Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 06-01-2018, 08:30 PM   #26
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Commander Keen View Post
Amazon says:
TF02 = 13.6lbs
FF502a = 12.7lbs
#3 looks like a good choice. I agree, no reason to go high torque on the FB20.
Exedy says 12.7 for both, but they can't confirm fitment for anything it seems.
Old 06-04-2018, 12:14 PM   #27
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Default Flyboy1100's engine out thread
Fjk1005 ordered
All new hoses, plugs ordered, f/r main seals ordered late last week.
Exedy FF502a was 288 today at rock auto before 5% off, no idea why it dropped 25.00 but is coming now too!
Still need buy some assembly lube and i think i will have everything, maybe by this Friday
Old 06-05-2018, 02:06 AM   #28
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Got these plus gaskets, orings, and pre heater hose. Group N is as close to polyurethane as I would even want to consider for a daily driver, hopefully I don't regret it as they feel super stiff..... done polyurethane in the past and didn't like it at idle.
Old 06-06-2018, 11:55 AM   #29
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Even more parts, clutch should hopefully be here tomorrow
Not sure where my flywheel was made?
Old 06-07-2018, 12:17 AM   #30
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Im hoping the group n mounts fit our brackets otherwise they wont fit our cars
Looking at keen's pics i think they will, the brackets they come with don't have the spacer on the back side so it doesn't fit, the holes line up however
Old 06-07-2018, 01:05 AM   #31
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I don't see any obvious differences.
Looks like that flywheel weighed in a bit lighter than advertised. Nice!
Commander Keen is offline   Reply With Quote
Old 06-07-2018, 01:18 AM   #32
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
look at your picture here, there is the large square metal spacer on one side, that is missing on the standard Group N mount brackets. like i said bolt spacing appears good, but w/o that spacer i can't use the brackets the Group N's came with and I will have to reuse my brackets which isn't a bad thing.
going to start dissassembly tomorrow i hope, i pulled off the front harness and the coolant pipes, and oil level sensor today, then got distracted by what seemed like 20 other things.
Old 06-07-2018, 09:41 PM   #33
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
w/o assembling the entire clutch, it does appear as though everything fits together correctly. tomorrow i plan to start dissassembly
Old 06-08-2018, 11:22 AM   #34
auskip07
Member#: 315643
amazing that the stock engine didnt last 200k with proper maintenance.
auskip07 is offline   Reply With Quote
Old 06-08-2018, 05:56 PM   #35
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Well, engineering defect on the rings didn't help any. Im fairly annoyed thats for sure. Did give me an excuse to buy lightweight flywheel and group n mounts i guess
Oh and now I'm completely out of other projects, 2 spare vehicle plus a motorcycle i can ride while i work on this one, tomorrow.
Old 06-09-2018, 05:18 PM   #36
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Every day is "tomorrow i will start" but tomorrow i will for real, today was a rest day since I have worked on various projects for the last week and i just need a break!
Today i picked up my lower dash cover for over the fan and a new Pilot and throwout bearing. I dont like the chinese ones in my exedy kit, the OEM bearings have made it 150k+ in my car so hopefully the new Subaru ones will too. New Subaru ones say made in Japan, so hopefully they are, the throwout bearing has no markings however
also borrowed another stand, so first thing i do tomorrow will be pull old engine so i can start stealing some parts for my new engine. Also once the engine is out i will be much more motivated to actually get this done
Old 06-09-2018, 09:36 PM   #37
Commander Keen
Member#: 319157
No need to rush. It's not a job you want to screw up, considering how deep you'll be getting into it.
If my Exedy TOB goes, the replacement will be some oversize bearing and snout sleeve combo. I'm not so loyal to the OEM TOB after mine went.
Old 06-10-2018, 02:45 AM   #38
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
True not much further and I could pull heads and pistons!
Old 06-10-2018, 03:55 PM   #39
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Compression testing on old engine, each cylinder done twice:
#1: 198, 195
#3: 193, 195
#2: 189, 193
#4: 169, 175
max difference per the book is 14psi, so I am just barely outside of that spec. my compression tester came out wet from #4, rest were dry...
just waiting for oil to drain so then i can drain coolant and start removing other stuff, well there is topside stuff i can continue to work on while that drains too
Old 06-11-2018, 01:36 AM   #40
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Now pictures, took me about 3 hours to prep for engine removal, spent another 30min flushing radiator and straightening some fins, and 1.5 to figure out how to get the darn engine to separate from transmission.
Factory exedy clutch had tons of life, no hotspots on flywheel or pressure plate. Included some weights, new setup will be a lot lighter!!
Factory transmission mount is a joke, new group n mount is perfect match
Group n engine mounts are wider, but look like they will fit fine and clear everything with the original mounting plates
Group n pitch stop vs factory only difference i can see is a different part number in the larger bushing but they carry the same part numbers for the plastic and front bushing, oh well
Probably will order a tsk1 sleeve kit, not sure I actually need it, the factory grove is still in the inside of the TOB, but the snout feels wavy but no major ridges. really tough call if i do need it or not.
when i put the newer engine back into the car i will probably also evacuate the AC and put on the newer compressor too, the idler bearing on my current one is starting to feel a bit rough, but for now going to leave AC hooked up to prevent possibly weeks of open system time. hopefully I am done this weekend, but not sure
Old 06-11-2018, 01:39 AM   #41
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Old 06-11-2018, 01:40 AM   #42
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
IMG]https://uploads.tapatalk-cdn.com/20180611/5e065fc18358f6e8aec1fe71b2240899.jpg[/IMG]
Old 06-11-2018, 01:40 AM   #43
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Old 06-11-2018, 06:31 PM   #44
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
pics later
I keep finding other things to replace due to swapping between the 2 engines:
1. water pump gasket
2. thermostat gasket
probably will find more I didn't fully account for.
getting the front cover off sucks, only done the old engine so far. removing the oil pan is worse, not sure i really need to remove it to get the upper pan off, book says i do but sure doesn't look like i do.
Old 06-11-2018, 09:01 PM   #45
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
so i guess i get to straighten the mounting flange on my new oil pan now. that thing was on way tighter than the old one :/ good thing it is sealed with RTV and I will be using the Ford stuff they use on 7.3 diesel oil pans as they use that stuff to seal up greater than 1/4" gaps!
Old 06-12-2018, 01:04 AM   #46
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
'12 vs '13 dipstick
Old engine pics
Newer engine ready for 5MT upper oil pan and installed. Tomorrow will be oil pan and maybe pull chains
Old 06-12-2018, 12:51 PM   #47
nubsub
Member#: 313575
2012 Impreza 2.0i HB
awesome watching your journey. way over my ability, but fascinating to see. thanks for documenting and sharing it with us.
nubsub is offline   Reply With Quote
Old 06-12-2018, 01:05 PM   #48
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It actually is much easier than even I thought it would be. Hardest part is getting the darn rtv to release
Old 06-12-2018, 01:12 PM   #49
Angelus911
Member#: 89967
2012 Impreza Sport
+1, thanks for showing your process, always cool to see. Hope it all goes well!
Angelus911 is offline   Reply With Quote
Old 06-12-2018, 04:07 PM   #50
Commander Keen
Member#: 319157
Great pictures, very clean inside! You were running 10K OCIs right?
