Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 12-25-2020, 01:32 PM   #1
pigboat_2
Member Sales Rating: (22)
Member#: 247823
2006 Fxt
RBP
Default CNT V3 Equal Length header review
I recently removed my CNT V3 ELH to install an APS twin scroll setup, so I figured I would post a review of them for others' information.
According to my phone, I installed them early January of 2020, must have been a Christmas present to myself last year. That would mean they have about 7-8k miles on them. I swapped out an old set of CNT V2's for these because I simply liked the look more. The V2's treated me just fine, see my review of those here.
The setup on my car is (was) a Rock Steady Tuning rotated kit and a GTX3582r with an AGP .82 hot side. I have a rods/pistons motor with built heads and ARP 625's so my tuner (Torqued Performance) kept the boost pretty conservative in order to preserve the motor, at about 27-28 psi. I'm also at Denver altitude. I street drive the car, never taken it to the track and don't have a huge specific purpose for the car outside of enjoying driving it.
The car was dyno'd back in November at Cryotune Performance for a baseline. He has a Mustang dyno that is simply soul crushing when it comes to numbers. A stock STi will put down ~210 whp and a FBO STi on e85 will run low 300's. This is for relativity's sake, since most people would expect to see mid to high 300's on e85 and FBO. My Forester baselined at 516/457 and has no problems taking down other STi's that make up to 600 hp on other local dynos. Of course I'll upload the dyno sheet to showcase spool and the power curve.
I've been extremely happy with these headers; definitely the best low-cost option in my opinion. I've run the Invidia ELH with a similar setup and the design of the CNT V3 looks extremely similar to the Invidia. I have my oil cooler deleted and a steel Moroso oil pan too so fitment was not an issue.
Anyway, to keep things short, I love these headers and if you can get your paws on a set, I would recommend it. The flanges were not warped and seemed to seal just fine using quality gaskets, not the ones included with the headers.
Youtube vid of dyno pull:
Merry Christmas y'all!
pigboat_2 is online now   Reply With Quote
Old 12-25-2020, 05:08 PM   #2
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Sure looks like the driver side is leaking pretty good. Passenger side looks like a cold leak. What's the 2-bolt gasket surface look like? That's typically where leaks are worst.
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is offline   Reply With Quote
Old 12-25-2020, 08:21 PM   #3
pigboat_2
Member#: 247823
2006 Fxt
RBP
Is that Nick? This is the Foz we talked about on the phone the other day. I found quite a bit of oil in my intercooler piping. Thoughts?
What's a cold leak?
They were used OEM gaskets from head to manifold. Torqued to the FSM spec 29 lb/ft, but I did find that the center nuts were somewhat loose upon removal yesterday. Maybe with the flex head sockets the torque wasn't the same or something. The flanges seem to be square using a straight edge.
Old 12-26-2020, 09:08 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by pigboat_2 View Post
Is that Nick?
No this is Chris, I work with Nick.
What's a cold leak?
A cod leak is a leak between two metal surfaces that goes away once the parts involved expand from heat.
Interesting on that flange. Looks rusty. Is it carbon? Are the others carbon steel too? See if a magnet sticks to it.
__________________
vs.
Old 12-26-2020, 09:53 PM   #5
pigboat_2
Member#: 247823
2006 Fxt
RBP
Magnet sticks to all flanges.
I often notice water/condensation in the exhaust especially when it's cold. Side effect of e85?
Old 12-31-2020, 07:02 PM   #6
car_freak85
Member Sales Rating: (42)
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
USED exhaust gaskets?!? That would explain the leaks mentioned.
car_freak85 is offline   Reply With Quote
Old 01-01-2021, 02:09 AM   #7
pigboat_2
Member#: 247823
2006 Fxt
RBP
Oh well. I don't blame the flanges.
Old 02-15-2021, 06:53 AM   #8
Anglina88
Member#: 522393
Default Suggestion
From where I can get this part ?
Anglina88 is offline   Reply With Quote
Old 02-23-2021, 05:08 PM   #9
GK1707
Member Sales Rating: (2)
Member#: 373868
'04 STi
Any pics of fitment of this? Did you have to modify the u frame?
GK1707 is offline   Reply With Quote
Old 02-25-2021, 05:23 PM   #10
pigboat_2
Member#: 247823
2006 Fxt
RBP
No fitment photos unfortunately. I have this one that shows the clearance of the oil filter with a sandwich plate installed for my oil pressure/temp sensors, but that's it:
Why do you ask about the u frame? Have you encountered having to modify that to fit a header before? Maybe like a Manzo or something ultra crappy. But this fits fine...I have a deleted oil cooler is all.
