#1 |
Member#: 508899
![]() Hello. Thank you for reading this. I appreciate the responses to my post about dented fins that I messed up with during this process. You're all awesome!
I am doing the timing belt on a 2000 Subaru Impreza SOHC after 13 years (60k miles after last one done at a shop) and everything looked in good condition and the old belt (no idea of brand) looks more substantial than this Aisin one, but I am still a newb to this process. I thought the number of years since the last one would require a change. After struggling, I got the belt on, but it's not lined up properly on the driver's side. The driver's side sprocket was off a bit after taking the belt off, so I had to turn it to try to line it up with the yellow mark on the belt, but it was under tension and would get close and then turn another 30 degrees or so until I got it as close as I could without spinning -- I did more research and apparently I have to turn the DS sprocket slowly and possibly get someone to hold it in place so everything lines up? The passenger and middle seem fine, and I don't think I could get it lined up better after trying multiple times, but I could be doing something wrong (flip the belt around?). I didn't pull the pin on the tensioner or rotate the crank yet, so would I rotate it and then check everything again or? The videos made it seem much easier, lol... Picture 1 (passenger side looks mostly lined up) - https://ibb.co/HBv0sr2 Picture 2 (middle) - https://ibb.co/5vHxNdp Picture 3 (driver's side that's a bit off) - https://ibb.co/r5F8t1H Does the red mark on the sprocket have to line up with the notch above and the yellow line on the belt? Pictures before new belt install -- Passenger side https://ibb.co/SwgvTcS Driver's side https://ibb.co/NjcKwwW Middle https://ibb.co/k5LvrRW
#2 |
Member#: 27525
SCIC
Vehicle:03 wrx wagon yellow |
![]() Yeah the driver side looks 1 tooth off. The yellow marks on the belt should line up to the "I" markers cast on the pulley. Looking at the before pics, the marker is over the red line. Redo the belt so the yellow line sits with the red line.
If you're having trouble putting the belt on. Take out the small bottom passenger side idler while you put on the belt and align it. Then put that idler back on last. Be extra careful not to crossthread that last idler. |
#3 | |
Member#: 508899
![]() Quote:
#4 |
Member#: 27525
SCIC
![]() Leave the cogged one on. With the bottom idler off, there's slightly more wiggle room to push the belt onto the cogged idler/waterpump area. There probably won't be enough slack to rearrange the teeth though.
Yes, if you have a helper it would be easy to have them hold onto the passenger pulley. Main idea is get the upper side tensioned so the lower side has slack to push the belt on. You have the right idea by clamping the belt to the cam. Probably figure out how to lock the flywheel or jam something in the passenger cam so you could put tension the driver cam. |
#5 | |
Member#: 508899
![]() Quote:
Pictures driver's side - https://ibb.co/SPqyqBY https://ibb.co/G3N3LYt https://ibb.co/NTvnrht Other spots - https://ibb.co/RYKpd71 https://ibb.co/Sc4R4pG Last edited by 2000Subaru2.5RS003; 01-04-2025 at 03:31 PM. |
#6 | |
Member#: 283429
South East
Vehicle:2016 Crosstrek Silver |
![]() Quote:
#7 | |
Member#: 508899
![]() Quote:
https://ibb.co/SPqyqBY https://ibb.co/G3N3LYt The belt didn't have arrows on it, but I placed it so I can read the name of the manufacturer. Last edited by 2000Subaru2.5RS003; 01-04-2025 at 03:02 PM. |
#8 | |
Member#: 283429
South East
![]() Quote:
YOU NEED THE BELT TO HAVE TENSION between the two cam sprockets across the top to verify timing. Install the belt fully. Do not pull pin in tensioner. Turn that drivers side cam with a socket or wrench slightly until that cam's marks line up. Verify the crank and passenger side cams line up on mark. |
#9 | |
Member#: 508899
![]() Quote:
#10 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
![]() When I install Subaru timing belts, I start at the crank and go CCW (counter clockwise) through everything. This allows you to work off a fixed point (crank) and then pull on the belt as you thread it around.
Most of the Subaru TB's I do are DOHC, so, a bit harder. A trick can be to use a small wood wedge between the timing belt and the guard over it at the crank. |
#11 | |
Member#: 508899
![]() Quote:
#12 | |
Member#: 283429
South East
![]() Quote:
#13 | |
Member#: 30669
![]() Quote:
This is normal. Don't get excited. Just make sure the cam and crank marks line up. |
#14 |
Member#: 508899
#15 | |
Member#: 508899
![]() Quote:
Current pictures with that teeth count - PS https://ibb.co/DCcLgKy DS - https://ibb.co/rbnVbrn Last edited by 2000Subaru2.5RS003; 01-05-2025 at 06:24 PM. |
