Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 09-16-2005, 08:06 PM   #1
Snoop
Member#: 20626
2002 WRX Wagon
Thumbs up Amsoil Severe Gear 75W90
I haven't read too much about this stuff on here yet, so wanted to post my findings. I just swapped out my tranny fluid again. As a history, I did this for the first time around 42.5k after getting some grinding into 3rd gear. I originally swapped with straight Valvoline 75W90 dino gear oil but the grinds didn't go away. I drained a little less than 1 Qt. of that and put in some Penzoil Synchromesh. That more less stopped my grinding, but I got worried about not having GL-5 rated fluid in there.
So yesterday, I drained the whole tranny again and this time refilled with Amsoil Severe Gear 75W90. It's GL-5 and MT-1 rated, so should be good enough rating wise for our trannys. I guess this stuff is supposed to be replacing the 2000 series Amsoil oil, but this stuff isn't blue like the 2000 stuff suppositively was (I never used it so can't confirm).
About 40-50 miles later and so far so good. No real physical difference in shifting performance. But there are still no grinds into 3rd. *crosses fingers* I only ended up putting in 3.2 quarts or so, so not all the old stuff got out. But there shouldn't be more than 0.1 qt of synchomesh in anymore, by my estimates.
I'll keep you posted if I experience anything bad with this stuff further down the road.
(I posted this originally in the Service/Maintenance forum. I meant to put it here. Sorry for the double post.)
Snoop is offline   Reply With Quote
FS DFW: 5 Quarts Amsoil Severe Gear 75w90 fastcb TXIC Private Classifieds 2 09-04-2009 03:45 PM
Can I use severe gear 75w90 amsoil in all my diffs and trans 06 STI? wrb2006sti Transmission (AT/MT) & Driveline 7 02-04-2008 05:06 AM
Amsoil SEVERE GEAR™ Synthetic Extreme Pressure (EP) Lubricant 75W-90 (SVG): Button Transmission (AT/MT) & Driveline 28 09-20-2006 02:24 PM
Amsoil Severe Gear 75W90 Snoop Service & Maintenance 4 09-17-2005 09:45 AM
amsoil sever gear lube 75w-90 trbowrx Transmission (AT/MT) & Driveline 24 04-24-2005 04:50 AM
