#126 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
![]() Anyone think getting a Mech Diff will be better than the torsion Diff??? I personally think I can get to the gas quicker and brake later with a clutch type diff.. What do you guys think??
#127 |
Member#: 55936
Vehicle:04 WRX STi PSM |
![]() IMO, Torsens are better at getting into corners while clutch-types are better at getting out of them. Which you do want to see improved more?
#128 | |
Member#: 18148
Vehicle:'08 WRX Dark Gray |
![]() Quote:
Taking initial cost and ongoing maintenance concerns off the table, I'd choose an OS Giken diff over a Torsen every time for a no-compromise RWD autocross car. However, it's hard to not like the "install and forget" nature of a Torsen. I had a Torsen in my old XP Miata that survived 280WHP and 5 years of hard autocross use without a single failure, while the car fragged 3 transmissions and a couple halfshafts. -Steve |
#129 | |
Subtly Outspoken
![]() Quote:
Thanks Steve.. Interesting points. I am actually going to a Gaurd Transmission diff that setup on Ratio's vs. Percent.. Supposedly I can stay on the gas longer going into to corner.. and get to it quicker coming off, which means time.. Kinda trying a different approach on this one. As A Guard Transmission Diff is on its way with expert setup of Matt Monson.. I am looking forward to shaving some time. Hopefully that translates to me being a better/faster driver. ![]() ![]() Bill |
#130 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
![]() Max has made some comments on ft86club about his OS Giken. Now he is sponsored by them but he said he felt the car was a lot more stable under acceleration with it coming out of corners.
I'd probably use the OSG but definitely don't plan on doing it this year. |
#131 | |
Subtly Outspoken
![]() Quote:
Bill |
#132 |
Member#: 18148
![]() When properly tuned, a clutch-based diff definitely has some advantages on corner exit. Power application out of corners with a Torsen can be a bit abrupt. Another consideration that may not be an issue with the Twins is that Torsen diifs don't work right if one wheel is off the ground - so it's important to set your car up to keep the tires on the ground at corner exit.
#133 |
Subtly Outspoken
![]() ^^^^ agreed... Don't know of any lift on the 86's that I am aware of.. unless its a uneven contact patch on exit. but that will soon not be an issue either as the new diff goes in. I wonder how much suspension adj is going to have to be made with the new diff. None??? minimal??? Huge??? I expect some Rebound and Comp adj. just hope its not spring rates also..
Bill |
#134 |
Member#: 55936
![]() My comment was based on the fact that only a 1.0-way clutch-type can enter a corner like a helical can. The others will provide some resistance to differentiating on turn-in, the 2.0-way ones do this the most. IMO, the abrupt power delivery on exit also applies to the 1.0-way clutch paks, though I find the transition not quite as obvious as on helicals. I've had the best luck with 1.5-way clutch units but I also realize much of this is personal taste.
#135 | |
Member#: 18148
![]() Quote:
I expect you'll want to make some minor to moderate changes to take full advantage of the new diff. First, it's likely the car will understeer a bit more on corner entry, unless you're getting a true 1-way diff. Ideally, it would be nice if you could set the car up with enough rear brake bias to make trail braking effective, but I'm not sure how far your braking system will let you adjust bias, before the electronic nannies freak out. (I'll be experimenting with this same adjustment on the WRX this year). Second, assuming you have the clutches set up for progressive power delivery, the car should oversteer a bit less at corner exit. This may allow you set the car up a bit looser to deal with item #1. I'd be surprised if the change required major changes, but I've been wrong before. |
#136 |
Member#: 60566
SCIC
Vehicle:2005 XT 5sp, 02 WRX 01 Legacy 95 Impreza L |
![]() I'm thinking you'll end up messing with toe.
#137 |
Subtly Outspoken
![]() Thanks Steve and Greg...
Greg, how much are you thinking??? more in, I assume.. |
#138 |
Member#: 60566
SCIC
#139 |
Member#: 193756
NWIC
Vehicle:2005 LGT Wagon Silver |
![]() Just to satisfy my curiosity because I'm really considering giving up on the WRX. What's a better base to start a build, the FRS or BRZ?
#140 |
Member#: 198231
Vehicle:2007 Not a Subaru |
![]() FRS is a little tiny bit lighter and cheaper. I much prefer the BRZ styling so I would pick that if price was close enough used.
#141 |
Member#: 193756
NWIC
![]() Good to know. Not really a whole lot of used ones in my area... But this may be a post-Nationals decision...
#142 |
Member#: 8343
![]() Yeah the heaviest BRZ (Limited) is only 16lbs heavier than the base FR-S, so really it doesn't much matter, there is more variation in driver weight than that usually.
If you are looking new they are widely available now. In a month the car will have been available for two years but I know used ones are still not too easy to come by. |
#143 |
Subtly Outspoken
![]() Current Weight on my STX BRZ is 2575ish... Depending on gas.. and I have the limited. I have also done considerable upgrades to get it to that weight also. Danny Kao's and mine are VERY similar in Weight. he's down to 2550ish. so a 25lbs difference at the Full limit of the Rules...right now.
power is even on both platforms.. Subaru IMO has better amenities..with the Heated Seats, fogs. and alcantara suede. (since then I have replaced the driver seat with a fixed back raceseat). it really is a matter of preference. Used are Scarce still .. but pay attention to Danny Kao....as he or Annie could sell their STX Car at any given moment. Danny's is Ex-AndrewPalotta car.. and Annie's is on her 3rd 86.. sooo ![]() Bill |
#144 |
Member#: 193756
NWIC
![]() Which Annie are we talking about? Gill?
#145 |
Subtly Outspoken
#146 |
Member#: 193756
NWIC
#147 |
Member#: 295724
Vehicle:2022 WRX WRB |
![]() Did Holly sell her FRS or move to STX? I know she had her stock size wheels from last year for sale.
#148 |
Subtly Outspoken
#149 |
Member#: 295724
![]() Oh if all else fails I will likely see her at our first event at the airport. Just wondered since she was selling the CS wheel setup.
#150 |
Subtly Outspoken
![]() She's registered in a HS Mini Cooper for Wilmington..
co-driving with Tim Carrite.. Bill |
