07-06-2005, 02:02 PM | #1 |
Visiting NASIOC Timeout
Member#: 9093
Vehicle:1995 RHD STi RA Ver2 swap starr |
Sti version 4.11 box, vs Version 2 RA 3.9
roarf.
so the box ive been running for the last 2 years has been a sti version 1 4.11 box code is: TY752VB3CA ratios: 1: 3.454 2: 2.062 3: 1.448 4: 1.008 5: 0.825 Final drive: 4.111 simple stupid setup - EJ25 dohc NA motor, redline is puny 6K. 4.11 box is awesome, its gota be the more fun street box imo, 1-5 are properly spaced out - 6K shift will land u at 4K. all 5 gears are useful, compared to the USDM 6box i drove with 1-4 really short and 5/6 useless, i much prefer the 4.11 box. the Sti-RA box (DCCD) that went in my car yesterday: STi-RA version 2 v-limited gearbox, code: TY752vb4ca ratios: 1: 3.454 2: 2.333 3: 1.750 4:1.354 5: 0.972 final drive: 3.900 http://www.catherineandken.co.uk/sti/wrx.html after driving both, the RA with 3.9 is INSANE. 3rd gear at 6,000 RPM (my pos redline) is 60mph. 4th gear is normal crusing, i can accellerate around town in 5th gear. its nuts. dccd dum dum (brainless - still in my front clip) is fun. its defaulting to id guess 65% rear, 35% front. really fun. i like it more i think :P
07-07-2005, 04:25 PM | #2 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
The RA tranny is known for the crazy acceleration compared to the normal STi tranny. I just wanted something stronger and still be able to cruise in 5th at freeway speed, and 4th for something lower. DCCD works nicely without the brain under non-adverse environment
07-07-2005, 04:37 PM | #3 |
Member#: 60972
BAIC
How much did this lighten your wallet?
07-07-2005, 07:25 PM | #4 |
Member#: 9093
hahah. not fun. not fun it was. :P
but it revs like a jet plane. |
07-07-2005, 07:55 PM | #5 | |
Member#: 75078
South East
Vehicle:2011 Forester 2.5X Dark Gray Metallic |
gearbox
derrick |
07-08-2005, 11:52 AM | #6 |
Member#: 9093
"fwd" refers to fake FWD. you can definately convert the AWD trans to FWD if you wish, theres a buncha ways to do it
i was running the 4.11 box in AWD mode, if you are interested in buying one mine is for sale- give me a call: 248.635.5906 h |
07-10-2005, 02:10 AM | #7 |
Member#: 76083
Vehicle:03 wrx silver |
I just did the same swap, except mine was a version 2 sti with 4.11..And it is alot of fun compared to the US POS tranny..I would recomend it also..Fun times..Justin.
07-10-2005, 04:32 PM | #8 |
Member#: 9093
word. it r teh bomb.
usdm trans is POS. |
08-03-2005, 12:53 PM | #9 |
Member#: 9093
haha. update. got the RA ej20 in, with the short gears and 8.5:1 compression, the TD05 spools up mad fast. almost as fastor as a SrT4.
08-03-2005, 02:11 PM | #10 | |
Member#: 9498
Vehicle:03 Bugeye Junkyards are fun! |
08-03-2005, 02:45 PM | #11 |
Member#: 23162
Vehicle:2006 300c,forester x silver steel |
now,try 4.44.
08-03-2005, 08:39 PM | #12 |
Member#: 9093
my 3.9 is shorter than the 4.44's. i have the shortest gears subaru ever had in a gearbox. i think it would top out at 100 @8200rpm in 5th with a 4.44 final drive :P
08-04-2005, 01:54 AM | #13 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
08-04-2005, 02:06 AM | #14 |
Member#: 9498
with a 4.44 on your gearset it would be physically impossible to go over 128 mph (5th gear, 8000 rpm). In reality, it would be lower than this. Stock fat piggo (USDM wrx) gearset/diff combo can achieve a theoretical top speed of around 185 mph, but obviously the car isn't capable of anything close to this (drag, etc.).
08-04-2005, 09:20 AM | #15 |
Member#: 9093
word. my dccd brain is plugged in now. kinda sad, i had alot of fun lifting and power drifting on u turns :P
Drop 4.11 push case gears into a 3.9 pull case? Possible? | biggreen96 | Transmission (AT/MT) & Driveline | 10 | 03-17-2010 08:34 PM |
ppg1-2 ra 3-5 | shift0246 | Transmission (AT/MT) & Driveline | 3 | 02-12-2010 10:12 PM |
WTT: 4.11 vlsd w 50k miles for 3.9 vlsd with 50k miles or less | 2slofouru | Drivetrain | 8 | 10-11-2009 03:21 AM |
Sti Version 4.11 Gearset with 4.11 LSD - full drop in conversion to 4.11 short ratio! | supermoose | Private 'For Sale' Classifieds | 11 | 07-06-2005 02:14 PM |
Gimmie gears 1-2, RA 3, 4, 5 possible? | Hondaslayer | Transmission (AT/MT) & Driveline | 2 | 04-20-2004 11:41 PM |
