Welcome to the North American Subaru Impreza Owners Club Thursday January 18, 2018
Old 09-14-2010, 02:45 PM   #1
mar1asynger
Member#: 45808
2003 WRX Wagon
JDM Sedan'd Sonic Yellow
Default Attention Retrofit Guru's!!
I recently picked up a cheap set of eBay bugeye projector headlights. I want to retrofit a decent HID projector into them, what size projector would fit in there? I realize I probly need to measure the diameter and post it, but I figured I'd ask anyway. Also, I was planning on using one of the Hella halogen high beams, unless someone has any better ideas... Thanks!
I'm planning on taking lots of pics during the process as well. Thanks.
mar1asynger is offline   Reply With Quote
Old 09-14-2010, 07:57 PM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
First off, we're going to need ATLEAST a link to the headlights you purchased.
Secondly, glad to hear there are still some smart people out there who won't simply throw in an ebay HID kit and call it a day.
I personaly used Infinity FX35 BI-Xenon projectors (has both high and low beams in the same housing). If you go this route, make sure you get the clear lens version. If you want to get all your retrofit stuff in one spot, check out the 'the retrofit source .com'
Best of luck with your project.
skingfreak is offline   Reply With Quote
Old 09-15-2010, 02:58 AM   #3
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Pretty sure he got the double halo ones. He said projector headlights and there is only one eBay light that is.
Byzantium is offline   Reply With Quote
Old 09-15-2010, 11:37 AM   #4
mar1asynger
Member#: 45808
2003 WRX Wagon
Exactly the ones, they are those cheap chauncy halo projector ones haha. I took both lenses out of each one already, I didn't get a chance to measure tho. I'm only using the black plastic housing. I will likely put some thick vinyl over the whole face too. Someone suggested heating a clear sheet of plastic to mold it to the shape of the headlight, but that sounds like a pretty difficult DIY...
Old 09-16-2010, 01:33 AM   #5
ryan2.5
Member#: 167205
2004 N.F.D
04 STi. FP Red + Meth
i think the best you will be able to do is find a set of hella projectors to fit inside. Your lights will turn out WAY better to just retro your oem lights. You will have plenty of room to use bi-xenons
ryan2.5 is offline   Reply With Quote
FS SOCAL: 04-05 HID Projector Retrofits & JDM HID fog retrofits BiggSean Exterior/Styling 6 10-13-2009 09:32 PM
Wiring Guru's.. Well, maybe not even Guru's. FederalAuditor Subaru Conversions 2 01-04-2005 06:55 PM
A few questions that need a guru's attention rstaph Tri-State Area Forum 20 08-08-2002 10:52 AM
A few questions that need a guru's attention rstaph New England Impreza Club Forum -- NESIC 9 08-07-2002 03:03 PM
A few questions that need a guru's attention rstaph Newbies & FAQs 8 08-07-2002 01:20 AM
