02-15-2008, 05:37 PM | #1 |
Member#: 35133
JDM STI V7 shortblock VS JDM STI V7 Spec C shortblock
Hi, does anybody know whats the difference between the normal JDM STI V7 shortblock and the V7 Spec C shortblock? are they identical or spec C is better in some ways? how can i tell if i have a Spec C block?
thanks for any inputs
02-15-2008, 05:57 PM | #2 |
Member#: 68059
Vehicle:2011 DGM WRX Hatch 304whp 04 wagon - sold |
the shortblocks are the same I believe.... spec c has better flowing heads
02-15-2008, 08:49 PM | #3 |
Member#: 152345
Vehicle:2000 R34 GTS-T sedan silver |
rumors have abounded that the spec c crank has been nitrated(cold treated to make itr stronger)
02-16-2008, 01:06 AM | #4 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
to my knowledge they are almost the same, but as you mentioned there might be a slight post processing to some of the internal parts such as nitriding.
I think the V7 Spec C has the same intake manifold as the V8 with no TGV parts. If all you are dealing with is the shortblock the standard V7 will take a hell of alot of power, more than most people will ever push through it. Even on broken subies in the US I bet a broken crank is pretty rare, usually its pistons or rods that break. |
02-16-2008, 02:56 AM | #5 |
Member#: 68602
Vehicle:02 STi Wagon |
V7 Spec C is essentially the same as a ver8 motor except with no twin-scroll system and with forged pistons instead of the hypercast ones they put in ver8s and newer. Same heads and cams as a ver8.
02-16-2008, 04:26 AM | #6 |
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
JDM black chrome hid vs jdm non hid. | D Money | Electrical & Lighting | 6 | 10-24-2008 11:09 PM |
JDM Sti 5 speed VS JDM Sti 6 speed | Ace009 | Transmission (AT/MT) & Driveline | 89 | 06-09-2007 03:26 AM |
STi carpet - USDM vs JDM (does it matter?) | KitchenerWRX | Newbies & FAQs | 2 | 10-21-2006 12:26 PM |
How much lower is JDM V7 spring vs. USDM STi or WRX spring | txl146 | Brakes, Steering & Suspension | 3 | 12-22-2005 07:19 PM |
jdm ver 7 tmic vs. usdm sti tmic | showcasewrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 05-09-2004 08:45 PM |
