Welcome to the North American Subaru Impreza Owners Club Sunday July 21, 2024
Old 12-19-2015, 11:56 PM   #1
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Default Dome light/door ajar dash light flicker during WOT?
2003 WRX wagon. During WOT pulls I sometimes get the door ajar indicator on the gauge cluster flashing on and off as well as the dome light flickering on.
I've checked all the doors and rear hatch and everything will be closed tightly when this has occurred.
It's an intermittent issue. I have had some trouble recently with my battery terminals due to their age but I have fixed that problem, I think.
Anyone else ever experience anything like this?
monkeyposeur is offline   Reply With Quote
Old 12-20-2015, 07:26 AM   #2
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
You have a weak door switch somewhere. Examine all the switches and wiring for corrosion or damage, clean/adjust/replace as necessary.
Mulder is offline   Reply With Quote
Old 12-20-2015, 12:38 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I agree with Mulder's advice. I would suspect the driver side door first since it gets the most use. Dirty switch contacts most likely.
Cougar4 is offline   Reply With Quote
Old 03-03-2016, 12:51 AM   #4
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
Update. I narrowed the issue down to the driver's side door. Installed a new OEM switch and problem is resolved.
Old 03-03-2016, 10:50 AM   #5
Cougar4
Member#: 53443
Winestone
Good deal. Thanks for the update.
Old 03-09-2016, 09:43 PM   #6
Lucien_Gauvin
Member#: 442228
2006 Subaru Sti
Grey
I had the same issue in my 06 Sti. Checked all my sensors and no corrosion/damage/interference. Seems to have gone away for now. I think its due to the fact that my rear drivers door wont ever close all the way. Guess I need to re-align the door pins.
Lucien_Gauvin is offline   Reply With Quote
Old 03-09-2016, 10:10 PM   #7
meaves62
Member#: 442231
Default Loose door latch...
I have a 2004 Outback Sport that had a similar issue. The screws to the door latch would come loose and allow the door to shift a little in turns when I had my leg against the door. Some Locktite fixed the issue.
meaves62 is offline   Reply With Quote
Old 02-12-2024, 07:22 AM   #8
sboyd90
Member#: 535130
I have a 2019 wrx. My driver side door ajar light flickering on and off randomly. Replaced the door jamp. It fixed it for a little bit then started to recently act up again.
sboyd90 is offline   Reply With Quote
