Welcome to the North American Subaru Impreza Owners Club Friday April 10, 2020
Old 08-03-2013, 06:28 PM   #1
twoolverton06
Member#: 357363
2007 WRX Limited
Default HELP! Loss of boost and CEL P2433 NS P2431..
Hey guys, I recently threw a CEL of P2433 and P2431, both relating to the secondary air injection system. I tried to clear them using my AP, but it wont clear. I have checked the connections to the valves but nothing. Now, my car wont run over 3.5 lbs of boost, when normally it hits 15. I own a 2007 WRX Limited 4EAT. Mods are just catless invidia DP and COBB Accesport V2, with stage 2 oct 91 OTS Map. Any suggestions will be appreciated. THanks!
twoolverton06 is offline   Reply With Quote
Old 08-03-2013, 07:18 PM   #2
twoolverton06
Member#: 357363
2007 WRX Limited
Anybody deal with this before? Im at my wits end with this
Old 08-03-2013, 07:25 PM   #3
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Well you are already running a tune that isn't supported by the parts you have on the car. The OTS Cobb map is for a CATTED downpipe.
Depending on how long you've been running like that = guessing the cause of the issues you face now is where I would start.
Napalm3nema is offline   Reply With Quote
Old 08-03-2013, 07:37 PM   #4
Vinnie
Member#: 7869
2011 STi
TheUrbanRallyProject.com
Try flashing the OEM map and see if you are still getting low boost. If not then its the map
Vinnie is offline   Reply With Quote
Old 08-03-2013, 08:24 PM   #5
twoolverton06
Member#: 357363
2007 WRX Limited
Ok ill try that. Idk why it would suddenly drop boost, I've been running that map for about 5k miles now without anything going wrong.
Old 08-03-2013, 08:34 PM   #6
twoolverton06
Member#: 357363
2007 WRX Limited
Definitely not the map. Still running low boost.
Old 08-03-2013, 08:56 PM   #7
SubieStiGal
Member#: 362014
11 STi Stage 2
Lightning Red
I'm curious to know if it has anything to do with running the catless DP. I was just on the phone with Cobb Tuning Surgeline because I have a catless Invidia DP and catback exhaust and intake that I haven't installed yet on my 2011 STI due to thinking I needed to get an opensource tune afterward to prevent boost creep. I was told by surgeline that the boost creep is a mechanical issue and that it can only actually be eliminated by doing an external wastegate, uppipe with dump pipe, new fuel pump, injectors and then a pro tune. He also told me it would be ok to flash a Stage 2 map with the catless DP temporarily as long as I monitor my boost levels (same as what you're doing).
Now I'm thinking I'll just wait to do my exhaust until I get my ewg and other goodies if you find out the Stage 2 map is the cause of your issue
SubieStiGal is offline   Reply With Quote
Old 08-03-2013, 08:58 PM   #8
SubieStiGal
Member#: 362014
11 STi Stage 2
Lightning Red
And I just saw you posted that it wasn't the map lol. Sorry. Guess you can disregard my other post.
Old 08-03-2013, 09:00 PM   #9
twoolverton06
Member#: 357363
2007 WRX Limited
Ya idk my tuner told me that running a catless dp with the stage 2 setup would be totally fine....now i have two hard cels that wont clear and cant hit boost, so basically my car is in limp mode. This is bs cause i gotta drive 1200 miles to go to my wedding in two weeks lol
Old 08-03-2013, 09:05 PM   #10
twoolverton06
Member#: 357363
2007 WRX Limited
whats throwing me off is the hard cels of p2433 and p2431...both of which have to do with that stupid Secondary Air Injection System. I have the blockoff plates for it, i was just wondering if anyone else experienced a loss of boost when the cels were thrown.
Old 03-25-2020, 11:08 PM   #11
Birdherpzfishing
Member#: 511268
2011 Sti hatchback
Satin Pearl white
hey man i know its been a minute since this post but i want to know what in the end you resorted doing with this issue because i too have now put block off plates and deleted thge system which now throws those same p2431 and p2433 codes. i ran an accessport reflash stage2 map since i have a whole cobb set with dp, exhaust, bv, and air induction with the maf and boost control solenoids... i dont know if i should dish out the $600 it may take to do a pro tune or if i can still save the car and some $$$ myself... please help me thank you
Birdherpzfishing is offline   Reply With Quote
