Welcome to the North American Subaru Impreza Owners Club Tuesday January 28, 2020
Old 11-10-2019, 02:14 PM   #1
thenewrick
Member#: 240649
2004 WRX STi
Default Does Baja have a HVAC heater or use passive heat?
When I turn the heat on in the Baja is it just sending me reused engine heat or is there a heating element that heats up?
I'm wondering because when I see my oil temps rising I'll turn the heater on full blast thinking I'm drawing heat from the engine compartment to cool it off some. But if it's just turning on a heating element, I wouldn't do this.
thenewrick is offline   Reply With Quote
Old 11-10-2019, 06:47 PM   #2
234herk
Member#: 392388
2005 Baja Turbo 5MT
TD05-18, DW850's
It uses engine coolant in a dedicated loop. Coolant is always thing through it. If the mixer flap fails it won't allow the heated air to escape the chamber.
234herk is offline   Reply With Quote
Old 11-10-2019, 08:06 PM   #3
thenewrick
Member#: 240649
2004 WRX STi
The heater works great. I guess I'm trying to find out if using the HVAC hot air will help passively cool the engine some to prevent engine over heating.
Old 11-10-2019, 08:11 PM   #4
234herk
Member#: 392388
2005 Baja Turbo 5MT
TD05-18, DW850's
It does. I have done it myself when I forgot to hookup the fans after an engine install. Gave me enough time to get off the road.
