Welcome to the North American Subaru Impreza Owners Club Saturday August 18, 2018
Old 05-30-2008, 11:49 AM   #26
efaroh
Member#: 166947
2006 WRX Sedan
Crystal Gray Metallic
Okay i didn't get around to taking pics of my engine bay, but I found a picture of flex grounding kit in wrx engine bay. comparing the pics, it looks like the throttle body is different.
Flex Grounding Kit on 06-07 WRX
Engine bay 06-07 2.5i
efaroh is offline   Reply With Quote
Old 06-25-2008, 01:56 AM   #27
mellow
Member#: 183181
2005 Forester XT
I just bought an 06' 2.5i wagon on sunday, and mine is doing this same thing in mostly 3rd gear and 1st at around 1500-2000 RPMS.
mellow is offline   Reply With Quote
Old 06-25-2008, 03:53 AM   #28
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
rear diff bushing wind up
In addition to the slow smooth let off, pause for a moment when you're changing from stepping down on the gas to letting up. This lets the bushing unwind.
chimchimm5 is offline   Reply With Quote
Old 10-21-2010, 09:37 PM   #29
SC_TBFD
Member#: 206790
2007 Impreza 2.5i
UGM
Originally Posted by lewisd View Post
The most common place I notice it is when driving down a very slight incline. Say I'm in 3rd, and I have my foot just barely on the gas, and I notice that because of the incline, I'm speeding up slightly thanks to the combination of gravity, and my foot on the gas. When I slowly try to move my foot to give less gas, as I come off the pedal, there's a bit of a jerk, and I start slowing down faster than I wanted. So then I have to give it just a tiny bit of gas to maintain the right speed, and as I put my foot back on the gas, there's a jerk again, and I start accelerating, instead of maintaining speed.
It's like the difference between "no throttle" and "minimum throttle" is too large.
Digging up an ancient thread.... again....
This is the best description of this problem. It's changing from 'coasting' in 2nd or 3rd to 'ever so slightly, as little as you possibly can, just barely touching' the accelerator at low(below 2500/2000) rpm. Following a another car in the city down a slight incline is exactly the situation it happens in. I think the initial jerk of acceleration pulls your foot off the throttle which makes the situation worse. Is there any new info on this, I feel like it's getting worse in my '06 2.5i
SC_TBFD is offline   Reply With Quote
Old 10-30-2010, 12:41 PM   #30
Tanuki505
Member#: 230472
My wife hates riding in my WRX 06 and is alway yelling about it being jerky no matter how much I try to drive nice.... It's just the car.
Tanuki505 is offline   Reply With Quote
Old 10-30-2010, 08:49 PM   #31
hillsboro
Member#: 84823
14 Evo
00 Outback
This is normal for a wrx or sti from what I've seen. I put 90,000 miles on my 02 wrx and it did the bucking thing. I tried switching from an aftermarket bov back to the factory. Didn't make any difference. I have had 2 sti's since and they all do it. This is a good thread though, it freaked me out at first. I had a protune and thought maybe it was bad. I remember asking the dealership and they had no idea what I was talking about.
hillsboro is offline   Reply With Quote
Old 11-01-2010, 02:20 AM   #32
Boosting 24
Member#: 262240
2006 Subaru
it's most likely the tune pro making it jump
Boosting 24 is offline   Reply With Quote
Old 11-05-2010, 03:19 PM   #33
Chipper
Member#: 179059
2003 Impreza TS
Default Jerky throttle
My 5sp 03 TS has EXACTLY the same symptoms as the other folks here are describing....and my 03 doesn't have drive by wire so I'm thinking that's not the cause.
This has been driving me crazy,(crazier), lately to the point of wanting to get rid of the car.
I'm really hoping the rear diff bushings are the cause,(as suggested by chimmchimm5)....sounds like an easy fix.
Chipper is offline   Reply With Quote
Old 11-20-2010, 09:02 PM   #34
thumpetto007
Member#: 156358
2001 Miata LS
Gay Blue
Well, part of it is also the AWD system. When letting off the throttle, the car tends to buck as shockwaves are transferred up and down the driveshaft.
I'm sure the DBW aspect only exacerbates (sp?) this condition, as would certain BOVs.
thumpetto007 is offline   Reply With Quote
Old 01-08-2011, 01:17 PM   #35
Special J
Member#: 148045
2006 OBS
CGM
Here's the problem.
What problem still remains?
Sadly, there appears to be one flaw in the DBW system that we do not have the tools to fix. The system appears to be unable to give a truly smooth transition away from idle. Significant testing with some VERY strange maps revealed that there is a small range just above idle that the system WILL NOT use. When you move the accelerator the smallest amount the ECU can detect, the engine instantly jumps from idle to an output about 70-90% above idle without passing the values in between. This is accompanied by a small lurch since the power doesn't come on smoothly. Dropping back to idle sees the same jump in the other direction. So, the bouncyness when trying to drive right above idle isn't totally eliminated due to this small gap in the programming. However, you can ease down to this point very smoothly, greatly improving drivability.
Everybody go paypal $10 to the Williaty Institute for ECU Research, and pray for a cure.
Special J is offline   Reply With Quote
Old 01-13-2011, 04:17 PM   #36
ChefVoltron17
Member#: 269918
I think I'm a bit late on the subject but I have the same issues in an 07 wrx. As much as the DBW system might be at fault I can't see the jerkiness resulting from that. Even if the electronics aren't smooth, the car should be. I would be curious to know how many people with the STi group N engine mounts have this problem. Or better yet, someone with upgraded diff bushings, engine mounts, transmission mounts and shifter bushings. I've read plenty of places that stock subaru mounts are basically "rubber gummy bears".
ChefVoltron17 is offline   Reply With Quote
Old 01-13-2011, 06:09 PM   #37
WHOrU
Member#: 156675
What Im seeing on mine live view accesport is at light throttle opening/closed throttle it appears the car cant make up its mind if throttle is closed or open and starts flipflopping air fuel ratios. generic coob tune this condition was much better. Custom tune the condition returned.
WHOrU is offline   Reply With Quote
Old 03-01-2011, 11:51 PM   #38
wrx_impreza02
Member#: 254711
07 STI
Try cleaning the inside of the throttle body, if you have a cool tech at your local dealer he may give you a can of it
wrx_impreza02 is offline   Reply With Quote
Old 03-08-2011, 11:46 AM   #39
gregoriousd
Member#: 269826
2006 Impreza Wagon
Regal Blue
I don't mean to threadjack, but I have something similar in my 06 2.5 automatic wagon (70k mi). If I let of the gas (mostly in stop and go traffic under 25mph) the rev's will drop fast from 1500ish down through 1000 and then back up to maybe 1200 rpm. I've always thought a healthy idle for a stock car is around 1000 rpm, give or take a little. If this is normal it's ok with me I can deal, however if this is some transmission problem staring at me from the shadows well...let's just hope it's not.
gregoriousd is offline   Reply With Quote
Old 07-01-2018, 01:46 AM   #40
SergeDeC
Member#: 375883
2007 Impreza 2.5i
Newport Blue Pearl Wagon
Once again, reviving an old thread here...
I am also experiencing the same bucking issue at low RPM in 1st-2nd gear (parking lots, traffic, etc.), on deceleration, and so on. I can confidently confirm that it has nothing to do with mounts and bushings.
I have a 2007 Impreza Wagon 5MT with the following parts installed and it still bucks just as much as it always has (Iíve had them all for approx. 30,000km):
- Group N STI engine mounts
- Perrin Pitch Stop mount
- Group N STI transmission mount
- TIC Rear differential bushings
- Kartboy Outrigger Bushings
- Kartboy Shifter bushings
I have also done the throttle body position relearn sequence on several occasions (when Iíve had my battery disconnected for more than 30min). That seems to smooth out the problem (very slightly) for only a brief amount of time, then it goes back to bucking.
My next attempt to fix the problem is to address the grounding issue. I still havenít decided if Iíll install a grounding kit or try to clean the current grounding points and coat them with dialectic grease for good measure (might try the latter and then resort to the former if necessary)...
SergeDeC is offline   Reply With Quote
Old 07-02-2018, 11:54 AM   #41
lewisd
Member#: 115287
2014 WRX
Satin White Pearl
Haha, I can't believe my thread's been resurrected after 11 years.
I sold the car years ago, cuz I was moving continents. I moved back eventually, and now I have a 2014 WRX Hatch (5-speed) that I love to bits.
Glad to see the someone fount the cause of the original problem I had, even if it's not fixable. Such a great car otherwise.
Originally Posted by Special J View Post
Here's the problem.
lewisd is offline   Reply With Quote
Jerky throttle in WRX luckdove Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 10-24-2007 11:05 PM
Jerky Throttle closing _oldtarf 'Old School' Subaru Forum 1 08-20-2005 11:04 AM
Jerkiness back with cobb stage 2? sjscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-10-2005 04:09 PM
hesitation/jerky throttle firealhrdcor Service & Maintenance 5 04-15-2004 01:24 PM
Herky jerky acceleration with unichip? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 01-20-2002 03:29 PM
