Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 03-13-2019, 11:42 AM   #51
Svobatron
Member#: 464986
2013 WRX
Satin White Pearl
Originally Posted by Womanjuice View Post
So if I spun a bearing and didn't tow it to a dealership first then afterwards tow it to my independent repair shop I'm SOL?
I knew what it was when it happened and wasn't going to drive it to cause further damage and definitely wasn't going to the stealership when out of warranty.
UPDATE: I spoke with a Subaru rep when I called the hotline set up for this lawsuit. She recommended gathering all my documentation and submitting a claim even if the car wasn't first presented to a dealership. She didn't have much further info but she did say that conversations through the hotline are added to each individual case. Just make sure to include the ticket # in your claim submittal so the reviewers have a good record of everything.
Good luck!
Svobatron is offline   Reply With Quote
Old 03-13-2019, 07:10 PM   #52
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
Originally Posted by scarab944 View Post
Got the letter as well. Looks like you fill out one form for reimbursement if you already got the repair done at an independent shop or sold/traded the car prior to repair. The other form is to exclude yourself from the class, in case you want to sue SOA on your own.
If I'm reading it correctly, they will reimburse you (subject to a cap) if you got it repaired at an independent facility, provided that you first brought it to a dealership and that dealership refused to perform the work at no cost.
If you want the extended warranty, looks like you don't have to do anything but continue to wait until SOA informs the dealership network. I called my local dealer last week and they had not heard of the extended warranty settlement yet. Guess I'll try again next month. Would be nice to have my car back within a year of it going down.
Thanks for the summary! I'm too busy to be sitting down reading legal docs so this helps immensely.
oichan is offline   Reply With Quote
Old 03-16-2019, 12:39 PM   #53
JJL330
Member#: 38672
2017 WRX STI
Lapis Blue Pearl
I received the documentation as well. Kind of alarming to me.
Is this issue rare or is there a good chance my car will run into this issue sometime in the future? I planned on using this car for as long as I can. I make sure my car gets all regularly scheduled maintenance done, keep car stock no mods, and only use 93 octane gas.
From my understanding after skimming through the papers all the cars in the given VIN range will automatically be given an extended 8yr/100k mi powertrain warranty once the settlement is officially approved sometime in May.
JJL330 is offline   Reply With Quote
Old 03-17-2019, 01:27 AM   #54
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
they have a website for the settlement
http://www.enginebearings.settlementclass.com
Looks like you can submit forms through May 22nd of this year. There is a fairness hearing in early June, and at some point after that the court will decide if they approve of things, or I guess if the fighting continues.
Old 03-18-2019, 03:01 PM   #55
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Stay off of the forums, honestly. The folks with the problems are always the most vocal. That doesn't mean that the failures don't happen, but it isn't going to help your anxiety at all to subject yourself to these threads.
Keep doing what you're doing; you're under warranty for a long time yet, and if you stick to the above, I don't think you'll have any issues with the dealership or SOA if you do need a repair.
P.S. Follow the maintenance regime recommended for "severe driving conditions" or whatever they call it in the manual. Basically change the oil and filter every 3,000 miles.
http://www.cars101.com/subaru/maintenance-2017.html
bicycle_wreck is offline   Reply With Quote
Old 06-17-2019, 11:16 AM   #56
Scargod
Member#: 260314
2007 STI
silver gray metallic
Is there really anything wrong with the connecting rods? If you came across a rod how would you identify it?
Scargod is offline   Reply With Quote
Old 06-17-2019, 12:39 PM   #57
scarab944
Member#: 114817
Quick update on this.
My car has been at the dealership since early April and they are fixing it under the extended warranty provided by the terms of the lawsuit settlement. This was after I had to authorize up to $1000 in diagnostic charges, since they had to take the engine apart to determine if it was truly bearing failer.
Thankfully, that was the case. However, now the dealership is saying that while they're fixing the bearing issue, I need to cough up $1650 for a new turbo. They claim that metal filings got in there, clogged the oil lines, and now the turbo's junk.
What do you think? Sounds like BS to me, since I thought the oil filter would have caught that. At any rate, it was due to the bearing failure, so sounds like they *should* cover it. The car was around 400 miles from the last oil change (performed by the same dealership) when it failed.
How are the rest of y'all fairing with this?
scarab944 is offline   Reply With Quote
Old 06-17-2019, 12:49 PM   #58
heavyD
Member#: 194216
2018 M2 LCI
You can't be serious? The filings that damaged the turbocharger are due to a manufacturing issue they have acknowledged so I can't understand how they can justify passing off the cost to the consumer. I would fight that tooth and nail. Talk to SOA as your dealer sound like a clown show.
heavyD is offline   Reply With Quote
Old 06-17-2019, 01:54 PM   #59
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
That is correct that the turbo should be replaced under those circumstances. But I don't see why you should be paying for it.
Old 06-18-2019, 08:05 PM   #60
Abismo
Member#: 99707
2018 WRX Premium CWP
The failure caused your turbo to eat itself, you arnt responsible at all.
Abismo is offline   Reply With Quote
Old 08-23-2019, 04:43 PM   #61
scarab944
Member#: 114817
Update: Happy ending.
Got my car back this week (after 13 months down) and didn't have to pay a dime for the repair (we'll disregard the towing costs and using another car for over a year). SOA claims dept agreed that the turbo ate itself because of the bearings, so I have new engine and hopefully better luck with this one. Break-in time!
Old 08-23-2019, 08:30 PM   #62
Bitmanglr
Member#: 505600
So, after reading through a bunch of posts and the legal docs, am I correct that my 2012 Base (103k miles) that coughed up a rod bearing last week would not be reimbursable by SOA?
Bitmanglr is offline   Reply With Quote
Old 08-23-2019, 08:38 PM   #63
JP Chestnut
Member#: 504432
Not having a car for 13 months is total bull****. I'm glad you got it fixed but I would have expected better.
JP Chestnut is offline   Reply With Quote
Old 08-25-2019, 02:52 PM   #64
Kottonwood
Member#: 505652
I don't think I'll benefit from this but it's good news anyways. Had to raise my engine a at just over 100k. Stock, driven nicely, well maintained... wasn't happy... kinda stoked to have a brandy new motor now though
Kottonwood is offline   Reply With Quote
Old 09-13-2019, 06:33 PM   #65
Svobatron
Member#: 464986
2013 WRX
Satin White Pearl
Default Settlement decision came in
Well I got my letter today from SOA and as I expected my claim was denied for not first presenting the car to a Subaru dealership. I am going to write an appeal for a second shot but don't expect anything to change.
Oh well.
Old 09-16-2019, 10:05 PM   #66
WRX4US
Member#: 162846
Has anyone else recently received correspondence from Subaru regarding this matter?
WRX4US is offline   Reply With Quote
Old 09-17-2019, 11:02 AM   #67
bizzlezx10r
Member#: 439586
2015 WRX
ISM
I bought my 2015 WRX from Carmax last year, shouldn't I of gotten some sort of letter or is this only for people who bought directly from Subaru?
I remember getting something for my 2002 Protege when there was a recall and i bought it 2nd (Or probably 4th hand)
Also to add, for people that have had their issues addressed, did you have any modifications? My car is fully stock but i have an AP with the Stage 1 91oct OTS tune just to get rid of the dreaded rev hang. I haven't shown any signs of the issue but i'm worried for months or a year down the road.
bizzlezx10r is offline   Reply With Quote
Old 09-17-2019, 11:13 AM   #68
Sid03SVT
Member#: 183032
OLD Family Wagon
You have an FA20 not an EJ25X; different engine series.
The lawsuit affects 2012-2014 WRX and 2012-current WRX STI's.
Sid03SVT is offline   Reply With Quote
Old 09-17-2019, 11:52 AM   #69
bizzlezx10r
Member#: 439586
2015 WRX
ISM
Everywhere i read shows both the WRX and STI. Perhaps you can point me in the right direction for more info on it? Because what i found doesn't mention the motor series.
Old 09-17-2019, 11:57 AM   #70
Bansheeboy11
Member#: 182415
1999 RS
The model year cutoff for WRX's is 2014.
Bansheeboy11 is offline   Reply With Quote
Old 09-17-2019, 12:07 PM   #71
Sid03SVT
Member#: 183032
OLD Family Wagon
Everything I've read (including the press release at the beginning of this thread) specifically notes models with the EJ; affected models are:
WRX 2012-2014
WRX STi 2012-2017 (EJ is still in the current model as I mentioned earlier)
Go to post one on page one and follow links for more info.
Old 09-17-2019, 12:53 PM   #72
bizzlezx10r
Member#: 439586
2015 WRX
ISM
WRX 2012-2014
Thanks for the guidance man. However on the same website there is another entry that states the FA20 is also effected.
https://www.carcomplaints.com/news/2...-lawsuit.shtml
"The proposed class-action lawsuit includes all current and former owners and lessees of about 250,000 model year 2009-2018 Subaru Impreza WRX and WRX STI vehicles and who lost money or vehicle values due to the alleged piston ringland problems.
Subaru allegedly knew WRX and WRX STI components were defective in engines coded EJ255, EJ257 and FA20. The plaintiffs say engines should last at least 120,000 miles but the Subaru engines may last just half that time before they fail."
not trying to give anybody a hard time btw just want to make sure I/Others are informed.
Edit: Just noticed it's for Ringland issues which would be different than Rod and Bearing issues..
Old 10-16-2019, 02:43 PM   #73
tricoastaljs
Member#: 507459
Default my experience re: rod bearing extended warranty
This is a first post for me, please bear with me!
I am in the middle of the coverage process right now, and so far so good. Here's some background for what you can expect if you have the issue.
tl/dr: the response is ok, but it makes sense to be involved with all of the decisions the dealer/your mechanic makes in replacing components. Request that all components that may be affected be inspected for damage related to the rod issue. Make sure that you advocate for yourself throughout the process and ask probing questions when you have doubts.
My 2011-14 WRX got the rod knock somewhere around 70,000. I bought the car used at around 64K miles. I am the second owner. The service records showed that the transmission was replaced under warranty. I purchased the WRX AFTER the settlement was handed down to ensure that this issue would be covered. However, I still had doubts about how sincere SOA would be in covering the repairs in the event it happened.
I had the car towed in and paid out of pocket for the tow. SOA is going to reimburse me for the tow.
I currently do not have a SOA extended warranty, but I do have a third party warranty that is probably just a waste of money. So I was concerned whether the new engine would have a separate warranty from SOA. I learned that engine replacements have warranties ONLY for the parts that were replaced.
New replacement components have a 1 year warranty; unlimited miles;
Re manufactured components have a 3 year warranty or 36K miles, whatever comes first.
The reman engine replacement looks like the better deal. Although we should rightly have suspicions about QC concerns in the long run. The SOA rep stated that only the "outer shell" would be remanufactured and the internals would be new. I pushed him on whether the outer shell meant the block and he didn't have an answer. This presents the question whether only the "outer shell" is covered for 3 years/36k miles or all of the components replaced. I will ask and get and update this thread.
My concern is that they do not replace other components that may have been damaged, such as the turbo, which may fail later. There are certain factual scenarios, such as the turbo failing later, that may not be covered by SOA. I can imagine that SOA will not cover replacing the turbo because: 1) the car is out of warranty and 2) the turbo's failure is not causally related to the rod bearing issue or separate recall. But, despite the issues I have to say that I'm pleasantly surprised at SOA's treatment of this issue.
tricoastaljs is offline   Reply With Quote
