Brakes & Suspension Forum sponsored by The Tire Rack |
02-19-2010, 07:17 PM | #1 |
Member#: 220114
NWIC
Vehicle:04 STi OBP |
Brembo brake pulsation after 6MT swap
Hi,
I just completed a full 6MT swap including the brembo front and rear brakes, now I have a pulsation when I apply the brakes. The pulsation is very intense as the speed of the car increases. At lower speeds it feels less intense but is still very noticeable. I have brand new Stoptech pads on the front and rear, the rotors are the factory original 5x100 brembos and have been turned and are within spec. The 6MT donor car was a 04 STi, my wrx is a 2006. I have bled the brakes using a vacuum hand pump and I have full pedal, I can apply the brakes at 50mph and bring the car to a complete stop faster than it did with the wrx brakes, so the brakes work, but something is definitely not right. I pulled the fuse on the ABS and still feel the pulsation, though I am not sure if it is quiet as intense. Does anyone have any suggestions on what could be causing this? I appreciate any help. Thanks, Derek
02-20-2010, 02:45 AM | #2 |
Member#: 237224
Vehicle:2004 WRX Wagon Stock Daily Driver |
Re: Brembo brake pulsation after 6MT swap
Im assuming that it only vibrates while stepping on the brakes. Not really sure but i think when you upgrade the brakes, you have to make sure that they are all gonna work together, maybe the brembo's are too much for your proportioning valve and brake master cylinder, or the pins on the brake calipers are sticking.
02-20-2010, 04:41 AM | #3 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 EJ207 S204 Wagon |
Try loosening and re-torque all the axle nuts.
02-20-2010, 11:36 AM | #4 |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
Pad deposits and/or rust buildup most likely
Rotor runout least likely bed them hard then look for other issues |
02-20-2010, 12:40 PM | #5 |
Member#: 220114
NWIC
02-20-2010, 12:44 PM | #6 | |
Member#: 220114
NWIC
Yeah, no vibration when driving without brakes applied. From all the reading I have done, I believe the master cylinder is the same from the STi and WRX and thought this was a fairly common upgrade. I'll take them all apart today and check the pins and look for anything obvious. |
02-20-2010, 12:46 PM | #7 |
Member#: 220114
NWIC
02-21-2010, 01:23 AM | #8 |
Member#: 220114
NWIC
I put the wrx front calipers back on using the STi axles, knuckles, and hubs. Problem went away. Frustrated that I can't figure this out, everything looks right. Still have the rear brembos on with no problem.
02-21-2010, 02:16 AM | #9 |
Member#: 170747
BAIC
Vehicle:2004 WRX Wagon PSM |
Who turned the rotors?
Have you checked the runout? Did you try rebedding the brakes? |
02-21-2010, 10:50 AM | #10 |
Member#: 220114
NWIC
Cruise control does not work after 6mt swap. | Dubstar112 | Transmission (AT/MT) & Driveline | 10 | 11-03-2010 05:31 AM |
running pig rich after 6MT swap | Team Scream | Open Source Reflashes | 51 | 01-17-2009 09:38 PM |
Noise after 6MT swap ... | daWagon | Transmission (AT/MT) & Driveline | 17 | 01-15-2009 05:33 PM |
Horrible grinding/rattling on startup after 6mt swap | Cyclops | Transmission (AT/MT) & Driveline | 8 | 06-03-2008 01:56 PM |
F/s:nj_wrx Parts Left Over After 6mt Swap! | rodknock02 | Drivetrain | 6 | 02-01-2008 02:40 PM |
