Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 05-18-2018, 01:33 PM   #1
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Default Flyboy1100's engine out thread
Here is phase 1, a 2013 FB20 with 24k on it....
Why?:
Current engine has begun consuming oil at exponential rate, tons of blowby, etc at about 155k miles as of today
Current plan/need to purchase:
1. 13lb flywheel and brz clutch
2. Boroscope the inside
3. Kreen soak cylinders
4. All new hoses, belt, plugs etc
5. prep the ac compressor for storage
6. Maybe water pump, otherwise just new gasket
7. Rear main seal
8. All Group N mounts, engine, dogbone, transmission
9. Maybe pull valve covers, probably not
10. Coolant
12. New tune for lightweight flywheel
13. Strip whatever else required off my current engine and open up old engine to see which cylinder/s have the bad rings
14. Swap my block heater over
Already purchased:
1. Flywheel bolts and exhaust gaskets
Going to start with scoping and soaking pistons.
When done this engine will only see 0w-40 oil after 500 mile rinse of something much cheaper
Old 05-18-2018, 01:51 PM   #2
nubsub
Member#: 313575
2012 Impreza 2.0i HB
sweet! looking forward to reading about your adventures although this sort of activity is well beyond my capability level so hopefully my engine has a long still ahead of it.
nubsub is offline   Reply With Quote
Old 05-18-2018, 02:37 PM   #3
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Good work. Subscribed...
Commander Keen is offline   Reply With Quote
Old 05-18-2018, 07:09 PM   #4
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Gonna be a slow thread here for a few weeks due to doctors orders...... but I managed to get it out of my truck and onto the stand. It rotates pretty easily, will get some pics of the inside next week.
I should have pulled a crank bolt out before putting it on the stand but the flange on the CVT bolts is much much larger than the 5MT. I bet they are the same length however.
Will try to find the cvt cooler pipe if i got it. And for the most part the harness is complete including starter harness. They cut the ground straps however and 1 connection on starter harness, hoping that one is just attached to the car....
It does look like the timing cover might be seeping as well as oil pan? Again pics next week
Old 05-18-2018, 07:26 PM   #5
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Ok few pics now of leaks?
Old 05-18-2018, 10:46 PM   #6
Commander Keen
Member#: 319157
Looks like the CVT has different (possibly hydraulic) motor mounts.
A teardown of the old engine should be very interesting. If before that point, you want to do a compression test for science, I'll give you my starter mount.
Old 05-18-2018, 11:04 PM   #7
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
yes, they are different, but I knew that going in. not sure if they are taller or not. most likely going to get Group N's but we will see.
i do plan to get a compression test done, i'm curious, i would like your starter mount, it would be easier on the stand..
wasn't planning to pull front cover, but might end up doing it since it really does look like it is starting to leak
Old 05-19-2018, 11:21 PM   #8
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Learned something new today. The '13 has different coil pack connectors than my '12 so i guess those wont be spares for me
Old 05-23-2018, 12:16 AM   #9
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
5MT flywheel bolts vs CVT Flexplate bolts.
2013 Ignition coils, those of us with 2012's will understand
today's progress (some rotated, sorry)
a few of my pistons before starting Kreen Soak, will let it soak for 36 hours before i get a chance to check it again. so thursday will get some new pics of the pistons.
i didn't get a pic of it before i cleaned, but I am wondering if the oil level sensor is leaking a bit and that is why the top of my oil pan was wet. either way plan to reseal both
there are a couple of coolant hoses on the top of the block but not sure what they are called, need to figure that out so i can get new ones.
Old 05-23-2018, 12:53 AM   #10
Commander Keen
Member#: 319157
What bore scope do you use?
Are you going to lube the bores, or does Kreen take care of that?
Old 05-23-2018, 01:09 AM   #11
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It leaves an oily residue behind when you spill it. Was planning to put some mmo in the bores when i was done too. http://www.kanolabs.com/msds/kreen_liquid.pdf
Need to add some oil so I can use one of my 2 old starters to run the compression test.
The scope is just some wifi scope of amazon, but it works pretty well. https://www.amazon.com/dp/B075CG73S2?ref=yo_pop_ma_swf
Whats the best way to disconnect the fuel hose? The yard buggered it up and then just cut the hose :/
Old 05-23-2018, 01:41 AM   #12
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Not my photo but I believe these hoses are Subaru parts only hoses :/ planning on gates for the rest. They don't seem like in horrible shape, but better safe than sorry over 20ish dollars
Old 05-23-2018, 01:55 AM   #13
Commander Keen
Member#: 319157
Something like this should work:
https://www.amazon.com/Lisle-37000-C...sr_1_6?ie=UTF8
Mine looks like this, but it didn't fit quite right:
https://www.amazon.com/Titan-Tools-5...sr_1_4?ie=UTF8
It looks like unformed heater hose might work for those, but I didn't replace them on my engine.
Old 05-23-2018, 07:39 AM   #14
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I have this set already, Lisle 39400 Angled Disconnect Tool Set https://www.amazon.com/dp/B000W0UZHG..._KrubBbGKHTY9N
But it doesn't fit over the ridge on the pipe, might just have to try a couple of picks??
edit: ordered a CTA 3476
Old 05-24-2018, 11:08 PM   #15
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Well, minor update today, good and bad news
Good: Kreen softened up the carbon on the pistons and removed some....
Bad: it also softened the sealant on the other side cam carrier. So now i will be resealing front cover, oil pan, oil level sensor, and cam carriers.......hopefully nothing else. I guess i can check torque on all the rockers now, only seen 1 reported failure of them coming loose
#1 piston
#3 piston, some carbon removed, i think just running the engine would remove the rest as it easily scrapes now
Whoops, kreen created this leak on opposite side
Inside #1 #3 rocker cover
Closer view, about what I expected with only 24k on it. I see i have green valve springs, IIRC those were in place of purple??
Old 05-24-2018, 11:36 PM   #16
Commander Keen
Member#: 319157
I really hope that stuff didn't hurt your head gaskets.
Old 05-24-2018, 11:51 PM   #17
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Me too! Might actually soak other side in MMO instead
But it is supposed to be safe, guessing just not safe for rtv/sealants
edit: other side soaked in Kreen for 9 hours, then i dumped it and put MMO in instead. will probably redo both cam carriers just in case of some damage to the RTV.
also need to get some assembly lube for when i reassemble everything. Planning to use Ford TA-31 as my sealant per recommendation of my friend, all he uses on any engine where sealant is specified instead of a gasket
Old 05-25-2018, 12:00 AM   #18
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Studying
I wonder if icant just install the crank pulley and boss to turn crank for cam carrier removal??? Otherwise i need to buy the 45.00 socket :/
Subaru FA/FB Crankshaft Socket https://www.amazon.com/dp/B06XSX8YQN..._gabcBbYE30MQ2
Old 05-25-2018, 12:46 PM   #19
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
so going back through old pictures etc. I think our 5MT engines have a different upper oil pan than the CVT engines due to extra CVT cooler pipe. so I probably have to pull the upper pan too and swap them, unless there is a plug i can use . edit yup, 2 different pans. pretty sure the 5MT upper pan just isnt drilled for that passage. add 1 more item to the list I need to swap
5MT
CVT
Old 05-26-2018, 08:10 PM   #20
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Got my Ford TA31 sealant yesterday
Ordered this junk today, upper pan o rings, cam carrier orings, valve cover gaskets, all group N mounts.
Still need a few coolant hoses, coolant, front & rear main seals, flywheel + clutch
The more i think about the upper pan the more annoyed i am, but i guess I don't need to swap block heater now..will use newer oil sensor though maybe it eorks better than mine
So flywheel bolts and upper pan are differences between CVT + 5MT applications
Old 05-29-2018, 01:43 AM   #21
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Woohoo for Andvance auto parts coupons, got 2 gals of pentosin A3 and 5qts of Mobil 5000 5w-20 for less than 2 gals of the coolant alone! Going to pick up that stuff tomorrow.
So just need hoses and flywheel and clutch. Really thinking BRZ ACT Streetlite 600705 +BRZ Exedy OEM FJK1005 now
Old 05-29-2018, 01:59 PM   #22
Commander Keen
Member#: 319157
Nice haul. Still plan on 0W40 for the new engine?
You don't need any special socket to turn the crank. You don't even need the pulley installed.
11.8 lbs should be a great upgrade. I'd be surprised if it gives you any issues.
Old 05-29-2018, 02:08 PM   #23
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I think so, conventional 5w-20 just because it was pretty much free will be used for compression testing and first 500 miles, then do some 0w40 and pull a 1000-2000mi sample. Depends on how that comes back but I suspect it will be fine
I think the streetlite will be fun.
Old 06-01-2018, 06:59 PM   #24
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
new Flywheel and Clutch plan. after much looking at the exedy parts catalog.
our 2012 isn't listed at all, but 2013-2017 is...it specs the same OEM replacment flywheel as all ej2.5 impreza's from 1999-2017....so I see no reason why I can't order the FF02 replacement flywheel with KSB04 clutch kit (which is also spec'd for 2013-2017 impreza 2.0)
or
the BRZ setup specs the same OEM replacement flywheel as the WRX/turbo 2.5's and the FA20DIT, but they spec a different lightweight flywheel for the BRZ vs WRX. looking at pics i can't decide what the difference is between the FF502a and TF02 flywheels. would still get FJK1005 clutch kit because no reason for a wrx capable clutch with our 150hp....
so I either get:
1. FF02 + KSB04; 403 + 151 = 554.00
2. TF02 + FJK1005; 399 + 171 = 580.00
3. FF502a + FJK1005; 303.00 +171 = 474.00
highly planning to order #3 tonight perhaps
going to pull motor some point next week.
Old 06-01-2018, 08:07 PM   #25
Commander Keen
Member#: 319157
Amazon says:
TF02 = 13.6lbs
FF502a = 12.7lbs
#3 looks like a good choice. I agree, no reason to go high torque on the FB20.
