Welcome to the North American Subaru Impreza Owners Club Monday February 10, 2025
Old 01-18-2005, 12:23 PM   #101
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
hey kyle...
this sounds pretty interesting. I'm running a phase 2 ej25 in my obs, with EL header scoming soon. I want to get a set of deltas in late febuary, and i'f i'm pulling things apart, upping the CR with heads too would be pretty cool. My questions lie along kyles (maybe we'll do them together?).
SUBSCRIBE
staticfritz is offline   Reply With Quote
Old 01-18-2005, 01:05 PM   #102
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Matt, I did say "old" and "years of use".........But how about "10 years or older!"
Old 01-18-2005, 02:55 PM   #103
quantum
Member#: 73416
05 CTS-v
Stealth Grey
Anyone ever tried a partial block fill on a ej25, I'm theorizing that it would take care of a lot of strength problems with the block. I've heard one of the biggest causes for problems with this block is the cylendar walls can actually move or shift causing the head to blow (let me know if I was informed wrong). So I thought that a partial fill should add a lot of strength and still allow for enough cooling for high compression,nitrous, or turbo build ups. Any thoughts?
quantum is offline   Reply With Quote
Old 01-18-2005, 03:04 PM   #104
Storm
Member#: 5218
96L Most Over-
Developed Beater
Uh....since it fills up the coolant passages....it's probably not a good idea for a streetcar.
Jay Storm
Old 01-18-2005, 03:09 PM   #105
quantum
Member#: 73416
05 CTS-v
Stealth Grey
That is why I was thinking a partial fill, Like a quarter the way up. I know tons of lt1 guys who have done a partial fill and a high volume water pump with a nice radiator and actually ran cooler.
Old 01-18-2005, 03:58 PM   #106
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
There's not a whole lot of prep required to make one of these EJ22/EJ25 hybrids. The phase I vs phase II EJ22 heads thing has been argued for years around here. We used the phase I because that is what we had. They were the NA heads. The Turbo ones actually have a slightly smaller exhaust valve size and won't flow as well. But the phase I heads are dual port and let you bolt up Cobb, TWE or the other high end headers. For the single port phase II head, you could only use the Borla single port version.
We did nothing to the bottom end. Use a phase II if you can get it. Use the new four layer OEM EJ25 head gasket. With the phase I EJ22 heads, you are in the 11.5:1 CR range with this set up. We use 91 octane here because it is as high as we can get. All the sensors on the bottom end plug right in to the harness. You use your stock manifold and manifold wiring harness.
We did nothing with the ECU. One of the points of this swap is hp per $$$. It is a ghetto garage build. If you are gonna spend the money on EM, then spend the money on a built EJ25. We are using a torque chip. It helps down low. We bailed on the chipped ECU becuase it didn't like the torque chip. You could use an AFC if you wanted to play a little bit. But that's $200 more invested.
Gas mileage is in the low 20's. If you don't drive like you stole it, probably mid 20's would happen daily. I think that about covers it, for now...
Old 01-18-2005, 05:15 PM   #107
G.Subramaniam
Member#: 64528
Matt, anyone used wet nitrous on these 11:1 hybrids ?
G.Subramaniam is offline   Reply With Quote
Old 01-18-2005, 05:48 PM   #108
CirrusWRX
Member#: 17439
2010 WRX STI SE
Gray
Thank you kind sir!
Well, with the answers that Matt provided here and in other threads, and in combination what I've been piecing together, I, too, am looking to "build up" this ghetto frankenstein and try to keep it as low buck as possible. I figure I might try and get the delta cams at the same time since the engine will be out anyway, but otherwise, basically just apples to apples with a different block as far as it looks.
THANKS A TON!
CirrusWRX is offline   Reply With Quote
Old 01-18-2005, 07:10 PM   #109
Matt Monson
Member#: 832
99 2.5RS, '85 911
Just do it! You engage in far to much mental masturbation. Speed is better than sex. Get fast now!!!
Old 01-20-2005, 03:32 AM   #110
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
subscribe
Crash477 is offline   Reply With Quote
Old 01-20-2005, 10:57 AM   #111
huck369
Member#: 26201
2015 Impreza Premium
Charcoal
Subaru Stars
I'll most likely be doing this too.
for my MY00 RS, as it broke a timing belt, and since I'll have the heads off...and have a set of EJ22 NA stage I heads laying around, I'll throw them on it, hopefully it'll be a nice up in HP.
Huck
huck369 is offline   Reply With Quote
Old 01-20-2005, 11:37 AM   #112
Matt Monson
Member#: 832
99 2.5RS, '85 911
Huck
Ah, this changes my opinion. Why would you use the EJ22 heads if your EJ25 heads are good? Use a thin .027 hg like I did and bump the CR on your EJ25. The EJ22 heads are a down grade. But if your EJ25 heads have bent valves, then it would be a good cheap option. Get the Delta cams while they are out. But remember, you are going to need an EJ22E manifold to make this bolt up.
If you need a manifold, pm me. I will sell you one for cheap. And if your heads are borked, I may be interested in picking them up for rebuilding if you will let them go cheap.
Lastly,
We are doing to R&D this weekend and plugging in the EJ22 ECU to the car. We want to see what differences we notice between the two. We will also have it on the dyno next month and will likely run it with both the 1.8 ECU and the 2.2...
Old 01-20-2005, 12:23 PM   #113
huck369
Member#: 26201
Charcoal
I haven't torn into it yet, but assume the valves are bent.
I just bought the car (wrecked) and the rad is pushed into the t-belt.
If I'm really lucky (which I usually am not) maybe a new t-belt will be all it needs, but I'd put money on some bent valves, and I'm looking ahead for my options.
And as I have a whole 92 MY EJ22 with a bottom end knock sitting in my garage, I can rob it to fix the 2.5, or at least it sounds like I can from what I've read in this thread.
It's my 20th Subaru, but have been mostly earlier EJ22's EJ18's and EG33's, EJ27's which are all non-interferance motors, so this will be something new for me.
But I have hope now anyways,
Thanks,
Huck
The originator of the SVX 5-speed swap
Old 01-20-2005, 12:55 PM   #114
huck369
Member#: 26201
Charcoal
Another quick question....
will I be able to run the 2.5 cams, and roller rockers in the EJ22 heads?
Huck
Old 01-20-2005, 01:21 PM   #115
Matt Monson
Member#: 832
99 2.5RS, '85 911
Huck
Nope. Totally different head design. Plus stock EJ25 cams aren't any more agressive than EJ22 cams anyways...
Old 01-21-2005, 10:26 AM   #116
CirrusWRX
Member#: 17439
2010 WRX STI SE
Gray
EJ22E manifold - You're referring to intake manifold, correct? They are virtually the same all the way up through the 2.2L lifecycle from 94ish - 00+ are they not?
Old 01-21-2005, 01:52 PM   #117
Matt Monson
Member#: 832
99 2.5RS, '85 911
read again. You cannot use an EJ22 manifold on Ej25 heads...
Old 01-21-2005, 02:47 PM   #118
huck369
Member#: 26201
Charcoal
But will have to to use a EJ22 intake manifold, when using the EJ22 heads on a EJ25....right?
Old 01-21-2005, 04:23 PM   #119
CirrusWRX
Member#: 17439
2010 WRX STI SE
Gray
Yes -
Matt, I think you might have a type-o which is causing confusion (or I'm just an idiot when it comes to the naming of the manifolds...)
You write:
That sentence is what screwed me up - do you mean EJ25E manifold? (all references that I am aware of regarding EJ22E is the 2.2L SOHC, am I wrong here?)
FINAL
EDIT: OK OK OK - I see what you were saying. You were saying to the guy if his valves are bent and his heads are toast and he DECIDED to go with the EJ22 heads (which you recommended against if his EJ25 heads are still good, which makes sense) then he would need the corresponding EJ22 manifold.
So class, in conclusion, the intake manifold needs to mate to your heads. EJ25 heads = EJ25 intake manifold
EJ22 heads = EJ22 intake manifold
REGARDLESS of what block you go with.
PHEW! Sorry for the momentary retardedness
-Cirrus "Master of the Obvious and Poor Reading Comprehension"
Old 01-21-2005, 06:37 PM   #120
Matt Monson
Member#: 832
99 2.5RS, '85 911
you got it.
-matt "master of the run-on thought"...
Old 01-31-2005, 10:18 PM   #121
G.Subramaniam
Member#: 64528
Bump--
Old 01-31-2005, 11:27 PM   #122
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Hey Matt! What is the part# for the headgasket you are referring to that is in bold above? Installing this gasket on my single (Siamesed) exhaust port 2.2ltr Outback Sport will yield an 11.5:1 compression ratio eh? Man.....got my head spinning.
So I can simply purchase this headgasket, take it to the dealership and they could install it without issue as if it was the stock headgasket? Interesting!
Kevin Thomas is offline   Reply With Quote
Old 02-01-2005, 08:20 AM   #123
huck369
Member#: 26201
Charcoal
Kevin,
The gaskets won't up your compression on your EJ22, it only ups the compression when you use EJ22 heads on the EJ25 block....its not the gaskets that bump it up...it's the heads, I think he's saying to use those gaskets as they hold up the best...
Huck
Old 02-02-2005, 09:21 AM   #124
Kevin Thomas
Member#: 110
1989 1989 XT6
Kevin,
Huck
Thank you Huck! I read kinda fast at work and sometimes do not get the whole 'gist' of the thread and/or posts. I'm relieved I won't be spending any money on this now. If it were just gaskets that would need changing, I'd pretty much be in trouble.
Old 02-04-2005, 08:02 PM   #125
Matt Monson
Member#: 832
99 2.5RS, '85 911
yeah Kevin,
Hukc hit the nail on the head. Now, Cometic might make a thinner than stock HG that would let you do something like what I have done on my 2.5RS. It might be worth pursuing for some cheap power.
And don't pay the dealership for that job. It is a weekend job that just requires a certain amount of attention to detail. But it is not hard...
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 35 12-13-2016 04:50 PM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 11:55 AM
Tuning hp and torque curve w/ low compression and high compression pistons FuJi K Normally Aspirated with bolt-on Forced Induction Powertrain 22 10-14-2001 08:25 PM
High Compression Jgrahn555 SVX Forum Archive 7 04-16-2001 01:31 AM
High compression pistons for NA? bsquare Normally Aspirated Powertrain 7 04-07-2001 11:56 AM
