Welcome to the North American Subaru Impreza Owners Club Monday February 10, 2025
Old 11-23-2024, 12:34 PM   #1
drifter001
Member#: 324227
05 wrx
cgm
Default Misfiring under boost
Not sure if I’m posting in the right spot so mods please feel free to move as needed.
I’ve got a 05 wrx that’s been tuned by a reputable shop. Lately I’ve had an issue where I get a misfire code from a single cylinder. Upon further examining, I noticed that it happens after passing about 5psi boost. My initial thought was maybe a bad coil pack but after paying more attention to my boost, I’m thinking that may not be it. Any suggestions on where to start?
drifter001 is offline   Reply With Quote
Old 11-24-2024, 10:26 PM   #2
Brock31
Member#: 128115
2008 STi Hatch OBP
enginuity is cool
Move the coil pack to another cylinder and see if the misfire moves to that cylinder.
Brock31 is offline   Reply With Quote
Old 11-24-2024, 10:35 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Agreed.
The coilpack, or maybe spark plug, may be weak/failing. Boost makes it harder for the spark to jump the gap leading to a missfire. If moving the coilpack makes no difference, swap the plug.
Old 11-25-2024, 12:22 PM   #4
drifter001
Member#: 324227
05 wrx
cgm
Thanks for the suggestion. I'll give that a shot
Old 12-03-2024, 12:34 PM   #5
drifter001
Member#: 324227
05 wrx
cgm
So the codes that I’m getting are P0302 and P0304
Old 12-03-2024, 04:50 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
So, misfire on cylinders 3&4.
But, you originally stated a single cylinder misfire. Is this getting worse? Have you swapped parts to see if issue follows a part?
Old 12-03-2024, 07:49 PM   #7
drifter001
Member#: 324227
05 wrx
cgm
The original code was p0302. I swapped parts on the same bank so 2 and 4 if I got my firing order right and now I got p0302 and P0304
Old 12-04-2024, 12:42 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
So, could be a bad #2 coil and plug. When you swapped, you moved part of the issue to #4, but still have bad plug in #2. The plug could be fouled by bad coil.
Old 12-04-2024, 01:27 AM   #9
drifter001
Member#: 324227
05 wrx
cgm
So I should try replacing plug in #2 cylinder and see if it at least that code clears then try for the #4 coil pack?
Old 12-04-2024, 05:12 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Sure, it would help diagnosis, on both counts.
What is the mileage on the plugs now and what are they? If old/high mileage, may be time for 4 new plugs.
Old 12-04-2024, 06:35 PM   #11
drifter001
Member#: 324227
05 wrx
cgm
I’d say they’re about 20-30k old. They’re the OEM plugs purchased from the subie dealership
Old 12-30-2024, 08:06 PM   #12
drifter001
Member#: 324227
05 wrx
cgm
So replaced coil pack in #2 cylinder and now I’m getting a p0304 and misfiring starts at over 5psi still. Is it possible that overall health of my coil packs is deteriorating or am I chasing something that may not be an issue?
