Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 09-09-2019, 09:52 PM   #1
Joey118
Member#: 399260
Default Mild bucking after fueling up
So just like the title says Iíve been experiencing mild bucking immediately after fueling up my car. It usually lasts less than 3-5 minutes and only on acceleration. My car has a new fuel filter, new spark plugs and everything else is new or at least in good shape and I have no check engine light. Iíve ran here through it several time over the last few months with no luck. It also happens no matter what gas station I use so itís not the fuel. Any thoughts?
Joey118 is offline   Reply With Quote
Old 09-13-2019, 09:06 PM   #2
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Do you stop refueling when the pump automatically stops? or do you keep going and going until it overflows?
tipsymechanic is offline   Reply With Quote
Old 09-17-2019, 03:04 AM   #3
Joey118
Member#: 399260
Well, I wouldnít say it overflows but I do top it off a tad.
Old 09-17-2019, 09:39 AM   #4
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
That happened on my 07 wrx. Turns out one of the solenoids in the fuel system was stuck open...
SnowWhite07 is offline   Reply With Quote
Old 09-22-2019, 03:24 PM   #5
ctimpreza96
Member#: 506661
Does this only happen when it is filled to a full tank or anytime new gas is added to the tank?
ctimpreza96 is offline   Reply With Quote
Old 09-22-2019, 03:32 PM   #6
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Sounds like an evap system issue, could be raw fuel being sucked through the purge solenoid up front. I'm not sure it can be caused by topping it off, but still wouldn't do that either way. Some of these cars have an issue with the charcoal canister bits being sucked up front and making the purge solenoid stick. If it can't close completely and you are forcing extra fuel in, it's possible raw fuel is making it to the engine through that solenoid. Even if the solenoid isn't clogged, it does open on its own for evap functions.
Old 09-22-2019, 07:24 PM   #7
Joey118
Member#: 399260
When I refuel from empty my car almost always fills up with about 12.2 gallons. This past time I stopped it just a little bit early at 12 gallons even and I didnít notice any issues. Should I get this issue looked at and possibly fixed or can I get by with simply not topping it off anymore?
