Welcome to the North American Subaru Impreza Owners Club Saturday April 17, 2021
Old 05-01-2017, 12:27 AM   #1
TrackHo
Member#: 407919
2011 WRX
Default My Experience with Southbend Stage 3 Daily
So I have almost 5K on my stage 3 daily Southbend clutch. My 2011 WRX is stage 2, protuned and puts out approx 300HP/305WTQ. I blew a head gasket at the track at 61K, so had a new clutch thrown in as install was basically free with the motor pulled. At first I was hesitant to spend $830 on a clutch- but Kent at Turn In Concepts talked me into it. I don't drag or do nasty launches, it's my DD and trackcar a few weekends out of the year.
1) the first 1K miles were a tad rough in stop/go with the grabby/judder deal, got better at 2K, and got much better after 3K.
2) I gotta admit- I smoked the piss out of it a couple of times in the first 500 miles. I pride myself on my ability to use a clutch- but it was tough- all good now
3) so at approx 3K, the clutch started slipping at peak torque in 4th---****. I emailed Kent at TIC, he recommended I speak with Dave at SB. Dave recommended I check the adjustment and sure enough, the clutch rod was too long- not letting the pressure plate apply full pressure.
4) so now it's adjusted properly, engagement feels way better and ZERO slipping no matter how hard I try--so it's bitchin
5) I'll try to give updates as I progress- customer service at Southbend is outstanding
TrackHo is offline   Reply With Quote
Old 07-10-2018, 01:55 PM   #2
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Any update. Considering this clutch
silversurfer05 is offline   Reply With Quote
Old 07-11-2018, 07:34 AM   #3
point78
Member Sales Rating: (1)
Member#: 344329
2008 Wrx, 6mt
I absolutely love mine.
Buy this clutch...
point78 is offline   Reply With Quote
Old 07-11-2018, 01:51 PM   #4
Zmanwrx23
Member Sales Rating: (3)
Member#: 438620
2006 WRX Sedan
CGM
which stage 3 do you have? I found one that's full-faced on one side and segmented on the other, then one that's segmented on both sides?
Zmanwrx23 is offline   Reply With Quote
Old 07-11-2018, 02:14 PM   #5
JourdanWithaU
Member Sales Rating: (2)
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Southbend has 3 flavors for each stage. Daily, Endurance, and Drag.
Daily is full faced both sides. Endurance is the full face and segmented on opposite sides. Drag is segmented on both sides.
JourdanWithaU is offline   Reply With Quote
Old 07-12-2018, 10:31 AM   #6
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
thanks for this. Makes more sense now that I'm looking at all the options again.
Old 07-13-2018, 12:33 PM   #7
silversurfer05
Member#: 366241
Dgm
Stage III daily is my leading choice at the moment, can anybody running above 350 wheel torque? I hear that aftermarket clutch is combined with the five speed and Torchh result in blown third gears
Old 07-13-2018, 12:35 PM   #8
rexbanner
Member#: 197218
2009 Impreza WRX
Dark Grey Metallic
I have the stage 3 daily on my 2009. After the initial break-in, it feels close to stock in terms of pedal effort and engagement. It also does not chatter at all.
Mods are: IAG block, Blouch 440XT + all supporting breathing mods.
It's an outstanding clutch.
rexbanner is offline   Reply With Quote
Old 07-13-2018, 12:52 PM   #9
silversurfer05
Member#: 366241
Dgm
Also compared to the stock clutch how heavy does it feel pedal effort wise? Don't want to have to re-weld the firewall for the second time. I don't have that many kidneys to sell
Old 07-14-2018, 12:23 PM   #10
rexbanner
Member#: 197218
2009 Impreza WRX
Dark Grey Metallic
Pretty close to stock pedal effort.
My firewall welds were creaking on me with the stock clutch, so my tuner shop fab'd up a bracket similar to this:
https://www.reflectedimagemotorsport...ester-xt-09-13
I haven't had any issues in the ~10,000 miles I've put on this build with 352 whp and 344 wtq. I also have the Moore Performance transmission blast plates, though I can't say if these actually do anything (they can't hurt...)
http://shop.mooreperformanceparts.co...i-2280992.aspx
Fingers crossed that it all holds together.
Old 07-14-2018, 10:25 PM   #11
silversurfer05
Member#: 366241
Dgm
I think im going with the clutch master cylinder brace frim rallitek or circuit motorsports and the grimspeed brake cylinder brace. The clutch brace has huge effect when they measured with a guage for movement. If it goes again im swapping a stock motor in and selling up it straight up selling
Old 08-16-2018, 12:49 AM   #12
silversurfer05
Member#: 366241
Dgm
Pulled the trigger on the stage III daily. Hope the firewall holds up with the added weight on the clutch pedal
Old 08-16-2018, 07:28 AM   #13
point78
Member#: 344329
2008 Wrx, 6mt
I have the circuitmotorsports & grimspeed units, along with the 6mt stage3 daily.
Little over a year now, no issues.
Old 08-16-2018, 10:11 AM   #14
silversurfer05
Member#: 366241
Dgm
Was it originally a 5spd?
Old 08-16-2018, 12:52 PM   #15
point78
Member#: 344329
2008 Wrx, 6mt
Yes. Always has stock clutch with the 5mt, then had stock clutch with the 6mt swap, then the southbend daily 3
Old 08-20-2018, 03:16 PM   #16
EightTenths
Member#: 468430
I just got a stage 3 daily. I was expecting initial break in to feel on/off and grabby but it wasnít. Very natural engagement and modulation. Pedal feel is heavier but nothing worse than E36 BMWs. 230 miles so far and it will probably get easier.
EightTenths is offline   Reply With Quote
Old 08-27-2018, 02:43 PM   #17
rexbanner
Member#: 197218
2009 Impreza WRX
Dark Grey Metallic
It's very heavy at first and over time has a near-stock feel.
Old 09-17-2018, 12:14 PM   #18
2stepgoespowpow
Member#: 450143
How much whp/wtq you making? Hows it handle launches?
2stepgoespowpow is offline   Reply With Quote
Old 11-20-2018, 09:26 PM   #19
silversurfer05
Member#: 366241
Dgm
Hes making 352/344
Old 12-19-2018, 12:15 AM   #20
silversurfer05
Member#: 366241
Dgm
Update on my stage III daily. just drove the car for 150 miles today and I got to say it definitely feels like stock. If not lighter. Havenít driven steak in almost a year but first gear does seem to have a little slip to it so it does drive similar to stock as well as far as first year engagement. Will update once break in miles are over and full tune is finished
Old 01-29-2019, 10:57 AM   #21
nerz
Member#: 319133
2011 STi
Car is tuned for 360whp/400tq, just did a hard launch at 5k and the Stage 3 daily slipped through 1st and then once I shifted to 2nd it slipped and bounced off the rev limiter. Seeing how this is rated for 590ft/lbs do I have unrealistic expectations or is there something mechanically wrong going on?
nerz is offline   Reply With Quote
Old 01-30-2019, 02:02 PM   #22
Evil_11Sti
Member#: 497100
2011 STI
Red
I have the stage 2, previous owner said it was put in 40k miles ago. It feels strong still. It is a bit noisy, that's my only complaint. But it is holding 344/358 just fine.
Evil_11Sti is offline   Reply With Quote
Old 02-01-2019, 06:38 PM   #23
Max Capacity
Member#: 149347
05 LGT ,09 SpecB
Black/silver
I've had the Moore Blast Plates for a few years now, I love them. The 5MT fight's me going into 3rd gear at high RPM's. I feel all shifts are better.
Max Capacity is offline   Reply With Quote
Old 02-02-2019, 07:33 PM   #24
silversurfer05
Member#: 366241
Dgm
This an sti stage 3 daily? Cause i have the wrx stage 3 dailyís and its only rated to 400 or 450 crank Torque. And whats the milage on clutch
Old 02-04-2019, 05:26 PM   #25
nerz
Member#: 319133
2011 STi
It's on my 2011 STi so it better be the STi version. Mileage is 1-2k miles properly broken in.
