Welcome to the North American Subaru Impreza Owners Club Saturday February 15, 2025
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 07-21-2004, 01:55 PM   #26
Entropy512
Member#: 66649
Originally Posted by ttl
I just found some good info about cd changer wiring:
CD Changer Protocols:
http://www.mictronics.de/?page=cdc_proto
Panasonic CD Changer Emulator - PIC 16F84A controlled:
http://www.lafrog.com/cdcemu/
Maybe someone can make a real AUX input for Panasonic 6-CD changer? (16-pin connector).
From what I've read (I just discovered those links myself...), many of the other Panasonic interfaces split the audio and the data portions of the interface into two different connectors. The Panny unit in the Subarus seems to use the same protocol but a combined connector, from the looks of the pinout on scoobymods.com.
Another link can be found at http://trikuare.cx/mt/archives/000632.php with some useful info.
I think I have a signal generator capable of a 125 KHz squarewave, so I'll see if that is sufficient for tricking the HU into thinking a CD changer is attached soon.
Otherwise if that doesn't work, instead of using a PIC like the guy in one of your links did, I'll use an Atmel AVR microcontroller. (I'm more familiar with AVRs, and they're easier to program IMHO.) Plus there are some good C compilers for the AVR and C is easier to understand/read than ASM.
I won't be able to do this for another week or two at least - need to get the connectors first.
Entropy512 is offline   Reply With Quote
Old 07-27-2004, 04:03 PM   #27
SASniper
Member#: 57913
Hey irmiger,
Was it you who posted the wiring harness diagrams in regards to ground loops ... was just wondering if you'd found where the plug in the compartment earthed to, or if you'd found an alternative?
The radio earth is easy to find, but the 12V plug is difficult to locate with that weird perspective diagram.
SASniper is offline   Reply With Quote
Old 08-01-2004, 04:10 AM   #28
irmiger
Member#: 54241
2004 Forester XT
Java Black
Originally Posted by SASniper
Hey irmiger,
If you mean this one...
Radio : B201
Radio Ground : GR
Front Lighter : B119
Lighter Ground : GB-3
...then yeah, it was me. As for that location of GB-3, I really couldn't say. I'm using the arm rest lighter socket so I went the easy route and ran a seperate wire from the radio's ground (right from plug B201) right to the lighter's wire.
In case you're using the arm-rest socket too, the ground point's easy to find. It's under the carpet, directly under the front edge of the passenger seat. If you run your hand along the top of the raised section there, you'll feel a bump right in the middle. That's it. It's a threaded post sticking straight up with a nut on it.
James.
irmiger is offline   Reply With Quote
Old 08-02-2004, 05:37 PM   #29
SASniper
Member#: 57913
Thanks irmiger. Yeah, I am using the arm-rest socket too
"Good news kids ... there's gonna be some rewiring, TONIGHT!"
Old 10-25-2004, 07:36 PM   #30
SASniper
Member#: 57913
Thanks again irmiger.
I still haven't gotten round to this, but I tooka quick look.
How did you get the carpet up from under the passengers seat?
Old 10-28-2004, 02:24 AM   #31
onglide
Member#: 52149
Lightbulb Pre-wired 13 pin DIN plug for $5.90 + 7.90 shipping
I've found an alternate source for making the adapter cable Irmiger describes in the first post of this thread.
Buxcomm sells a DIN plug that's already wired up with 6 feet of cable. I have one currently installed and talking to my Ipod in my 04 Forester XS stock CD head unit (though I haven't fixed the ground loop problem yet, more on that in another post.)
If you are interested in making your adapter this way, go to http://www.buxcomm.com/afconns.htm and search the page for text like: "13 pin DIN male plug wired with 6 ft".
The cable comes with all 13 pins connected to color coded wires and their web page shows which color goes with which pin. You still need to buy an un-wired mini stereo plug and connect 4 of the cable's wires to the three conductors of the mini stereo plug.
Irmiger kindly translated the cable wiring diagram for me to this simple cheat sheet:
1 - Connect the Brown (1) wire to the Phono Plug's "Right" pin
2 - The Orange (3) wire goes to the Phono's "Left" pin
3 - Then connect both Red (2) and Yellow (4) wires to the Phono Plug's "Ground".
That's it! It works! Thanks Irmiger, Boxxer & others for figuring this out!
onglide is offline   Reply With Quote
Old 10-29-2004, 10:39 AM   #32
akuhner
Member#: 462
2000 Impreza 2.5 RS
SCCA Rally Cross Car
That is sweet, I'm going to be doing that to my wife's Forester after we get eachother i-pods for Christmas. Thanks for posting this, it will save me a lot of time.
I'd do it to my car, but at this point only one speaker works and the wiring is hacked to heck, so forget it...
akuhner is offline   Reply With Quote
Old 11-14-2004, 04:31 PM   #33
onglide
Member#: 52149
Question Where's the radio's ground?
Sorry to be thick, but I haven't had any luck finding the radio ground from the diagram Irmiger posted.
I think I found the armrest cig lighter ground (at least I've found the threaded post sticking straight up with a nut on it underneath the passenger seat.) But I've no idea how to find the radio ground -- or how to thread a wire underneath the carpet from the center console to the post under the passenger seat. Also, I don't know what a star connector is.
After trying to connect the cig ground to various points under the radio and producing a spark with one of them I decided it would be better to ask than continue experimenting.
Can anyone help describe exactly how to find the ground or post a pic? And/or explain how they got the connecting wire under the carpet?
Thanks,
Eric (Onglide)
Old 11-14-2004, 06:38 PM   #34
irmiger
Member#: 54241
2004 Forester XT
Java Black
Sorry, I haven't looked at this post for awhile. I'll pull my facia off when I get home from work and snap some pics so you can see where the radio's ground wire is and where to run the wires.
SASniper - If you're using the center armrest lighter socket, then you don't really need to run a wire under the passenger seat carpet at all. The lighter has two wires comming directly out of it's bottom, one positive, one ground. You can use a tap connector and tie right into it there. Then run the wire along under the side of the center console to the radio.
Eric - Thanks for your email. Will post the pics this evening and hopefully everything will clear up a bit.
James.
Old 11-15-2004, 03:45 AM   #35
irmiger
Member#: 54241
2004 Forester XT
Java Black
Ok gang, I had a wonderfull offer from nearby onglide to use his dismantled dash for my pics...but of course, stupid me checked my email after I finished with the pictures! Go figure. Thanks anyway onglide.
I also thought some pics of the #13D Buxcomm cable would help:
They also offer a 1/8" Stereo Phono Plug for $0.85 just above the cable.
If you don't want to solder anything, Radio Shack has a Solderless 1/8" Plug for $3.99!
CABLE/GROUND ROUTING
a. Unscrew the shifter knob, then pull up on the surrounding plastic panel to remove.
b. To pull the center console cover off (between seats) remove these 2 screws:
c. Then screws 1 and 2 (3 and 4 are for the center facia covering the radio) and pull up where marked (there are two press-fit clips underneath holding it in):
d. Lay console cover against driver's seat while running wires so you won't have to remove the parking brake handle. You can route your cable/ground wires along the right side of the center console without interfering with the parking brake:
Old 11-15-2004, 03:48 AM   #36
irmiger
Member#: 54241
2004 Forester XT
Java Black
GROUND WIRE (Center console lighter)
a. After removing the center console cover, the lighter's wires will be exposed (you can see my black iPod cable running up along side the lighter). Blue=positive (12v), Black=negative (ground):
b. Use a wire tap and connect your wire to the lighter's black (ground) wire:
c. Run your cable along the right side of the console to the radio.
d. Underneath the radio is the radio chassis ground (black w/yellow stripe). This ground connects back to the radio's primary ground wire (black w/red stripe) located in the main harness plug on the rear of the radio:
e. Using another wire tap, tie into this wire to complete your ground.
f. Optional: to really get a solid ground, remove the radio, unplug the main harness, and tap into the primary ground itself (black w/red stripe) instead of the chassis ground.
- James
Old 11-15-2004, 04:11 PM   #37
Seayak
Member#: 52687
2004 Forester XT 5M
Question Kenwood Aux Adaptor
Has anyone tried using the Kenwood Aux adaptor for the MP3 player input solution? Model # CA-C!AUX
http://www.bestbuy.com/site/olspage....5&type=product
I'm curious if I can skip the soldering :-)
Seayak is offline   Reply With Quote
Old 11-15-2004, 05:00 PM   #38
irmiger
Member#: 54241
2004 Forester XT
Java Black
Looks like the right 13-pin plug. I wonder.....
Old 11-15-2004, 05:24 PM   #39
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
anybody figure out how to trick the HU into thinking it has a changer?... I believe I read that you can use something to do that...
DanzBorin is offline   Reply With Quote
Old 11-15-2004, 05:25 PM   #40
irmiger
Member#: 54241
2004 Forester XT
Java Black
Just called Good Guys and will be picking one up this afternoon for $25. I'll try it tonight and post my results. Wish me luck - James.
Old 11-15-2004, 05:32 PM   #41
DanzBorin
Member#: 7131
2015 Outback - Croc
picking up what? the cord you mentioned?
Old 11-15-2004, 10:40 PM   #42
Seayak
Member#: 52687
2004 Forester XT 5M
Arrow Holding my order...
I'll wait 'till you post your results before I order one (none in stock around here - man I hate waiting...)
Old 11-16-2004, 02:11 AM   #43
irmiger
Member#: 54241
2004 Forester XT
Java Black
Well, apparently it doesn't work. I was looking forward to a quick fix, but I guess not. The actual 13-pin plug is identical and connects right up to the radio. Sadly though, no amount of fiddling around could get any sound out.
After removing it, I checked the pin outs with my multi-meter. The RCA-to-pin matches are as follows:
#12 - Lch (+)
#11 - Lch (-)
#8 - Rch (+)
#7 - Rch (-)
Compare that to what it should be on the Subaru radio:
Does anyone know any other manufacturers using the 13-pin plug?
Old 11-16-2004, 03:13 AM   #44
Seayak
Member#: 52687
2004 Forester XT 5M
Have a Nice Day? Buxcomm Cable Ordered...
Sorry it didn't work IRMIGER
My Buxcomm cable is on it's way - soon it's goodbye RF modulator! I even have a hard-wired Kenwood RF - still sucks! I actually get more volume when using the little IRock battery powered one (cleaner too). The Kenwood does eliminate signal override when I travel though...
When I installed the RF modulator I encountered the ground loop issue. Fix came from Wal-mart of all places... It's a Scosche ground-loop isolator. $12 but I didn't have to open up any panels again. Radio Shack has one too... The Scosche uses RCA in & out.
I'll wire mine up to go in the dash storage - the Nomad sits on top (I use a sticky gel pad from Best Buy to keep it in place - works so well I have on for my boat to hold stuff on the console). I'll post pics when I'm done.
Old 11-16-2004, 10:34 AM   #45
DanzBorin
Member#: 7131
2015 Outback - Croc
irmiger... can't you just hook it up to the correct pins? I would assume wires are wires...
Old 11-16-2004, 08:23 PM   #46
irmiger
Member#: 54241
2004 Forester XT
Java Black
Unfortunately, no. Inside the little box you see in the picture are just the connections, no circuit board or anything. Rewiring it only does what I've already done and create a 13pin-to-RCA adapter cord. Nothing different will happen without circuitry to imitate the changer protocols. Bummer.
Old 11-17-2004, 10:31 AM   #47
DanzBorin
Member#: 7131
2015 Outback - Croc
does panasonic make such a cord... if so, that would be the way to go...
Old 11-18-2004, 05:00 PM   #48
Seayak
Member#: 52687
2004 Forester XT 5M
Lightbulb Another source of silence...
I found a free WAV editor that you can download & make a "silent" song in wav (and other) formats. It's here: http://nch.com.au/wavepad/index.html
Super easy to use. Make a silent song (create a new WAV and use the "Insert Silence" "Begin" under EDIT. You specifiy the milliseconds of silence to insert (45 million milliseconds = 1 hr 15 min = 75 min). It starts playing the track, but the silence is inserted right away... Just hit STOP and SAVE AS. Save the WAV file on your hard drive.
Close WavePad and open Windows Media Player. The latest version will convert a wav file (and many others) to a CD music file and burn it to a CD. Have MediaPlayer search for media files on your disc (if you aren't specific about the location it'll find every sound and such). Click the BURN tab and pick your new silent song from the list - burn it to CD. Done
Hope this is helpful.
Old 12-13-2004, 03:55 PM   #49
jmolaver
Member#: 19130
'01 TTE Miata
www.awesom-oracing.com
Default STi?
If I remember correctly the head unit in the Forrester looks real similar to the one in the STi -- anyone have any info if this mod/hack will work with that ('05 STi)?
p.s. please please please say yes
jmolaver is offline   Reply With Quote
Old 12-13-2004, 09:46 PM   #50
kevinsUBARU
Member#: 2263
2014 Sportwagen TDI
I have a AM/FM radio/tape decks (Clarion)from both a 1995 and 2001 Impreza. Both have the 13 pin din plug on the back. If I make this cord and then just put a blank tape in, should it do the same thing as the blank CD? I think it is worth my time to try this if no one else has
kevinsUBARU is offline   Reply With Quote
The iPod Solution For Those Who Have Time colinrobinson Car Audio, Video & Security 18 06-20-2014 01:36 PM
The best Ipod Solution for '06 Tribeca owners WITH rear DVD... HB_Dad Tribeca Forum 0 06-05-2006 04:29 PM
IPOD solutions? bwagner Car Audio, Video & Security 26 11-24-2005 01:49 AM
aesthetically pleasing ipod solution captain_dingaling Car Audio, Video & Security 7 11-11-2005 11:55 PM
