeves.
Maybe HTA3794 T4 TS???
Old 01-28-2011, 10:51 AM   #23
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
so what are you doing for the o-ringing (method) and what size headstuds are you using? Just going standard 11mm but L19?
Old 01-28-2011, 12:41 PM   #24
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
.040 copper wire cut into sleeve flange, and L19s.
Old 01-28-2011, 12:47 PM   #25
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
nice pics and GL with build.
