Welcome to the North American Subaru Impreza Owners Club Tuesday January 28, 2020
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 01-23-2014, 11:42 PM   #1
SteamSpeed.com
Member#: 339860
Default SteamSpeed's Project Domino: 2001 RS + V8 ej207 driveline
Welcome to SteamSpeed's project Domino! We are taking a 2001 RS coup that has been sitting a few years with a blow motor and an unfortunate turbo conversion and bringing it back to life with a JDM Version 8 STI drivetrain, a ton of work, and buckets of degreaser.
Q: Why start with the GC8 coup shell (technically a GM in the US market)?
A: Simple, the GC8 coup is arguably the besting looking Subaru body style ever sold in the US.
Q: Why a Version 8 STI powertrain?
A: We feel the JDM EJ207 + 6-speed is a great fit for a lightweight track car to throw around. There are already a ton of threads out there that extol the virtues of the EJ207 for the uninitiated, so we won't get into that here. We went with the Version 8, because we need a shop car to test our twin-scroll stock location turbos. Also the version 8 comes with great heads stock. We are not acutally using the full version 8 driveline though. We are upgrading to 5x114 hubs, axles, etc. from a 2007 USDM STI.
....stay tuned, more to come....including pics.
SteamSpeed.com is offline   Reply With Quote
Old 01-24-2014, 11:48 AM   #2
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Very nice! Is this Sams car?
My dream is to buy a set of EJ207 big port heads. Have the machining do to run my usdm avcs sensors etc. Then ill be able to run my usdm 04 sti 32bit ecu and harness.
I cant wait to see what you folks do.
Ian,
Old 04-13-2014, 09:21 PM   #3
murrdogg24
Member#: 50586
2017 Tacoma
TRD 4x4
i have a full v8 swap in my 04 wrx, i'd love to come across a shell GC8 and transfer everything into it.
murrdogg24 is offline   Reply With Quote
Old 04-22-2014, 02:49 AM   #4
SteamSpeed.com
Member#: 339860
This is what she looked like when I got her:
All in all, not a bad starting place. She did have a blown motor to start with, so oil was kind of every where.
Old 04-22-2014, 02:52 AM   #5
SteamSpeed.com
Member#: 339860
Here is my version 8 STI power train that we got from JDM racing motors...thanks guys.
Old 04-22-2014, 02:53 AM   #6
SteamSpeed.com
Member#: 339860
Step 1: remove blown motor
Old 04-22-2014, 02:55 AM   #7
SteamSpeed.com
Member#: 339860
Step 2: remove transmission, sub-frame and front suspension.
Old 04-22-2014, 02:56 AM   #8
SteamSpeed.com
Member#: 339860
She kind of looks like she is flying in this pic:
Old 04-22-2014, 02:57 AM   #9
SteamSpeed.com
Member#: 339860
Anyone need a custom rotated turbo exhaust for a RS?
Old 04-22-2014, 03:02 AM   #10
SteamSpeed.com
Member#: 339860
Next: the interior wiring loom. For swaps like this where you have a chassis that is incompatible with the engine, you need to merge a harness that matches the newer engine with harness from the old for the older body.
Old 04-22-2014, 03:04 AM   #11
SteamSpeed.com
Member#: 339860
Next: we dropped the rear end
Old 04-22-2014, 03:07 AM   #12
SteamSpeed.com
Member#: 339860
Part used in this post: * PM us if need these parts. We normally have them in stock.
1x Walbro Fuel Pump 255Lph (pn GSS342)
1x Walbro Installation Kit Subaru WRX / STI 2002-2007 (pn 400-791)
Tank swap: while you have everything out, it is probably not a bad idea to swap the RS' tank. They are not baffled like the WRX tanks that followed. Here is a WRX tank with a STI fuel pump assembly
Old 04-22-2014, 07:09 AM   #13
scylar
Member#: 369585
Subscribing
scylar is offline   Reply With Quote
Old 05-06-2014, 02:54 AM   #14
SteamSpeed.com
Member#: 339860
Default The Rear Is Coming Together
1x Whiteline Rear Sway Bar 24mm Adjustable Subaru STI 2004-2007 (pn BSR37XZ)
1x Control arm - complete lower front & rear arm assembly (pn KTA123)
1x trailing arm rear bushing (W61383A)
1x trailing arm front bushing (W61381A)
1x Outrigger bushings (pn W91379)
1x rear diff bushing (W92835)
1x Perrin Subframe Lockdown Kit (PER1 PSP-SUS-525)
It is fun to to figure out how to put things back together when parts come for several different years and models. Subarus are like Lego bricks...except when they are not.
We got the tank back in. It is from a 2002 WRX, but it has a fuel pump assembly from a 2005 STI.
We pressed out some old subframe and rear dif bushings and added some new Whiteline parts. We swapped the RS' old rear subframe for a JDM version 7 STI subframe that came complete with sway bars, lateral links, etc. Who knew that a JDM version 7 STI rear suspension looked like a 05 WRX's? Not me. Also the version 7's lateral links are longer that the RS'? Me neither. Not realizing that version 7 rear suspension looked like the 05 WRX and not the 05 STI, wanted to use USDM 05 STI style suspension parts, so I swapped out lateral links for Whiteline parts. This allowed me to use 05 USDM STI style endlinks from Perrin and swaybars from Whiteline.
Next I wanted to go 114 hubs/bearings, so I have spindles and trailing arms from a 07 USDM STI.
Old 05-13-2014, 01:38 PM   #15
SteamSpeed.com
Member#: 339860
you are moving to 5x114.4 hubs, ideally you use GC8 style rear coilovers for the tophats, and 2005-2007 STI style front coilovers because you need the larger receiving bracket.
Old 05-29-2014, 08:37 AM   #16
SteamSpeed.com
Member#: 339860
Default Rear Brakes Are In!
The rear breaks are in! JDM STI Brembro 2-pot and 2007 USDM rotors for 5x114 are setup in the rear.
This is what it looks with wheel and tire combo with the corner loaded with the floor jack.
Here is the side angle. It is a little too hella flush for my tastes, but remember the suspension hasn't actually been configured yet; still, I think we will be rolling this finder to the max to minimize rubbing.
Old 05-29-2014, 08:39 AM   #17
SteamSpeed.com
Member#: 339860
Default Front Subframe
Here is the front subframe all setup. It has a 2005 USDM STI rack and Whiteline swaybar and tie rod ends.
Now bolted up to the car shell.
Old 05-29-2014, 08:41 AM   #18
SteamSpeed.com
Member#: 339860
Default Labor Day Progress
Next we separated the engine from the transmission. Fun fact: you must undo the clutch's release leaver by removing it's shaft before the transmission and engine will separate (6MT only). This is basically how we took the car apart. Given that the car is on jackstands, and there isn't a lot of room to push the engine and tranny from underneath, it is safer to install them one at a time.
Next, we installed the control arms, and coilovers. We didn't install the wheel carrier today because we still needed to install the ball joint. We have new Whiteline upgrades, but needs the aluminum arm shims which still need to be pressed out. Once the wheel carries are in, we will have a rolling chassis again. Then we will be able to roll this baby out to power wash it clean.
[update]
We finished installing the wheel carriers, rotors, and brakes. Here it is with the wheel on to give you an idea.
I also got a replacement for the cracked timing cover on the left side. While we were in there, we inspected all of the belts and they more or less looked nearly new. I have new belts and timing kit for this project, but I think I will save them for later or perhaps for one of our other cars. Also, we did a compression test, 130 on all cylinders. We have a nice clean version 8 ej207; thanks JDM Racing Motors! Part of me relishes the idea of doing a monster motor build, perhaps a 2.1 stroker, or perhaps bore out the block to use 100mm pistons and machine the heads, but the more practical part of me would feel sad breaking down a perfectly health motor. Besides, the version 8 should be built enough to run roughly 400 whp which should be fine if I run our STX 67 in twin scroll. If I go with our STX 71, I may be pushing it. In any case, I will rebuild the motor whenever it comes to that.
Old 05-30-2014, 11:08 PM   #19
norexyet
Member#: 39149
Looking good. Both the 5mt and 6mt have the clutch pin though unless it's a push style fork.
norexyet is offline   Reply With Quote
Old 06-10-2014, 01:41 AM   #20
SteamSpeed.com
Member#: 339860
The rear sway bar is in! I believe it is the 26mm Whiteline sway bar for a 2005 USDM STI. Note: the rear sway bar mounts on the GC8 chassis are different than the GD chassis, so the sway bar bushings I got were not compatible. Lucally for me, I saved my GD mounts when upgraded the rear mounts in my other car! I swapped them out, and everything worked great.
Finally I used the Perrin rear end links for the 2005 USDM STI with spherical bearings. The only thing is the clearance seems super close between the rear sway bar and the mud cover for the fuel filler pipe. I'll have to keep my eye on that.
Next step will be to mount up the version 8 JDM STI 6 speed gear box.
Old 06-10-2014, 01:43 AM   #21
SteamSpeed.com
Member#: 339860
Thanks. Updated the post.
Old 06-22-2014, 03:54 AM   #22
SteamSpeed.com
Member#: 339860
Default Major Milestone: Rolling Chasis
Today we reached a major milestone with project Domino, we were able to roll her out of the garage for the first time in six months. Aside from that, the JDM STI version 8 6 speed transmission is also in.
The tranny is bolted up with fresh new bolts.
The frontal view.
Domino standing on her own for first time in these many months.
Rolled out for a little clean up.
Old 06-22-2014, 04:08 AM   #23
murrdogg24
Member#: 50586
2017 Tacoma
TRD 4x4
This is gonna be one fun car to drive!
Old 06-22-2014, 02:19 PM   #24
TeamShocker
Member#: 247881
2000 2.5 RS
BRP
Are you located in WA or is that just where the car was bought from? This is pretty much exactly what I want to do to my RS eventually, except I want a V7 Looks promising!
TeamShocker is offline   Reply With Quote
Old 06-23-2014, 02:37 AM   #25
SteamSpeed.com
Member#: 339860
Hope so. We are looking forward to some track time to see how it handles.
Yep, we are in Bellevue WA. I picked the car up in Federal Way.
