Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-17-2005, 08:31 AM   #1
bajatuner
Member#: 83774
2010 Legacy GT
Default Finally Finished...20psi!!
Well I finally got a re-tune yesterday so my baja project is finally done for now...
Modifications are:
VF22 port and polish
Perrin Inlet
Perrin Short Ram
JDM STi TMIC
JDM BOV
Samco Intercooler Hoses
Gutted OEM uppipe
TurboXS Downpipe
3" custom Magnaflow catback
High-flow cat
Walbro 255
Perrin Modded Injectors
HKS EVCS
Ecutek Tuned to 20psi (Thanks to Dave at MSPT for a great tune)
Car feels amazing...now i just need to get it to the dyno and the track...and my next project is to figure out how the hell Im gonna get a fmic on the baja.
bajatuner is offline   Reply With Quote
Old 08-17-2005, 09:01 AM   #2
ez bturbo
Member#: 56048
2004 baja turbo 5spd
black/dark gray
nice setup -- what kinda of power are you expecting to put down?
ez bturbo is offline   Reply With Quote
Old 08-17-2005, 09:48 AM   #3
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
nice! congrats on finishing got any finished picts or installation picts? I still need to figure out a solution for the STI TMIC hose being short, I think the 3" pipe extension is what I'll need to end up doing.
02_Forester is offline   Reply With Quote
Old 08-17-2005, 11:50 AM   #4
bajatuner
Member#: 83774
2010 Legacy GT
Ok so there is supposed be a browse button on the bottom of the screen when posting where you can put in an image from your computer(according to a tutorial post on how to post pics that i just read) but I do not have one there...I have enough posts to put up pictures, can someone help me!?
Old 08-17-2005, 03:17 PM   #5
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
you should be able to just type in the IMG command with the image URL.
[img]url=http:www.....[/img] to get your images to show.
Old 08-17-2005, 03:43 PM   #6
bajatuner
Member#: 83774
2010 Legacy GT
The photos are not published to the web...they are just on my computer...that isn't working...
Old 08-17-2005, 03:54 PM   #7
KC
Member#: 442
17 Imp Spurt
00 S2k | 14 BRZ (SSC)
You need to publish them to a website that allows linking.
Something like we-todd-did-racing.com has free image hosting.
--kC
KC is online now   Reply With Quote
Old 08-17-2005, 07:13 PM   #8
bajatuner
Member#: 83774
2010 Legacy GT
Finally some pics up...if there is anything more specific you would like to see let me know...
Old 08-17-2005, 07:30 PM   #9
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
so you only have one cat now? do you think this cat is comparable to a random tech cat (approx 502cfm flow rate at normal test pressure)? where did you find the hks evcs, and was it an easy install? thanks, im nosy...
btw, pics look nice!
cliffhanger is offline   Reply With Quote
Old 08-17-2005, 07:48 PM   #10
bajatuner
Member#: 83774
2010 Legacy GT
Yea only one cat...Im not too sure specifically what the cat flows; the exhaust along with tuning are the only things I didn't personally install on the car. When the exhaust was fabricated the stock cat didn't fit right, the guys at mufflex where the exhaust work was done told me that I could have a high flow installed for more money so impulsively I just said go for it. As far as the EVCS goes I got an amazing deal on an older version of it. The install is identical to that of a new one, and is very easy to do. The only difference between mine and the new ones is that it doesn have the screen, it is simply a low boost button, high boost button, and a manual button with a dial in the front. Im sure there are some other things that the new version has but for $500 more i didnt find it necessary to pass up the great deal I got on this.
In the 4th picture you can see the selenoid and all the hoses for the evcs just to the left of the intake...Below is a pic of the control unit that I mounted just below and to the left of the steering collumn...
Old 08-18-2005, 01:56 AM   #11
wikidwrx
Member#: 36607
Wow, that's nice. Congrats on your setup. With your VF-22 setup I'm guessing 290-300WHP?
wikid
wikidwrx is offline   Reply With Quote
Old 08-18-2005, 08:01 AM   #12
bajatuner
Member#: 83774
2010 Legacy GT
Thanks...Im actually hoping for the 320-330whp range...may seem a lil high but when I was tuned at only 15.5psi I was just over 260. I believe the average rate of increase per pound of boost is approximately .05%whp and .08%torque(and that is just increasing boost regardless of EM). At that rate I should theoretically be nearly exactly at 325. Im not saying that I am; I wont claim anything until its been on the dyno, but going by feel it is definately possible...I've had two separate tuners work on my car and they both estimated around the same area, even slightly higher by one of them. Also, from getting pulls with some friends I can see the crazy difference between 15.5 and 20 psi...I used to pull slightly on my friend w/ a modded 350z and now I see him in my rear view in a second. The tune on my car is wonderful too which may create a sense of more power than really is there. I am spooling up starting at just under 3000rpms and hitting 20psi in all gears but 1st just at around 3700rpms; boost peaks at 18ish in 1st and holds to 15 at redline. Ill try to get some video/audio clips up of the car during a pull...20psi sounds amazing!!
Old 08-19-2005, 08:52 PM   #13
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Damn, I've got Baja envy
Chris N is offline   Reply With Quote
Old 08-19-2005, 10:53 PM   #14
Bigkahuna
Member#: 75960
Hey bajatuner, I have yet to see your Baja even though I may be your neighbor in Newark. Looking forward to spying yours on the road someday! (I'll be in the black/obsidian n/a Baja with a kayak roof rack.)
Bigkahuna is offline   Reply With Quote
Old 08-20-2005, 10:45 AM   #15
bajatuner
Member#: 83774
2010 Legacy GT
Where in Newark you live? Im living at home in NY for the summer but Ill be back to DE in a few days for school...
Old 08-20-2005, 12:06 PM   #16
Bigkahuna
Member#: 75960
School as in, the U of D? I'm in Pike Creek which is technically Newark. With so few Bajas around here I'm sure I'll see yours sometime.
Old 08-20-2005, 12:45 PM   #17
bajatuner
Member#: 83774
2010 Legacy GT
Yea Im at UD, my last year there...Im sure ill run into ya on the road sometime. I've only seen one other baja around the area, same color as yours...do you have an exhaust?? if so it coulda been you
Old 08-21-2005, 12:54 AM   #18
koopkoop2
Member#: 94100
Ver ynice
koopkoop2 is offline   Reply With Quote
Finally finished the EJ22T swap. first driving impressions Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 30 11-14-2001 07:41 AM
Finally finished my installation T-REX Car Audio, Video & Security 16 05-12-2001 09:41 PM
Finally finished sub install! ImprezedRS Car Audio, Video & Security 9 03-22-2001 08:02 PM
It's Finally Finished Gerry Car Audio, Video & Security 0 11-24-2000 01:32 PM
Finally finished N/A Technical Forum Archive 8 06-14-2000 06:54 PM
