#1 |
Member#: 326377
SCIC
Vehicle:2006 WRX Wagon Aspen White |
![]() Building a custom turbo kit for my 2005 lgt
Header built out of 1.5” sch10 321ss primaries, and 2” secondaries. Using a Garrett gtx3584rsii. I plan on doing a front mounted turbo, and awic with a rotated custom aluminum intake manifold. I will keep this thread updated with my progress. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
#2 |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
![]() Very nice stuff.
What's your power goal? |
#3 |
Member#: 326377
SCIC
#4 |
Member#: 478524
NESIC
Vehicle:All Any Every |
![]() Holy gorgeous manifolds!
I would think 500 on the stock block is doable, but she ain't gonna like it. It would probably survive if driven conservatively and ALL the supporting mods are done. 750 on a built one some be no problem. Idk if you're interested, but this dude has a turbo ez30 in his LGT. https://youtu.be/OyWe1_sxEE4 |
#5 | |
Member#: 326377
SCIC
![]() Quote:
Yeah I don’t have to high of expectations out of a stock block. Brandon is the man! He’s actually helping me out with my wiring. Super cool dude! Sent from my iPhone using Tapatalk |
#6 |
Member#: 478524
NESIC
![]() That's awesome! Can't wait to see the progress!
#7 |
Member#: 3687
MWSOC
Vehicle:MY99 GF4 JDM 6spd |
![]() Your intercooler setup will limit you. You need more crossflow because I know you're not going to be only running 12psi. Give it a go and watch the IATs.
#8 |
Member#: 326377
SCIC
![]() ![]() ![]() Turbo is hanging in its new home. Talking with turbosmart and haltech about possibly using the new electronic straight gate. Sent from my iPhone using Tapatalk |
#9 |
Member#: 326377
SCIC
![]() Got the “up-pipe” fit and welded. Left it long so I can cut it to fit. Working on the wastegate
#10 |
Member#: 326377
SCIC
![]() ![]() ![]() ![]() ![]() Finally got something done. A lot of work goes into this stuff Sent from my iPhone using Tapatalk |
#11 |
Member#: 326377
SCIC
#12 |
Member#: 326377
SCIC
![]() Added a small bend to move the turbo closer to the engine. Much happier with the placement now! Time to finish the last couple welds on the header
#13 |
Member#: 515308
![]() Room under there for for twins bolted as close to the ex flange as possible? And oil sump/pump
#14 |
Member#: 326377
SCIC
#15 |
Member#: 326377
SCIC
![]() ![]() So close. Just need some free time! Sent from my iPhone using Tapatalk |
#16 |
Member#: 326377
SCIC
![]() ![]() ![]() ![]() ![]() Had some time to work on the car this past couple weeks. Header just needs the vband for the wastegate welded (need to machine a heat sink before welding it). Welded the oil return bung in the front cover (welded from the inside). Fuel lines complete up to the firewall. Can’t wait to drop the motor in and keep rolling! Sent from my iPhone using Tapatalk |
#17 |
Member#: 326377
SCIC
![]() ![]() ![]() Downpipe ready to finish weld Sent from my iPhone using Tapatalk |
#18 |
Member#: 326377
SCIC
![]() ![]() ![]() ![]() Just need to add a hanger and she’s done. Deciding if I want to recirc the wastegate into the downpipe or just make a straight dump for it. Sent from my iPhone using Tapatalk |
#19 |
Member#: 326377
SCIC
![]() I need to talk to some professionals in the cooling department. I need to decide what size radiator is needed and if I should do awic or not. Any recommendations?
#20 |
Member#: 326377
SCIC
![]() ![]() Fuel lines are complete ![]() Sent from my iPhone using Tapatalk |
#21 |
Member#: 464859
![]() Very nicely done!
#22 |
Member#: 326377
SCIC
![]() ![]() ![]() Sent from my iPhone using Tapatalk ![]() Last edited by newbie123; 03-19-2023 at 08:54 PM. |
#23 |
Member#: 326377
SCIC
![]() ![]() ![]() ![]() Making some progress on the intake manifold. Would anyone be interested if I started making these? Sent from my iPhone using Tapatalk |
#24 |
Member#: 124809
MWSOC
Vehicle:04 FXT, 07 STI JBP, SWP |
![]() Awesome progress!! Do you have an IG to follow?
#25 |
Member#: 326377
SCIC
