#26 | |
Member#: 192988
Vehicle:2005 WRB GD Wagon |
![]() Quote:
So I'm doing even bigger injectors, SS lines, and rails now. Waiting on parts at the moment.
#27 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
![]() Where are you at ?
Did you sort it out ? Sent from my iPhone using NASIOC |
#28 | |
Member#: 192988
![]() Quote:
It's back in with, new fuel lines, new fuel rails, new injectors. I just buttoned it up last night, checked fuel pressure and flashed a new tune for the bigger injectors. I did not start it, because I know better to do that on a Sunday night when I won't get to touch it until next weekend. The saga continues! ![]() |
#29 |
Member#: 517506
Vehicle:97 coupe-bugeyewrx |
![]() JDM EJ20 X-Y. throw out the intake and sell heads for scrap metal. you can use valves. shim cups. etc but the 4 cam sensors don't work with US stuff. use the USDM heads-intake and sensors your ECM can work with. slightly higher CR but not huge issue until you go with real boost. then you want 800 buck forged pistons, etc...
#30 | |
Member#: 110078
![]() Quote:
He is not playing with either of those variants, he has a ver 7 ej207 Sent from my iPhone using NASIOC |
#31 |
Member#: 192988
![]() It's a V9 and nothing fits. The one piece intake is cool but it hits the AVCS solenoids. I started it and it has a massive vacuum leak, so I tore it apart again. It's been cold and I have not been working on it.
#32 | |
Member#: 110078
![]() Quote:
Why would that be ? I have a ver 9 ej207 with the original one piece intake manifold and fuel rails. No issues. Sent from my iPhone using NASIOC ![]() |
#33 |
Member#: 192988
![]() Well, because my 05 has quick disconnect fuel fittings, so I could neither use my old fuel lines (would not bolt up), or the fuel lines from the one piece intake (because they are barb fittings).
So instead, I went full aftermarket fuel lines, which are beautiful and bendy, but the aftermarket fuel rails sit against the AVCS solenoids. So now I'm thinking I need to go back to TGV deletes, or, I need spacers between the heads and the intake. This is my nightmare. Name of thread still holds. 8 degrees out this morning, work stoppage. |
