Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 08-03-2018, 12:24 PM   #1
Gerald81
Member#: 34226
Default High fuel pressure on startup
Recently I installed a fuel pressure gauge and sensor in my fuel rail.
After the install, I noticed that everytime I started the engine, there would be a loud droning noise coming from the fuel pump. At the same time, the fuel pressure reading will be relatively high at 5 bar.
After about 25-30 seconds, the sound will cease and the fuel pressure reading will drop to 3.5 bar. It generally does not change much thereafter (unless I get into boost)
Video below for reference:
Anyone have any ideas or clues as to what could be causing this? Thanks!
Gerald81 is offline   Reply With Quote
Old 08-03-2018, 01:35 PM   #2
TDagen
Member#: 163648
2002 Resurrected WRX
Fuel pump controller runs at 100% on startup and then after a short period of time goes to 33%.
Old 08-03-2018, 07:48 PM   #3
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
That's normal. At key on the fuel pump runs at full speed for 3 seconds to build pressure. It's not until the car is started that the FPC controls pump speed from 33%=>66%=>100%
Old 08-03-2018, 08:23 PM   #4
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
What was said above as per fuel pump controller is accurate.
What I'm not sure is normal for the STi is your gauge reading. When you first cycle the key on but not starting, your fuel pump should run for a few seconds. Your fuel pressure will come up to the static pressure, which your gauge should read, ~43.5 psi/~3 bar. Then when the fuel pump stops priming, the pressure should drop slightly. When you start it, the gauge should read your static pressure less vacuum, which is usually around negative 5-8 psi/0.35-0.55 bar (aka vacuum). When you drive around and your a 0 vacuum and 0 pressure, the gauge should read static pressure. When under boost, your gauge should read static pressure plus boost (ie, if you only boosted to 7psi/0.5 bar, your fuel pressure gauge should read ~50.5psi/3.5bar). Your regulator, which is (should be) 1:1 rising rate, will adjust fuel pressure based on your boost and vacuum.
Either your sensor or gauge is doing some kind of calibration or something is a miss. I can't explain the noise, unless you have a noisy pump??? Is the boost reference to the fuel pressure regulator cracked or old? I honestly can't explain the noise you're experiencing.
What fuel pressure are you running (ie, stock)? Do you have an adjustable fuel pressure regulator?
viper_crazy is online now   Reply With Quote
Old 08-05-2018, 04:36 PM   #5
Csquared33
Member#: 198053
02 WRX Wagon
www.efilogics.com
Larger pump, stock regulator? Probably overrunning the stock regulator on startup when the FP duty is 100% if that is the case
Csquared33 is offline   Reply With Quote
