Welcome to the North American Subaru Impreza Owners Club Wednesday February 19, 2025
Old 11-14-2016, 08:54 AM   #1
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
OMGHi2U How to use a 2010-2012 legacy ej253 in your 06-07 impreza 2.5i
I kept the 2012 2.5 legacy sohc and modded a few things so it now has a home in the impreza.
2slofouru is offline   Reply With Quote
Old 11-15-2016, 05:23 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
For those that are wondering (as I was) what he's referring to when he said he's still stuck with his '12 engine, see here.
Old 11-15-2016, 05:57 PM   #3
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
So the pre-12 pan wont fit this enigne is that right? Have you tried yet?
GEE-OTTO is offline   Reply With Quote
Old 11-15-2016, 08:48 PM   #4
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I'm not exactly sure, but I think the 10 or 11 legacy started with the strange two piece pan on the ej253, until they went to the fb25 for the next change which is totally different altogether.
Yeah Patrick, I was referring to the for sale thread and forgot to mention that. I'm trying to hold off on removing the pan from the legacy engine so a potential buyer won't be worried but if it can be adapted I will close the for sale thread. I'm checking with a friend about making an adapter spacer to mate the normal metal pan to the block and adapt to the different bolt locations, but can't even do that without knowing if there are bolt holes for the pickup on the block or if the pickup hole is even in the same location.
Old 11-16-2016, 01:53 PM   #5
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
Can you post up the two piece pan? At this point your cheapest choice it to at least try to see if the 253 pan matches the shortblock profile.
Old 11-16-2016, 04:21 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Having never seen the 2-piece version, my opinion might mean nothing, but I would be rather surprised if Subaru changed the entire block just to bolt up a different oil pan. I'd think the block is the same, so a "normal" pan and pick-up will work.
Old 11-16-2016, 10:09 PM   #7
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
This is the pan it uses, the front row of bolts are 12mm head and their shank is thicker as well. I pulled two to check. Here is a good ebay pic: http://www.ebay.com/itm/252599509954...%3AMEBIDX%3AIT
10mm bolts like the others around the perimeter are too small to work. If you look closely the front edge also seems slightly diagonal while the normal pans have their front row basically parallel with the rear row. The pickup tube is also built into the pan and the pan holds the pickup tube to the block, there are no bolts for the pickup.
I will pull it in a few days if there is no real interest. I have a person inquiring but not sure if they realize whether or not it will work on their vehicle.
Old 11-27-2016, 06:03 PM   #8
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I figured out how to use the normal steel pan, had to drill and tap two holes that weren't there and tap the two for the oil pickup. Luckily the oil pickup tube mates to the same spot in both setups. The holes were there just no threads. I drilled two that weren't there for the pain flange and used 8mm allen plugs with sealant on the two holes that didn't line up with the pan. Then you just enlarge two of the pan holes a little for the m8 bolts that you have to use. So basically you will have two 12mm head (or allen like I used) bolts and the rest normal 10mm bolts holding the pan on.
https://drive.google.com/file/d/0B07...ew?usp=sharing
The m8 factory hole next to my drilled and tapped m6 hole, and the allen plugs I used for the two unused holes:
https://goo.gl/photos/DPWhTCu1efycSzgd8
Everything worked out great and the engine is now in the car running. I'm just waiting on the exhaust manifold gaskets from the dealer because no local parts places had them in stock.
I had to do some rigging for the pcv to block setup
Old 11-27-2016, 06:09 PM   #9
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Up and running yesterday!
https://goo.gl/photos/o7Nt74RQztwm4ADL7 What the crap, I suck at this google photo link stuff :/
A few more photos here
http://legacygt.com/forums/showthrea...66#post5523966
Old 01-13-2017, 01:36 AM   #10
abomination
Member#: 456880
2003 Ourback
Red
That's awesome. I'm looking to do the exact same thing on my 2007 outback!
Thanks for the info! It seemed feasible, but I was concerned about the motor mounts and the oil pickup. That could have gotten pretty crappy if they weren't basically there.
Thanks Again,
Jeremy
abomination is offline   Reply With Quote
Old 12-27-2023, 07:59 PM   #11
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Up to the top. I've had some requests for the photos in my drive folder, but no notifications from anyone here. Thanks for the interest.
Old 01-01-2024, 03:03 AM   #12
Julian758
Member#: 536281
Default Hi
I'm a bit unsure, but it seems like the 10 or 11 legacy models began with the unique two-piece pan design on the ej253 engine, then shifted to the fb25, which brought a completely different setup.
Hey Patrick, sorry, I forgot to mention earlier that I was referencing the for sale thread. I'm holding off on removing the pan from the legacy engine to avoid concerns for potential buyers. I might consider closing the for sale thread if I can adapt it. I'm exploring options with a friend to create an adapter spacer to connect the regular metal pan to the block and accommodate the different bolt positions. However, I need more information about the bolt holes for the pickup on the block or if the pickup hole aligns similarly.
Julian758 is offline   Reply With Quote
Old 01-01-2024, 12:36 PM   #13
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
The normal ej pan bolted to my legacy engine after removing its aluminum pan. The normal oil pickup tube will bolt on, I believe the holes are already there and just need to be threaded to m6x1.0.
The pan also uses most of the holes but one or two need to be filled with the allen plugs I mentioned in the photos, because those don't align with the normal ej pan holes.
Old 10-03-2024, 05:59 PM   #14
Suba Imp 10
Member#: 520833
2010 Impreza 2.5i Pr
Why did you have to plug the 2 holes that didn't line up with the pan? Wouldn't the gasket keep them from leaking? Is the Y-tube you have for the pcv from the legacy engine?
-Never mind. Just read the thread on the Legacy site. I think information that would be more beneficial to this site than the legacy site. But at least it's somewhere..lol. Thank you for your insight.
-unfortunately most of the pictures are no longer there.
Suba Imp 10 is offline   Reply With Quote
Old 12-11-2024, 10:19 AM   #15
Suba Imp 10
Member#: 520833
Just did the same thing for my 2010 Impreza N/A. All went well and am hitting the 500 mile break in soon. Haven't heard from the OP. But thanks for giving me the courage to do this. Couldn't believe my luck and bought a brand new remanufactured block off CL for 600 bucks. He also threw in another engine with 500 miles on it for free. He says it might have bad rod or crank bearings but rolling it over and pushing on the pistons it seems to be all right. Now all i need is a car that needs an engine..lol.
