Welcome to the North American Subaru Impreza Owners Club Friday February 14, 2025
Old 01-16-2006, 01:28 AM   #1
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Default Water Vs. Alky VS. Meth...
I searched for a while and couldnt come up with the answers I am looking for.
How do the three compare to eachother? I am assuming that Meth or Alky will yeild higher numbers than water alone, right?
Advantages/disadavanteages of each?
I know that is very common to see a 50/50 mix, but Is anyone running just water? Results?
Thanks. Mike
mrubino83 is offline   Reply With Quote
Old 01-16-2006, 01:39 AM   #2
Davenow
Member#: 23676
water will yeild the charge cooling only. Which will allow a little more agressive fueling/boost/timing
Alch/water mix will allow a little more agressive fueling/boost/timing
Straight alch will allow yet slightly more agressive fueling/boost/timing
Methanol will allow yet again SLIGHTLY more agressive fueling/boost/timing
50/50 alch/water mix is commonly thought as "best" because it is the best bang for the buck. A good bit better potential, and half the cost of straight alch.
Old 01-16-2006, 05:50 AM   #3
mrubino83
Member#: 22987
Thank you! That is the info I was trying to confirm
Old 01-16-2006, 01:44 PM   #4
AdamBlitzer
Member#: 87709
2005 STi
i cannot decide which route to go myself. thanks for the info it has helped.
AdamBlitzer is offline   Reply With Quote
Old 01-16-2006, 01:53 PM   #5
Davenow
Member#: 23676
One other benefit of 50/50 is that a lot of people worry about a plastic jug if VERY flamable stuff in their engine compartment. Well, 50/50 doesnt ignite
Old 01-16-2006, 01:59 PM   #6
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Don't forget that methanol is extremely toxic to deal with and straight alcohol simply should not be ingested.
Nixlimited is offline   Reply With Quote
Old 01-16-2006, 03:11 PM   #7
titsataki
Member#: 4402
Methanol is quite a bit cheaper than Alchy. I get it in 5 gal containers. Wear gloves and do the mixing in an open garage and you should be ok. I use a 1 parts distilled water 2 parts methanol formula. I also have a spec C tank that fit 12 liters so I do not have to refill as frequent.
Cheers
Nick
titsataki is offline   Reply With Quote
Old 01-16-2006, 03:13 PM   #8
dream
Member#: 37003
2015 WRX
Cheers
Nick
Where did you get the spec C tank??
dream is offline   Reply With Quote
Old 01-16-2006, 07:59 PM   #9
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Rallispec Ltd sells them on their website.
Methanol is considerably cheaper, I am getting 5 gallon cans of Sunoco powermist methanol for about 30 bucks a can. As a perspective, denatured alky is about 11 dollars a gallon at home depot. Unless you get alky in bulk, I.E. 50 gallon drum, meth is much more bang for the buck. Have you checked out the aquamist forums yet? THere is good info there on injection mixes. I am right now using 50/50 meth/distilled water. Go the aquamist home site, and then to the forums in the menus at the top of the homepage.
DP
DonkeyPunch is offline   Reply With Quote
Old 01-16-2006, 04:28 PM   #10
SaabTuner
Member#: 67608
There are some things that a straight-water mixture can do which cannot, or at least should not, be done with alcohol in the mix, such as injecting pre-turbo. "Wet compression" is a big thing in the turbine world, even though the name sounds like the title of a bad pr0n movie.
It should be noted, however, that iff you inject straight water without making any other adjustments/tuning, you'll lose power because it slightly delays the ignition of the mixture. Fortunately, the ability to add timing, boost, or subtract fuel, generally offsets that delay by a wide margin.
SaabTuner is offline   Reply With Quote
FMIC vs STI TMIC+meth? marcus.raw Water/Methanol Injection, Nitrous & Intercooler Cooling 8 11-05-2007 08:49 PM
How much more with 100% alky vs 50/50 metoo Water/Methanol Injection, Nitrous & Intercooler Cooling 8 11-20-2006 10:57 AM
Pump vs. Alky injection 1/4 results xcntrk75 Proven Power Bragging 4 06-06-2006 09:43 AM
water injected carborater vs. intercooler sprayer romeo2001us Newbies & FAQs 7 07-22-2005 08:41 PM
Water Injection: Pros vs Cons SuberStar Water/Methanol Injection, Nitrous & Intercooler Cooling 18 04-08-2004 12:41 PM
