04-14-2003, 11:23 AM | #1 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Any one have tips for doing an EJ20T swap?
Hi, I have anh 02 WRX engine with 11K on it. I am looking to install it mid June but was wondering if anyone had any tips for this installation. For example where to relocate the cruise control, or can I just connect my old AC lines up to the WRX unit? any tips are appreciated. I need the mechanical tips or ideas. I'm paying Ralli Spec to do the wiring.
Thanks, Micah
04-14-2003, 11:30 AM | #2 |
Member#: 33445
Vehicle:2005 Chevy Silverado Cherry Red |
Is this a direct bolt up? and does the tranny match, and what about the fuel pump, radiator and all that shtuff! And is that the 227 US spec or the 280 Jap spec. cause instead of turboing my EJ25 i think i might be getting a EJ20 Jap spec that comes out of the crate with 280.
04-14-2003, 05:35 PM | #3 |
Member#: 1503
South East
Vehicle:2012 2012 WRX Sedan Silver |
You have to swap your RS lines onto the WRX Compressor...Get rid of the Cruise Control all together...Get rid of your Airbag wiring...You have a complete clip right? Remove the whole chassis from the drivetrain, Remove your whole suspension, steering rack, crossmember, brakes, all that...And, drop your car right on top of the WRX drivetrain...Tighten up the strut towers, Control Arm Brackets, all that bolts onto your chassis...Thats the easiest way to get your drivetrain in...In other words, You are better off keeping the WRX swap together as one piece and dropping your car onto it...
How much did Rallispec charge for the wiring? Are you swapping just the motor or the full drivetrain? Zee |
04-14-2003, 06:32 PM | #4 |
Member#: 133
NWIC
Vehicle:TBA TBA TBA |
Like I said in the Mid-A, use on the EJ20 you can use the Ej25s A/C support bracket to mount the orignal A/C compressor to the EJ20 so there is no need to remove the stock stuff. Just leave it connected to the A/C lines and set the A/C compressor where the battery would normally be during the swap. I would have to assume the Ej18 bracket would be the same way. If the orignal motor had the cruise control then it will be as simple as just attaching your cruise control cable to the EJ20 throttle body. If you want to make it quick and easy I still say at least make an offer to TaiChih to see if he will cut you a deal on the install so that he helps/walks you through the install in his garage. That way you don't have the hassles. Just pull the motor from your car, put some support under the trans while you change the crossmember. Especially since your going to be using the 2.5RS stock transmission with the EJ20.
04-15-2003, 09:24 AM | #5 |
Member#: 33782
first thing first is all I have is a 94 L not an RS. All I have to seap is the motor not the complete drivetrain. I have my stock tranny which I would love to swap out but will have to wait for money. I don't have a front clip.
I've been told that Ralli Spec does electrical for $750. That's just wiring the harnesses. For now I'm using the L tranny (until it falls apart or I can buy an RS). I wasn't wondering to much about how to hook up the cruise control but where to locate it? For the plumbing of the Radiator and all...how many lines have to come off of the radiator for the WRX as apposed to the L? I would go to Taichih but I don't have the money plus I have friends who are experienced in swapping motors so we are going to be doing it. I'm just trying to gather to make an easier (lol) smoother swap. Thanks, Micah |
04-15-2003, 10:01 AM | #6 |
Member#: 133
NWIC
If all they've ever done is a Honda motor swap then they won't be much help to you. Also your L front cross member won't work with the EJ20 and its manifold. You said you only have the motor is why I mention it. All of the Subaru motors have the same mounting location for the A/C so you might only need to use your stock bracket on the EJ20 with the stock L A/C compressor.
04-15-2003, 11:25 AM | #7 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
micah .. you keep scaring me
your headded down a scary path my origional budget for my swap was 5k .. which ..now i know is way too low ..i am at $10k and still having substantial issues here is my current break down
04-15-2003, 10:18 PM | #8 |
Member#: 33782
I have the
motor down and up pipes exhaust manifold turbo choice of two intercoolers GFB BOV WRX crossmember choice of two turbos ECU harnesses clutch flywheel all of this was roughly 2600 shipped. my 94L w/ 4 wheel discs(identical to my frineds 01 RS) 1.8L (slow) basic 5spd has all options for 3100 total thus far $5700 wiring harness to be done for me = 1050 from ralli spec still looking around to see if anyone can beat that price!! new estimated total $6750 giving bumper of 1000 for unforseen costs. One of the friends doing the swap is a trained mechanic as is one of my dad's friends(who works for what the parts cost him and a 6 pack of good beer) replumbing and custom machined parts are no problem. I have access to those machines. excess money is left for radiator and replacement tranny for when the L's goes. |
04-15-2003, 10:23 PM | #9 |
Member#: 33782
sorry forgot to mention I already have
gauges grill for RS hood headlights for RS hood RS hood for only 160(shipped) need RS radiator top mount WRX radiator some hosing time I know I'm forgetting something |
04-15-2003, 10:46 PM | #10 |
Member#: 177
NWIC
the wiring part is probblay the hardest .. since mine is a project not transportation . i wil be doing it myself
1050 for wiring is a great deal... go for it if i had to do it again i woud buy a newer car and do a usdm wrx swap |
04-16-2003, 09:58 AM | #11 |
Member#: 733
Vehicle:'18 WRX Frozen White |
Micah - I thought you were selling the EJ20. Keeping it now???
-mykr. |
04-16-2003, 07:50 PM | #12 |
Member#: 11620
Vehicle:1997 GF4-STiV3 clone |
I don't think your 94L cruise will work with your WRX ECU. You will need the WRX cruise unit likely.
04-16-2003, 09:13 PM | #13 |
Member#: 1503
South East
$1050...That includes removal, splicing, and installation? Thats a great deal...I replaced all the wiring in my car...All of it!!!Got rid of SRS while I was at it...I'll take pics of all that was spliced so you can use that as a how-to...
My car is a 2000 RS though...But, I'll send pics so someone can put them on this site and everyone can do the wiring themselves... Just be aware that your entire car's interior will be removed if you do it my way...Everything but the headliner... Zee |
04-17-2003, 01:25 PM | #14 |
Member#: 33782
it's strictly matching the needed wires beteween the two harnesses and soldering. I'll be doing the removal of the L harness and then shipping the two harnesses to Ralli Spec.
Mykrr I thought I had told you. I thought that I had sent all potential buyers an email as to why I wasn't selling anymore. I send it to you. |
04-17-2003, 01:26 PM | #15 |
Member#: 33782
the cruise control unit I really don't care about. I don't use it much anyway. Although... it looks identical to my friends 01 RS c.c.
I don't know I'll ask some people who have done swaps. From what I've heard they just moved the unit and still had it working. |
04-18-2003, 12:25 AM | #16 |
Member#: 733
Huh...I never got the email Micah. Good luck w/the swap.
-mykr. |
04-18-2003, 12:40 PM | #17 |
Member#: 33782
thanks, sorry about the email... it's been screwy for a while now and it's making me mad.
Thanks anyway, Micah |
04-24-2003, 10:14 AM | #18 |
Member#: 23979
crossmember =P
ok guys, sorry this is a very very nubie question....
i was wondering wat is the crossmember of where is it? thanks kevin |
04-24-2003, 11:21 AM | #19 |
Member#: 33782
simply put... the crossmember is a big piece metal that is under the the tranny/engine that strengthens the front part of the chassis. Go under the motor swap section and look at the pictures. You can see the crossmember very well.
http://www.i-speedusa.com/home/ Hope this helps, Micah |
04-26-2003, 02:20 PM | #20 | |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
http://www.i-speedusa.com/images/wrx...ginebay_01.jpg Crossmember is that black plate thing extending from side to side. -paK +1 |
04-29-2003, 05:17 AM | #21 |
Member#: 15135
NWIC
Vehicle:95 GF WRX Black |
Sounds like you have the parts/skill to get the engine and exhaust swapped into the car. If I were in your shoes, I'd be far more concerned about a clean swap than if your cruise worked... Really, there's much more to that swap than you think. Have you looked at the wiring of the harness/ecu you are putting in vs. a USDM harness/ecu? They are different in several ways, that's why you can't just plug a JDM EJ20 ecu into a USDM car, the pinouts are completely different. At any rate, be more concerned about your car firing up/idling than cruise or A/C working, and be prepared to shell some more coin to make it happen. These things always cost more than you think.
Keep us posted on the progress. |
04-30-2003, 10:56 PM | #22 |
Member#: 33782
yeah I know all about the wiring. I've been studying all the info I can find on the swap and am paying Ralli Spec to do the wiring. I'm not going to get into that mess.
05-01-2003, 09:35 PM | #23 |
Member#: 188
Vehicle:2004 Forester XT 24k gold on white |
You might want to make sure you have front and rear O2 sensors if you plan to use the stock ECU.
nizz |
05-02-2003, 02:14 AM | #24 |
Member#: 188
There are a lot of other little things that add up like:
Getting your freon refilled - $80 May need new coolant, coolant lines/hoses - $50 May need new power steering line and reservoir - $250 May need alignment from x-member removal - $60 Just what I can recall off the top of my head... nizz Last edited by nizz; 05-02-2003 at 02:44 PM. |
05-03-2003, 11:08 AM | #25 |
Member#: 33782
I'm aware that some plumbing needs to be redone on this swap and have found out all kinds of info on the AC(trying to use the AC already on the 94). i have the O2 sensors from the 94 and the O2 sensors from uppipe and manifold. I have heard that you do and that you don't have to change the power steering stuff. So I don't know.
Thanks, Micah Still looking for tips. |
sold my fxt, any one have anything for sale | foresterated | RMIC Private Classifieds | 17 | 04-02-2009 01:41 AM |
any one have hookups for seaworld tickets? | hersheywrx | Southern California Impreza Club Forum -- SCIC | 1 | 07-24-2008 12:49 AM |
Any one have WHEELS for sale? | ChrisV-FL | Private 'For Sale' Classifieds | 3 | 03-12-2006 10:57 PM |
anyone have tips for doing touch ups myself | Fyxtion | Interior & Exterior Modification | 3 | 05-20-2002 12:48 PM |
doing an EJ25 swap into my 99 sportwagon...any tips? | ej25wagon | Normally Aspirated Powertrain | 4 | 07-01-2001 05:53 PM |
