Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 02-07-2014, 09:23 AM   #3351
shamrock 05
Member#: 120057
2018 WRX (base) 6spd
Originally Posted by iconone View Post
^ that would be nice but I have no problems reading the gauges the way it sits. They probably make them that way so both passenger and driver can see them.
Only Mavrick needs to see the gauges, Goose speaks when spoken too
shamrock 05 is offline   Reply With Quote
Old 02-07-2014, 09:45 AM   #3352
awenthol
Member#: 355024
2013 DGM STi Sedan
Originally Posted by alt14 View Post
Thanks! And that'll be short enough to have eight feet of wire from the boost sensor to an smy bezel?
You can run an 8ft harness through the passenger side firewall, through the dash and to the smy pod, with a bunch of wire to spare.
awenthol is offline   Reply With Quote
Old 02-07-2014, 09:55 AM   #3353
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
:lol that's true but what if goose is your tuner?
iconone is offline   Reply With Quote
Old 02-07-2014, 06:10 PM   #3354
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Thank you sir, the drivers side fender should be enough then.
alt14 is offline   Reply With Quote
Old 02-08-2014, 06:33 AM   #3355
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Are you guys with 08+ models running your wires through the firewall behind the intercooler or through the left fender area? I want to pass through the fender but not sure if eight feet will be long enough.
The first time I ran wires to the dash, I used the big grommet behind the downpipe. I just pushed it in, passed the wires through, then pulled it back out into position. The wires were ran from the lower end of the grommet so that they were less visible.
When I decided to replace my boost gauge, I pulled everything out and used the grommet behind the intercooler following Overland04's gauge install thread. I had my gauges over the cluster trim, but then made my own triple gauge pod to go on the clock area. Did it because I thought it was better to have all the wires coming through the same place.
cianuro is offline   Reply With Quote
Old 02-08-2014, 09:34 AM   #3356
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Originally Posted by cianuro View Post
The first time I ran wires to the dash, I used the big grommet behind the downpipe. I just pushed it in, passed the wires through, then pulled it back out into position. The wires were ran from the lower end of the grommet so that they were less visible. When I decided to replace my boost gauge, I pulled everything out and used the grommet behind the intercooler following Overland04's gauge install thread. I had my gauges over the cluster trim, but then made my own triple gauge pod to go on the clock area. Did it because I thought it was better to have all the wires coming through the same place.
It's been a while, but I don't remember a grommet in that location... It might have gone away prior to the 2011.
There was a reason why I went through the fender...
Louie is offline   Reply With Quote
Old 02-08-2014, 10:38 AM   #3357
cianuro
Member#: 235475
2008 WRX
Originally Posted by Louie View Post
It's been a while, but I don't remember a grommet in that location... It might have gone away prior to the 2011. There was a reason why I went through the fender...
Old 02-08-2014, 11:16 AM   #3358
wutdadilyo
Member#: 53967
2011 WRX Premium
Satin White Pearl
There is a grommet location below and behind the top mount intercooler on 2011 wrx. I know this because I made a video on how to install a boost gauge that I'm currently in the process of editing to be put on YouTube.
wutdadilyo is offline   Reply With Quote
Old 02-09-2014, 02:08 AM   #3359
alt14
Member#: 271928
2014 WRX Limited
I'd rather go through the fender as well, it just seems more of a simple route then from behind the intercooler but that's just me.
Old 02-09-2014, 08:15 AM   #3360
hoffmanEstates
Member#: 122043
04 wagonier
psm
02-07 has grommets under the brake booster area its a little tight to get to but they exist.
idk if that goes for the new ones also
hoffmanEstates is offline   Reply With Quote
Old 02-09-2014, 10:28 AM   #3361
alt14
Member#: 271928
2014 WRX Limited
That's what I did on my 07 for all my wires but in 08 they did away with that pass through.
Old 02-09-2014, 10:45 AM   #3362
J.biz
Member#: 191825
2009 WRX Hatch
Here's a video of my simple gauge setup! Defi red racer boost gauge 09 wrx. Great gauge and matches well.
J.biz is offline   Reply With Quote
Old 02-09-2014, 11:00 AM   #3363
wantsti
Member#: 134764
04 sti
java black pearl
Here is a bad picture of my Speedhut Revolution custom gauges. They are factory matched and all have a pink STI logo on them and light up red.
AF
boost
oil temp
oil pressure
water temp
wantsti is offline   Reply With Quote
Old 02-09-2014, 02:03 PM   #3364
eckman
Member#: 96100
'06 Impreza WRX/STi
Would like to see your Speedhuts up close and at night time.
eckman is offline   Reply With Quote
Old 02-14-2014, 09:04 PM   #3365
awenthol
Member#: 355024
2013 DGM STi Sedan
JCS Triple Pillar with AEM Wideband, Defi RR Pyro, and Defi RR Boost/Vac
SMY Clustermaker with Defi RR Oil Pressure and Defi RR Oil Temp
HTC Rezound with Torque and round it off with a Nexus 7 for WIN
I know I need to get better pictures but the car is in the garage until spring. Still working on Fuel Pressure, Trans Temp and Rear Diff temp gauges + E85 gauge
Old 02-14-2014, 09:14 PM   #3366
plucebo
Member#: 93682
2002 wrx no more STi
WR Blue
Originally Posted by azn0boi04 View Post
this is what it is now... until i get my pod...for my 95 impreza with ej20g...oil pressure/boost/water temp...
Nice shift boot.....MC Hammer called he wants his pants back!!
plucebo is offline   Reply With Quote
Old 02-15-2014, 10:10 AM   #3367
Vt_rdr
Member#: 363640
2010 WRX
Hey man, you can't touch that.
Vt_rdr is offline   Reply With Quote
Old 02-16-2014, 11:22 AM   #3368
sethsubie34
Member#: 381684
Nice!
sethsubie34 is offline   Reply With Quote
Old 02-20-2014, 12:35 AM   #3369
rex864
Member#: 371854
2014 WRX
I laugh so hard looking at the pics in this Thread, 99% of the cars have a half tank of gas or less and 50% of them are at a 1/4 tank or less.. When I post my pics once I get my JCS- triple pod I am sure I will fall under the half tank club myself.. All great setups so far love all the pics..
rex864 is offline   Reply With Quote
Old 02-20-2014, 01:34 AM   #3370
fushnica2
Member#: 248151
2013 STI
Ice Silver Metallic
JCS pods + AEM boost and A/F ratio. (and I just realized I posted this pic in this thread already last summer...)
fushnica2 is offline   Reply With Quote
Old 02-20-2014, 01:35 AM   #3371
alt14
Member#: 271928
2014 WRX Limited
I guess the gauges took priority over gas?
Old 02-20-2014, 10:53 AM   #3372
MountMorse
Member#: 290140
2007 WRX
Red Garnet Pearl
Mounted my Accessport on a CB mic clip on the third blank gauge spot. Can take it on and off with ease. Also hvac and dash are RED LED
MountMorse is offline   Reply With Quote
Old 02-20-2014, 07:38 PM   #3373
wantsti
Member#: 134764
04 sti
java black pearl
Old 02-20-2014, 08:02 PM   #3374
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
work in progress =\ idr if i've posted about this before
A Fatal Ode is offline   Reply With Quote
Old 02-20-2014, 08:06 PM   #3375
WRBHatchLfe
Member#: 364618
2012 Hatch Stage 2
How satisfied are you with the JCS A-Pillar!? There is an airbag behind that pillar, correct? Does it stay disabled after install or is it still usable?
Thank you,
Dominic
WRBHatchLfe is offline   Reply With Quote
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
