Welcome to the North American Subaru Impreza Owners Club Wednesday February 19, 2025
Old 09-25-2018, 12:18 PM   #1
bigredscowboy
Member#: 442121
1999 Impreza Outback
Red
Default 2.2 (EJ22) head gasket p/n and 2.5 alternates?
I have one of the rare 2.2 with blown head gasket. Fel-pro blue mls failed after 35k. So it’s back out. I had a set of sti gaskets (11044aa642) and everything lined up. Simple google search gave me this:
https://forums.nasioc.com/forums/showthread.php?t=1713699
Originally Posted by Marnix View Post
All OEM headgaskets after 1999 are MLS; ie. 2.5 SOHC and 2.5 DOHC Turbo (11044AA641 - 0.58 mm thickness); 2.0 DOHC Turbo (11044AA483 - 0.8 mm thickness); 2.2 SOHC (11044AA542 - 0.8 mm thickness) and even the replacement 1996-1998 2.5 DOHC (11044AA610 - 1.4 mm thickness).
All these gaskets have the same pattern for coolant passages which means they won't work on pre-1999 SOHC heads (except 1991-1994 2.2 Turbo).
So this was from 2009. STI AA642 mic’ed out at 0.8mm for me, so I used it (old Felpro was also 0.8mm). Called my people at Subaru and they said the present 2.2 p/number is still 542. 2004 2.5 N/A is 632 and/or 633. He didn’t have a thickness spec. Rep said it was possible that all the gaskets are the same thickness.
So did Subaru add some thickness to the sti (642) over the last decade or was the above DOHC turbo a wrx only measurement (641 @ .58mm)?
Also, will I have any valve interference or tensioner problems if my guage was wrong and the 642 was actually 0.58mm when it needs 0.8mm (or more for the .001” I shaved off)?
bigredscowboy is offline   Reply With Quote
Old 10-01-2018, 03:20 PM   #2
bigredscowboy
Member#: 442121
Red
I ended up at Subaru and purchased a set of 633’s. These are for the 2.5. Just wanted to add info for posterity. They are single layer @ .8mm
Compare this to the 642 which is mls (three layers) @ .8mm also.
Old 10-01-2018, 04:09 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Thanks for the info.
Do you have an Outback (guessing no, thought 99 was 2.5L) or OBS (Outback Sport, Impreza based, NOT Legacy based)?
We owned (from new) a Impreza L wagon, 2.2..... yes, we lost a HG. Myself and others didn't believe it either.
I tend to just use the current USDM dealer HG, I shy away from aftermarket on some cars, like Subaru.
Not saying others are bad, just saying what I do.
I would "prefer" the correct current HG PN for the VIN assuming the engine is original.
Will yours work?
Maybe.
Assume ALL Subaru engines are interference. There are ways to check, but I err on the side of caution, even though I do a lot of my own work.
Old 01-14-2025, 10:07 PM   #4
Sforester
Member#: 540036
Default Question
I saw this post and have a question for anyone where who may have the relevant experience. I own a Subaru forester usdm ej2.5 l I swapped to a jdm ej20 and blew head gaskets on the jdm ej20 I am trying to verify whether gaskets mentioned above 110044AA483 will fit this engine I have been told that gaskets for the ej205 02-05 wrx are what fits this? Anyone have any relevant experience with this as I would like to ensure I have the right gaskets for this jdm ej20 motor
Sforester is offline   Reply With Quote
