Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 01-03-2009, 05:20 PM   #1
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Default dynochart ATP GT3076R
My engine is not in the best of shape. Comp is good in all 4. 155psi c1 has small leakdown problem 8-10 %
I have a new engine being built. But heres the graph.
06STi is offline   Reply With Quote
Old 01-03-2009, 05:42 PM   #2
Boxer112
Member#: 78751
2017 Sti
ISM
mods???
Boxer112 is offline   Reply With Quote
Old 01-03-2009, 05:51 PM   #3
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
ATP GT3076R EWG (OEM location, EWG top of turbo hotside)
Tial 44mm EWG
Dwks 740's
Perrin V1 Fuel Rails
HKS Custom Catless Downpipe
JIC Ti Full 3 inch Catback
APS FMIC
APS Turbo Inlet
APS BOV
APS 70mm CAI
GM Boost 3 port Sillynoid
Cosworth Highflow Oil pump
Cosworth Airpump delete plates
Cosworth Studs
Cosworth Bearings
Cosworth Head Gaskets
link to my thread. http://forums.nasioc.com/forums/show....php?t=1667843
Old 01-03-2009, 06:34 PM   #4
sleepersti04
Member#: 146554
2004 STi WRB
30R
still makes power
sleepersti04 is offline   Reply With Quote
Old 01-03-2009, 06:40 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
gotta get them heads ported!!! Good power!
Old 01-03-2009, 06:47 PM   #6
CatfaceType-R
Member#: 81102
very odd graph
Old 01-03-2009, 07:11 PM   #7
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
I have some cosworth heads sitting next to me.
Originally Posted by sleepersti04 View Post
still makes power
Yeah not bad for cali 91 oct fuel.
Originally Posted by soon2bblackongold View Post
very odd graph
Why do you say that?
Old 01-03-2009, 07:13 PM   #8
subenerd
Member#: 72630
2004 STi
Tial 44mm EWG
Dwks 740's
APS FMIC
APS Turbo Inlet
APS BOV
APS 70mm CAI
Cosworth Studs
Cosworth Bearings
Why do you have two user names?
subenerd is offline   Reply With Quote
Old 01-03-2009, 07:15 PM   #9
TDagen
Member#: 163648
2002 Resurrected WRX
3750-6750rpm 300wtq and above roll that block till it goes... That ATP 3076 looks like a great turbo...stock location thats sweet...AND on 91
Old 01-03-2009, 07:24 PM   #10
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
I no longer have two. I forgot my log on to this account till it was fixed last week.
I plan to see how much I can get out of this. Then swap the new set up in.
Ah also I still have tgv's installed and working.
Old 01-03-2009, 07:42 PM   #11
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
very odd graph
The wavy curves is what stands out to me, looks like boost could be dialed in a bit better.
Infamous1 is offline   Reply With Quote
Old 01-03-2009, 07:48 PM   #12
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
I didnt tell them for full tilt. Told them I wanted to make this thing last a bit while I get the new motor done. Its a welcomed step up fro the pe1820 thats for sure...
Old 01-04-2009, 07:47 PM   #13
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
nice numbers! i got one on my ej205. =)
ownnij is offline   Reply With Quote
Old 01-05-2009, 07:25 PM   #14
DuCash
Member#: 198714
04' JDM STi EJ207
437whp/357wtrq Dom3 24psi
and how does it perform on the 205? as in spool up and top end characteristics?
DuCash is offline   Reply With Quote
Old 01-05-2009, 07:27 PM   #15
DuCash
Member#: 198714
04' JDM STi EJ207
lookin good for 91oct
Old 01-05-2009, 07:31 PM   #16
nick32
Member#: 160687
2025 Durge
viperrroni
very nice power!!
nick32 is offline   Reply With Quote
Old 01-05-2009, 09:02 PM   #17
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
400WHP/420WTQ on a stock block with C1 8-10% variable and you are talking about making the motor last.
Nice power for sure but your kidding right? I give it one good boost spike and that C1 drops. Not being an ass that's power to be envious of but I'm not even pushing my AXIS Stage 3 that hard and its mint.
Truly interested in seeing how long it lasts. Is this a DD or a do you just drive it occasionally?
Nice setup BTW
4ST-AIR is offline   Reply With Quote
Old 01-05-2009, 09:30 PM   #18
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Its a DD... Not kidding around... Why? Its been running fine. The c1 is a valve adjustment problem we think. Not piston.
You should see it on 105oct :-)
I was building a motor till the shop I got the two blocks from had a problem between the shop manager and shop owner. So I have put everything on hold.
Need to find a hook up on some parts now. How do you like your AXIS block?
Old 01-05-2009, 10:00 PM   #19
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
I love my AXIS SB and saving for the Signature Series Cylinder Heads.
Give Ron Williams a call you can pretty much get Ron 24/7 on his cell which is the exact number he has posted on the Raw Performance. My AXIS was built more for my driving habits but its also currently tuned knowing them as well . That engine just begs for more. On Q16 on a nice 70* night I make just under [email protected] 29psi which holds 96% of max WHP all the way to 7500RPM's.
Holy mother of god that's on 91 piss? I need to see timing, boost, IDC's ATM card. These #'s must be SAE Corrected but to what factor is the correction? 740's must be at 100% IDC's. My brain needs more input
Old 01-06-2009, 07:02 AM   #20
Uncle Buck
Member#: 140062
2005 STI ATP3076r
95' Eclipse gs
nice numbers and car man. i can't wait to do some internals and push up the boost on my atp.
Uncle Buck is offline   Reply With Quote
Old 01-06-2009, 07:13 AM   #21
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
^ be careful on your tune. My tune was bad.
Old 01-07-2009, 07:49 PM   #22
TDagen
Member#: 163648
What do you mean your tune was bad? Why what happened?
Old 01-07-2009, 10:07 PM   #23
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Lets just say..... I caught a my car boosting at 25+psi ,pulling timing and a few maps were off.
I took it to a so-cal shop and they fixed it for the most part.
Old 01-07-2009, 10:09 PM   #24
hanzo918
Member#: 82148
1992 Daihatsu
Charade
I'd go w/ TMIC
hanzo918 is offline   Reply With Quote
Old 01-07-2009, 10:11 PM   #25
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
how much boost are you currently running with this setup.
bhhamblin is offline   Reply With Quote
atp gt3076r to atp gt3582r modified titoune Built Motor Discussion 5 11-02-2008 03:46 PM
BNIB ATP gt3076r kmurphy Engine/Power/Exhaust 15 09-30-2008 04:27 AM
Fs Atp Gt3076r Used 1000km titoune Engine/Power/Exhaust 3 09-29-2008 03:47 AM
Wtt: Atp Gt3076r Stock Location titoune Private 'Wanted' Classifieds 3 09-27-2008 09:07 PM
FS: ATP GT3076r TEXAS tydawg2 Engine/Power/Exhaust 18 08-29-2008 09:50 PM
