Welcome to the North American Subaru Impreza Owners Club Thursday October 24, 2019
Old 07-12-2011, 01:32 PM   #1
JarHarms
Member#: 138994
06 WRX Ltd
SGM
A thread to collect some info on my WRX, sticking to chronological order as best possible. My "point" is to remain somewhat functional minded but also try ideas, make mistakes, learn, and have some fun while I'm at it. This is not my daily driver. I'm older and have a decent job so I can tinker when I get "rare" free time. Family makes free time pretty non-existent but I try. I don't expect this WRX to be everyone's cup of tea since I tend to steer away from current trends and car show fluff. I use a cell phone for photos since actually working on the car is my focus. I don't have time to be waving at everyone that I don't actually know. At surface level I may come off gruff but I am told there is an alright guy under there. Since it's my car, my interest, and my hobby.....it is what it is. Enjoy.
April 2019 ..........back apart
2006 Impreza WRX Limited - Steel Gray Metallic color #26d
Read this IPASS Jesse......
>>My 2002 Forester Thread<<
Old 07-12-2011, 01:33 PM   #2
JarHarms
Member#: 138994
06 WRX Ltd
SGM
...used to be a mod list...
Old 07-12-2011, 01:33 PM   #3
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Paint and Powder Colors
General:
-Generally many texture (wrinkle) powders are not UV stable unless overcoated so I suggest you ask and also verify to the mfg's specs. This property has much to do with the type of powder (epoxy, hybrids, polyester, urethane, etc). Overcoating with a UV stable clear will help preserve the base coat but at the cost of diminishing the texture. I recommend opting for a stingle stage UV stable powder instead.
-Texture powder throw a curveball so find a coater that is familar with curing textures and opt for runing a small test batch prior.
Wrinkle Reds:
If you are in a hurry then use the VHT wrinkle red spray paint and install carefully. If you want a durable finish I currently recommend Prismatic Desert Red Wrinkle powder #PWS 2762 since it is UV stable, color matches APS and STI close enough, and the common person can buy it by the pound. If your coater goes out of business then it is as simple as sourcing the same powder for the next coater to use.
-I feel that APS red powder is ever so slightly darker hue than the STI red paint. I can say that APS does not bother to properly prep before coating so it chips off like cheap paint. Why do they even bother?
-VHT's older wrinkle red spray paint was a good match for STI red. VHT altered the formulation around 2008/2009 resulting in a lighter hue and slightly orange-ish looking.
-Dupont Red Wrinkle powder #GFR-600-W2 is supposed to be a direct match for APS red and slightly darker than STI red. Keep in mind that this only comes from internet scouring. I have not seen it in person, it is not a commonly accessible powder, and I'm not yet willing to pay for coating a part just to determine its color match.
-AkzoNobel (Corvel) Robin Red Wrinkle powder #AG400QF color, legacy #12-4004 is an epoxy powder that is "close" to APS but slightly brighter hue. Probably a close match to STI red. Texture is spot on. It is not UV stable. This powder seems to be getting more difficult to find, has been sold around a bit (-> RH -> AN).
-AkzoNobel (Interpon) red texture powder #EG304G does not match either APS or STI colors, it is much too bright of a hue. Texture is finer than I had hoped but it is an attractive color. It is UV stable.
-AkzoNobel (Interpon) red texture powder #EG3027 I have no idea because the sample never arrived. I believe it to be almost as bright as EG304G and it is UV stable.
-NIC (Prismatic) Desert Crimson Red powder #PWB 6699 is the closest I have found to APS color and texture. Probably a tab darker hue than STI red.
-NIC (Prismatic) Desert Red Wrinkle powder #PWS 2762 is "close" to APS but slightly brighter hue. Probably a close match to STI red. Texture is spot on. It is UV stable.
-NIC (Prismatic) Hotsy Red powder #E-9141B is even lighter hue than Desert Red Wrinkle and the texture is too fine. It is NOT UV stable so I do not recommend it.
-NIC (Prismatic) Phone Red powder #E-9125B is a darker matte red than Desert Red Wrinkle with a slight sparkle in it and the texture is too fine. It is NOT UV stable so I do not recommend it.
-NIC (Prismatic) Desert Night Black powder #PWS 2859 is a really good black wrinkle color and texture wise.
Reds:
-The older cherry blossom red is a Panatone Magenta C color. I still need to find the RAL color.
-The newer cherry blossom red is a Panatone 207c color. I still need to find the RAL color.
Holding Tank --------------------
I've helped with more than a few installs of the newer steering racks (2006-07 WRX/2005-07 STI) into other Subarus using the older square saddle front cross members. Contrary to the internet joes toating that this requires a matched cross member.....this is just not so.
I also helped install a Qrack more than awhile ago in a 2005 WRX. I ended up ordering one for my 2006 since it was pretty sweet in the 2005. THIS scenario is a whole new PITA. Since I am going in the opposite direction than most; grafting an older rack into a newer cross members there are bound to be some issues. First off there are no threads that mention any detail of this or show any photos depicting concern areas. I looked everywhere none, zip. So I can see how one might think it just installs fine as-is.
The older rack physically mounts into the new cross member fine. The rack's LHS square cross section fits fine into the round cross member saddle as long as you do not use a rubber/poly bushing.
There are problem areas with the right and left hydraulic tubes (hard lines). The older rack routing rubs the newer cross member; this is not good for a problem free service life. So I thought why not try modifying hard lines from the newer rack onto the older rack. This is also not really possible for a few reasons 1) the end flares do not match, the older used o-ring flares and the newer uses DIN bubble flares, neither are interchangeable. Both require special flaring tools. 2) the routing is slightly different at the quill connections, the older rack has ports in the quill housing while the newer rack has ports in the rack housing. 3) the newer tubes are not long enough to support re-bending to fit. I "might" be able to re-bend the older tubes to avoid the rubbing.
I have a few sets of the older hardlines to try re-bending for more clearance. Otherwise this could require custom bent tubes. I would be looking at some o-ring to double flare insert fittings that would let me use 45 degree double flares or having to buy another flare tool. Sucks since I really want this steering rack in here.
I decided the best route was to install the Qrack with a 2004 engine cross member. Plus I gain the forward LCA-subframe mounts to use with my Oswald subframe.
Recap:
-> 2005-07 STI (2006-07 WRX) steering racks fit in round saddle cross members as-is and into square saddle cross members with some TLC.
-> 2004 STI (2002-05 WRX) steering racks fit into square saddle cross members but not really into round saddle cross members (at least good enough for me to risk it)
Originally Posted by mrsaturn7085 View Post
The JDM P/S pump for 13:1 racks was different...I noticed this when I took it out for a drive and the pump was straining at 1/2 to 3/4 lock. By straining, I mean the pump was whining at this position as bad as the OEM rack would at full lock. The proper p/n for the JDM pump is 34430FE071 (or 072).
USDM pump specs:
output = 7.2 cm^3/rev
relief pressure = 1067-1165 psi
JDM 13:1 pump specs:
output = 8.5 cm^3/rev (18% increase!)
relief pressure = 1176-1277 psi
This means that not only is the JDM pump designed for almost 20% more flow, but it is also designed to operate at a higher peak pressure. I'll be ordering one before I end up burning up the USDM pump.
Impreza GD/ GG (2000/ 02 – 2007/ 04)
<GGB is only for A and B. (Wagon Sti did NOT make after C)>
e.g. GDA: 2.0L Turbo AWD
G is Impreza
Body Code:
D is Sedan
G is Wagon
Model Code:
A is 2.0L 4WD (DOHC TURBO EJ205 WRX)
B is 2.0L 4WD (DOHC TURBO EJ207 Sti)
C is 1.5L 2WD (DOHC N/A EJ154 Model G only <1.5R>)
D is 1.5L 4WD (DOHC N/A EJ154 Model G only <1.5R>)
2 is 1.5L 2WD (SOHC N/A EJ15)
3 is 1.5L 4WD (SOHC N/A EJ15)
6 is 2.5L 4WD (ONLY FOR EXPORT MODEL)
9 is 2.0L 4WD (DOHC N/A Model A and B only EJ204)
Applied Model Code:
A. 2000/ 02 – 2001/ 08
B. 2001/ 06 – 2002/ 10
------------------------------Minor Change
C. 2002/ 09 – 2003/ 07
D. 2003/ 06 – 2004/ 05
E. 2004/04 – 2005/ 05
F. 2005/ 04 – 2006/ 06
G. 2006/ 04 – 2007/ 04
-------------------------Full Model Change
Grade:
IS: EJ152/ Wagon Only
ISS: EJ152/ Wagon Only
ISSL: EJ152/ Wagon Only
15I: EJ152
15I-S: EJ152/ Wagon Only
15R: EJ154
NA: EJ204/ Sedan Only
20N: EJ204/ Wagon Only
20S: EJ204
NB: EJ205/ Sedan Only
NBR: EJ205/ Sedan Only
20K: EJ205/ Wagon Only
WRX: EJ205
WRX-V Limited: EJ205/ Sedan Only
WRX-WR Limited: EJ205/ Sedan Only
Dumping some brake info here for later...
Front
4pot Sumitomo cast iron calipers 40.4mm / 40.4mm pistons - rotors 294x24 (295x25.5)
-red w/ flat Subaru logo - 2629FE0418A RHS and 2629FE0518A LHS
-black w/ flat Subaru logo - looking for p/n's since US shops hide that info
-earlier v5 red w/ raised Subaru logo - looking for p/n's but probably not relavent anymore
-earlier v5 black w/ raised Subaru logo - looking for p/n's but probably not relavent anymore
*raised and flat logo calipers are functionally identical except raised face sticks outwards +1.22mm (0.048") which may affect wheel clearance*
2004-07 4pot STI Brembo alloy calipers 40mm / 46mm pistons - rotors 326x30
-gold w/ Brembo logo - 26292FE022 RHS and 26292FE023 LHS
-07 Ltd black and clearcoat w/ Brembo logo - 26292FE120 RHS and 26292FE130 LHS
-08+ black and clearcoat w/ STO logo
6pot RA-R Brembo alloy calipers ?? / ?? / ?? pistons - rotors 340x32, 15.5-16mm thick pads, 54mm annulus pads, 68 annulus disks, pin bridge calipers
-temp changing silver w/ Brembo logo
6pot Brembo HD kit ?? / ?? / ?? pistons - rotors 350/34, 18mm thick pads, 65mm annulus pads, mono block bridge, 1L3.8004A5 kit p/n
Rear
2pot Sumitomo alloy calipers 38.1mm pistons - rotors 290x18
-red w/ flat Subaru logo - 26692FE0408A RHS and 26692FE0508A LHS, also seen 26692FA020 and 26692FA030
2004 -07 2pot STI and RA-R Brembo alloy calipers 36mm pistons - rotors 316x20
-RA-R temp changing silver w/ Brembo logo
08+ 2pot STI Brembo alloy calipers 40mm pistons - rotors 316x21
-black and clearcoat w/ STI logo
Not certain where FHI 4pot/2pot came from. Probably based from the fact the Fuji Heavy Industries is Subaru. Sumitomo manufactures these calipers for Subaru as well as other cars makers.
The STI Brembo black caliper clear coat finish fails early on and results in some harsh looking brakes.
What is EFI? - wait 1:18 what? was that the entire video's content?
The Four Stroke Cycle - 1:40
Trigger and Sync - 2:34
Critical Sensors - 4:48, crashed right away then site went ouch
Old 07-12-2011, 02:50 PM   #4
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Subscribed.
Nice Limited WRX I have a '07 WRB WRX Limited
96accord is offline   Reply With Quote
Old 07-14-2011, 01:27 AM   #5
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Most of us at some time in our WRX timeline want a proper boost meter. Do I really need one? Well no, not really but here it is. Really I just wanted something fairly accurate and that might somewhat match the OEM cluster. I have used most of the usual meter brands on prior cars and was set on avoiding garbage parts. The Defi meters used in the past have always performed well and live a long service life. Autometer (while mfg'ed nearby) are complete crap and I would not even use them if given for free.
I do not really like the clock hoods, A-pillars, or any of the other mounting pods offered for Subarus. They all just end up looking out of place and not quite my style. So steering column mounting seemed to be my remaining option. Those are tough to find for meters bigger than a 52mm, so 52mm is what I went with on this meter. Since my mind functions in English units (it just does) I wanted to avoid SI "metric" scale. I have had meters in SI units before and I do not like them as much. What can I say, the Imperial units work best for me. Defi BF's are really nice but I just didn't need their added wow factor, extra cost, and dash cluster miss-match. So a black faced imperial unit 52mm Link boost meter, V2 control, and Defi mounting cup was ordered. Then promptly installed.
The before action. *Links to save space.
http://i24.photobucket.com/albums/c2...ntingMeter.jpg
http://i24.photobucket.com/albums/c2...ontrolunit.jpg
The after action. Looks pretty good and you would hardly notice it in passing.
Ended up using the Subaru gauge pack jumper harness which made for an easy install, factory appearance, and extra pwr/gnd taps for future electro goodies. I tried using an ACC and then switched to an IGN circuit to power the control unit but both ways still do the annoying double opening event. I never really use Defi's record or playback features, a waste I suppose. The control unit is held in with that HD velcro that is used on IPASS/EZPASS transponders. Check out Radio Shack, they carry it. It only needs two smaller pieces or otherwise you are not getting that unit out easily. This meter is still working to this day without issues. I think the only time I touched the control unit was to increase the overboost warn setting.
*This column mounting arrangement did however require a later repair thanks to an auto glass guy.
Since winter season had set in there was all kinds for road junk being flung onto the sides of the WRX. Some decent mudflaps would solve that problem. I hate OEM mudflaps since they are usually aesthetically challenged and tend to accelerate rusting. The rally style flaps tend to get a bit too much "out there" if you know what I mean. I eventually ended up with some RallyArmor flaps. The only PITA was figuring out what the difference was between regular (stiffer material) and ultimate (flexible material) versions. Their web descriptions were a bit lacking back then. Plain black was the color of choice; red and blue flaps are just effing ugly man. Just accept it.
The before action, plenty gritty. *Links to save space.
http://i24.photobucket.com/albums/c2...s/DSC01593.jpg
The after action. They overhang relative the oem wheels but the summer wheel/tire combo reduces most of that overhang. Still not sure I really like this look though. I ended up modding the rear flaps to bring them inboard a bit more to my liking. After a good few years of DD use these are showing use but holding their own. They have a very little warp to them but the hard corner scrapes have finally disappeared. I must have finally worn them down past the scrape zone. RallyArmor must have renamed this version of the flap to "Classic".
We then strapped it onto AMS' dyno just to see what bone stock had to offer. Three pulls Max HP1 207.85 Max TQ1 235.36, Max HP2 208.49 Max TQ2 246.72, and Max HP3 209.24 Max TQ3 245.45. Sadly I have long since lost that dyno plot. But really I could care less about dyno stats at this point in time. It was done more for fun and curiosity. Right after that a cat back exhaust was installed. I just wanted something a little louder. The dyno run was embarrassingly quiet. Too quiet. I researched and read, then got lazy and ordered a dual tipped Borla. It works well enough, looks fairly stock-ish, and lets more rumble out. Fine enough for me although looking back I might have opted for a single tip Maddad Whisper or other catback instead.
Old 07-14-2011, 02:44 AM   #6
fastwrx25
Member#: 126441
03 bugeye
good choice on the tr wheels, I've always liked those wheels...any pics standing still?
fastwrx25 is offline   Reply With Quote
Old 07-14-2011, 03:19 AM   #7
rockthebox50
Member#: 150034
2007 WRX & STI
SWP & Aspen White
^what he said
rockthebox50 is offline   Reply With Quote
Old 07-14-2011, 04:23 AM   #8
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
2003 Subaru Legacy L..ame
Love the overall stockness. At times wish I would have gone that route.
future_subaru_owner is offline   Reply With Quote
Old 07-15-2011, 01:00 PM   #9
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Yea "stockness", I tend to be pretty uninspiring on most of my cars exterior appearances. So far it has worked pretty well as I get very little attention from LEO and other motorists. I lost a bunch of early photos due to a HDD failure. I'll try to take some less-crummy photos to replace these.
Since this is a DD I figured it would be useful to scare the bejeesus out of a fellow motorists that gets out of line. Some Hella Supertone horns were installed in the usual WRX forward pointing position. Honestly I do not use them that much but they are available if needed. No photos of that since we all know what those look like. Eventually the piss poor nuts and bolts that Hella uses rusted up pretty fast and started annoying me. All 16 of these got replaced with SS 8-32 capscrews and nuts.
My "creature comfort" splurge was towards new center console trim. The WRX center console trim is too shiny for my tastes. Sure I had aspirations of the flat black Spec C trim. Cost, availability, and later finding replacement parts steered me away from those. I decided on the STI Limited console trim which has a more charcoal gray color. It really was the best option after contemplating Spec C or painting the WRX trim. The only downside was cost and the two little holes that would have located the Limited badge (which you cannot order unless you prove STI Ltd ownership). Looking back, if that 3m matte gray vinyl was around I would have gone that route and saved some cash. PlastiDip coating did come to mind but was not sure on its durability. I posted up some of my install detail >HERE<.
The after action.
The only other install things I did differently was forgo the red Hazard button and bright silver HVAC control rings. Now that I look at it, the oem radio looks kind of funny inside that darker console trim. Meh Shortly after this I ended up selling off the last of my motorcycles and other toy cars. It did not take too long before I ended up at a track event and needed something to drive. This WRX is all that I had even though the curb weight is; well it's a little "porky". It worked out fine aside from the RE92's, oem pads, and brake fluid. Knowing that the WRX would have to suffice for more track use, I shopped around for some parts to at least hold a usable session or two. I felt the steering input was better than older WRXs I have driven. I suspect it has something to do with the difference in the rack mounting design. Whiteline steering rack bushings were installed to help a little "more". To avoid the cost of a new rear anti-roll bar I replaced the oem rear endlinks (made of black laffy-taffy) with Whiteline alloy links.
The rear felt like it had some wandering during acceleration. I tried some TiC rear differential bushings in their comfort version. Whiteline rear outrigger bushings were also installed. I really wanted to avoid turning this WRX into a rough DD car like I've done with past cars though.
Another alignment was done to confirm everything was good to go. The brake fluid was purged out with some Motul600 I had around the garage and I borrowed a set of Hawk track pads from a friend (short notice). These sorted out a few of the previous issues, helped the following track visit, and made the DD use interesting to say the least. The RE92's were still problematic but held their tread longer then I expected. I would get around to better tires eventually. I was originally going to outright buy new 2004-05 tail lights since I am not a fan if of the new clear tail light fad. Tail lights are supposed to have red lenses with the appropriate clear for reverse and maybe some amber PERIOD. I ended up trading a friend for his 2004 STi tail lights. In the end we were both happy and the cost was about right. free
Old 07-21-2011, 12:23 PM   #10
JarHarms
Member#: 138994
06 WRX Ltd
SGM
A good set of 2004 STi takeoffs was bought and installed with RCE v1 camber plates. I split them apart, removed the OEM grease, and repacked with some slick-o-leum strut grease I had around. That avoided any STi strut clunking later in life. Slick-o-leum is a bit thinner than the usual Mobil1 red grease that is used, but this maintains good contact with the strut cartridge surface.
**I eventually replaced these with Tokico Dspecs...but now I wish I would have kept these to have the inserts tuned up by Feal.**
The RCE v1 camber plates worked great. My only gripe was the minor issue during install where one of the chassis mounting nuts must have stripped while tightening to spec (with TQ wrench). This left me with a spinning nut on the stud that would have to be removed by cutting it off. A minor gripe at that point though. I made repeated emails and calls asking for a replacement (stud and nut only) to get "Yea we will send you one" but nothing ever arriving. I gave up with a salty experience over $1.50 in hardware. Yea I could have gone to the hardware store and got replacements but considering the cost of these plates I wanted them to match the other hardware without additional cost to my wallet. This should have been made right. Meh
**I later fixed these myself prior to selling them off.**
Eventually I wanted aftermarket wheels and some new rubber. I spend a stupid amount of time on what sizes, what was available, and what I was willing to spend. For various reasons my best compromise on function, cost, and looks were some 17" x 8.5" +48 TR Motorsport (Tire Rack) MT1's in 5x100 bolt pattern. Sadly these are not made anymore despite the fact that they were an excellent size and value. The finish is more matte that this photo suggests, but I was really pleased with how it went with the SGM paint. I am certain that these were made for Tire Rack in an Enkei foundry. I had a few different sets of rubber on these wheels, I think starting with a few 235/40/17 sizes, then later some 255/40/17 sizes, and ending on 235/45/17 tires.
On the car, not too shabby. It's just a plain WRX nothing special.
Old 07-21-2011, 01:05 PM   #11
2006subaru
Member#: 191637
I honestly can say this is the one of the best WRX build I have seen. Kept it nice and simple and enjoyed the car for what it is.
When I had mine I was so focus on all the things it didnt have that I forgot about all the good things of a WRX. Which is a good DD and good track car on the weekend.
+1 on your car man and I am jealous mine didnt go this way.
2006subaru is offline   Reply With Quote
Old 07-21-2011, 05:52 PM   #12
sc00ter
Member#: 117767
2014 Audi S4
DP Stage 2 (~420whp)
Originally Posted by JarHarms View Post
I've been wanting to do this but I feel like it just makes the cd player stick out like a sore thumb.
sc00ter is offline   Reply With Quote
Old 07-22-2011, 09:18 AM   #13
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Thanks, that is what I am going for. My last project car got a bit out of hand and in the end it got boring. Caged, solid mounted everything, limited traction, and loud as eff sort of makes for less-fun after awhile. Turbocharged B20Vtech was a blast. It is shocking how inexpensive Honda swaps have become today. Trick is in finding a decent chassis to start with.
I hear you there. That was taken care of when I replaced some of the audio stuff just recently.
Later I was given some STi under body panels. But installing these without the rear diffuser seemed inappropriate. I ordered a diffuser along with the oem brackets. Heck you can't see them much but I thought why not?
(need to find a photo of these)
Once the rear diffuser arrived I followed up with its installation. I decided to go with using the OEM brackets that are usually welded in place during assembly. Getting them lined up correctly before drilling holes in the floor pan was tricky though. Stainless pop-rivets, POR-15, seam sealer, and urethane undercoating was used to install them and protect from the elements.
After action:
(missing, have to take a new photo)
So I have all the aero bits shown below minus the JDM transmission piece. Oh and my front under panel is the shorter one we got here in the US.
I always though this was a decent diagram of airflow around the GD body. Although I do not have the STi rear vane and spoiler...or ever plan on installing those fugly bits.
Old 07-22-2011, 09:45 AM   #14
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Shortly later I found a windshield crack or more accurately it was found during a tech inspection. It was originating from the edge under the glass trim and moving downwards then over to the right.
Here is the crack (center vertical one). Ignore the others as this photo was taken after removing the glass.
Huh that seems kind of coincidental.
These are locating aides used to position the windshield at the factory.
The center ones in my case is the cause of this crack due to poor factory installation. There is one on the glass and a mating one on the body frame. These two were making excessive pressure at the edge causing a high stress point. Cracks were only a matter of time.
So if you are replacing a windshield make sure your glass guy removes all of these foolish pieces or you may be returning in a short time for new glass.
Or you might have to come back for new glass when the glass tech tries to cut corners and cracks the bottom edge (of a heated windshield) trying to force the cowl trim in place. Just take off the cowl and replace it once the glass is installed azzhats. I am still pissed off about this.
Oh and I almost forgot that the Defi meter cup got broken off in the process of installing the 2nd windshield. (holy jeezebus that dash is dusty!) I had to come up with something more robust.
The steering column cover was replaced and a new dual dash bezel was installed. The unused side got filled in with a meter blank. All and all it works OK and had acceptable fitment. The surface finish is a bit shiny and I only used the upper screw mounts. The only gripe I have is that Defi has since discontinued the Link meters. That is going to make it difficult to find an extra Link meter to fill that blank spot.
Old 08-18-2011, 09:37 PM   #15
JarHarms
Member#: 138994
06 WRX Ltd
SGM
A bit of time passed before I started changing more parts. I tackled the rear suspension bushings next, starting with the trailing arms. The rearward trailing arm bushings in the rear knuckle were replaced with Group N using BIG SKY's install tools. Just do yourself a favor and get on the list for this install tool. Trust me.
I know it does not look like it is the correct bushing but I assure you it gets shoved in there as designed.
The forward trailing arm bushing was removed with at self-made install tool and replaced with Group N bushings. I considered box welding these arms in to add some strength but ran out of time.
All of the rear lateral link bushings were replaced with Group N bushings. I ended up getting the SPX install tool for the 2 toe-adjust position bushings, tricky buggers. I found that those particular bushings are harder to install without tearing the rubber. I messed up two of them before ordering the SPX tools. Meh
The rear was finished up with some subframe lock bolts or as Kartboy calls then "Botox bolts". These installed fine, work great, and meet my demands for well designed/built parts. However the method of instruction delivery is poor and the TQ specs commonly used on these is way too much.
*I had removed the rear cross member and saw what I expected with these inserts. The excessive TQ spec deforms the piss out of the alloy inserts which makes them semi-permanent parts of the cross member and tricky to get the bolts out.*
These bushing and lock bolt upgrades made a dramatic difference, noticeable on the first test drive. There was a reduction of spongy-ness in the rear end with a increase in rear stability during hard corners. Well worth the effort to install these. I have helped install these for a few people who brought or shipped me their parts to install front trailing arm and lateral link bushings. They comment back on similar positive experiences.
Old 08-19-2011, 11:35 AM   #16
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
How do you like the D-specs compared to the Sti take-offs? My JDM v7 struts clunk like a mofo.
Subian is offline   Reply With Quote
Old 08-19-2011, 12:00 PM   #17
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Honestly I'm not that enthusiastic about them. To be more precise they function as fine as I would expect any JPN variant dampener, acceptable that is. But I detect that clunking noise that they are known for. These were not top of the line but they were not cheap either...hence they should not make a peep. More or less I am pissed off at myself since I long ago said I would not purchase any more Tokico products, I went against that, now they make stupid noises, guess I got my just deserved. In the end I wish I would have kept my STi take off struts and had them re-valved. I already had the STi clunk issue sorted out by re-packing them with a better grease. Eventually the D-specs will be replaced with something else, I just have too much on my plate to do it now.
I got tired of the dirty gray floor mats that Subaru paired up with the black (well I guess you can call it black) carpet. Seriously, light gray over black? You can hardly blame color blindness on that mistake.
So I wanted black floor mats that fit the floor shape and not some universal fit junk. Since I really do not use this car in the winter I was not interested in any rubber floor mats. The only oem floor mats I could find were the STi ones which include an extra retention bracket that bolts to the seat. Cool, except it is embroidered with STI in cherry blossom red (which is just a manly way to say pink). Initial observation makes me think the materials may not hold up that long but I installed them and they look way better. Made in Canada too
I also installed an STi shift trim ring, given to me as a gift. It's kind of shiny for my tastes but I'll see how it goes before I try media blasting the shine out of it . I tossed my hacked 5MT shift boot to make way for a new 6MT shift boot. It all just bolts together and looks like it is meant to be there. The worn out STi knob was also replaced with a not-so-shiny new one. I LIKE! LatheWerks does excellent craftsmanship.
Old 08-19-2011, 01:49 PM   #18
96accord
Member#: 145105
'15 Accord (Daily)
Nice updates! What headunit is that? I know Pioneer.
Old 08-19-2011, 02:24 PM   #19
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Pioneer AVH-P4200DVD, although I just saw on crutchfield's that this model may have been replaced with a 4300 that includes Pandora interface/controls. Dang
Old 08-19-2011, 03:07 PM   #20
96accord
Member#: 145105
'15 Accord (Daily)
Thanks. Always something newer/better coming out as soon as you get the older model lol :/
Old 08-19-2011, 06:19 PM   #21
98intrigue
Member#: 277262
2010 Nissan 370Z
40th Anniversary
Technology has its setbacks, haha
98intrigue is offline   Reply With Quote
Old 08-20-2011, 01:22 AM   #22
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
Weird i've had tokico d-specs for 2 years, and i still don't hear any sort of clunk.
Old 06-19-2012, 11:18 PM   #23
Scoobisteve420
Member#: 323726
03 WRX
Absolutely beautiful subie. Lovin the rims for sure, good eye
Scoobisteve420 is offline   Reply With Quote
Old 07-02-2012, 02:12 PM   #24
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Thank you Sir.
The trans is fine but a broken bolt is holding me up. I just "had" to finish my air pump delete while I was in there and one of the wimpy 6mm bolts twisted off in the RHS cyl head. Then I broke a drill bit off in it due to my own impatience . The Defi EOP meter arrived in great shape but missing the link cable. I will use the one leftover from the boost meter. Also found a few other parts that I have been looking for, they should help out on later projects. So besides missing the beautiful Midwest weather driving, I am still happy. It is crazy hot anyways.
Once the 6MT is finished and tested I plan to switch out the Centric Posi-Quiets to see if the Stoptech Street Performance pads operate better. New front rotors as well. I know others report good results with these pads but I have had constant corrosion imprint problems with them. I have properly bedded, re-bedded, sanded, and re-cut rotors with no improvement. In fact I have never had such a re-occurring shutter with any other brake pads in my life. I have a feeling that the ST and Centric pads are mistakenly talked about interchangeably regardless of the different material properties. If the ST pads work out then the rears will be soon to go as well. I like Bobcats but trying my best to avoid Bobcat pricing. Then the new steering rack goes in, followed up with an alignment.
That might be all I can squeeze in this season.
As long as I had the exhaust manifold down I planned to install the groupN engine mounts and the Killer B parts I had stashed away. Engine mounts were easily done since I had plenty of room. On to tearing that oil pan off next.
Old 07-15-2012, 07:28 PM   #25
JarHarms
Member#: 138994
06 WRX Ltd
SGM
Bummer. Found an unwelcomed guest inside my oil pan. One of the mounting tabs for the inner pan baffle broke off and was floating around in there. At least it was larger than the pickup screen but still not something anyone likes to find.
This pan isn't going on there again and not sure how I feel about replacing with the same exact designed oil pan.
Now I am held up in order to find a suitable replacement pan.
New Act 6 Puck For 2006/2010 Wrx Or 2005/2006 Legacy Push Type aaguirre Drivetrain 18 11-18-2009 09:20 AM
WTT: 2006 BLACK STI Wing for 2006 BLACK WRX wing ILSMKU2 SCIC Private Classifieds 3 08-02-2006 09:27 PM
2006 Mitsubishi Evolution IX vs. 2006 Subaru WRX STi (edmunds.com) NYCshopper News & Rumors 109 05-07-2006 04:54 PM
Socal: 2006 OBP wrx winged trunk, trade for 2006 wingless trunk mattjk Private 'Wanted' Classifieds 5 05-02-2006 02:17 PM
