Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 08-27-2015, 07:54 PM   #1
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Bast's MY99 Prodrive P1 Replica RS
After 2 years of ownership I've finally made the jump from RS25 to Nasioc for a "build" thread. It'll be a bit of catching up from my other journal, I apologize.
I purchased the RS in July 2013 from a Subaru 'specialist' dealer in Oregon. They had completely overhauled the engine. I picked it up at 124,500 miles with a 5-speed manual transmission and new tires. It had some blemishes (the rust spot I somehow missed until I got home), chewed up passenger doorcard, scrapes on the glovebox and a broken driver's side mirror. It came with the OBX axleback, black depo side corners and OEM subwoofer. All in all, I am completely happy with my purchase.
The main plan has been to keep the car N/A and focus on cosmetic and suspension/brake upgrades. There will be no 'lowlife' or flares or widebody. It'll be something of a Prodrive P1 replica with some v6 STi pieces. I definitely want to update and refresh all the bushings and old OE parts. A possible far future plan would be to purchase a wrecked GD STi and do a full USDM swap. I'm in no considerable rush to do that.
Interior
- JDM STI V5/6 front door cards
- JDM STi MT blue pedal set
- JDM WRX gray cluster
- JDM WRX gray HVAC trim
- JDM WRX gray shift trim
- JDM Subaru red hazard button
- OEM black coupe carpet
- OEM all-weather floor mats
- Prodrive P1 cluster
- Prodrive P1 front seats
- Prodrive P1 rear seat
- Prodrive black 5MT shift knob
- Prodrive floor mats
- STi V9 steering wheel
- WRX intermittent wiper stalk
- Shiba dog hairs
Audio & Lighting
- Kenwood 6x9 rear speakers
- OEM subwoofer
- OEM trunk light
- OEM P1 Hella spotlights
- JDM Subaru ion yellow foglights
- White LED cluster lighting
- White LED map/dome lighting
- White LED HVAC lighting
- Retrofit DEPO glass headlights:
= E46-R shrouds
= Morimoto Mini H1 7.0 projectors
= Morimoto XB35 ballasts
= MotoControl Bixenon harness
= 4500k bulbs
Exterior
- JDM Subaru taillights
- JDM Subaru clear corners
- JDM Subaru front aeroguards
- JDM Subaru rear aeroguards
- JDM 22B OE hood vents
- JDM STi V5/6 grille
- JDM STi V5/6 rear bumper
- JDM rear spats
- JDM flat fuel door
- EDM "frosted" clear bumper lights
- Prodrive P1 OEM trunk badge
- Prodrive P1 OEM fender badges
- Prodrive P1 OEM spotlight covers
- Prodrive P1 OEM spoiler
- Prodrive P1 replica front splitter
- Depo clear side markers
- Paint-matched side skirts
Engine & Exhaust
- Engine rebuild at 124,000 miles
- Paranoid Fabrications grounding kit
- Prodrive oval tip axleback
- Stromung midpipe
Chassis & Suspension
- KYB Excel-G struts
- JDM STi V5/6 pink springs
- KYB AGX struts - not installed
- Prodrive springs - not installed
- Group N front and rear tophats
- Group N pitch stop mount
- GT Spec fender braces
- CUSCO lower rear subframe brace
- Whiteline HD rear endlinks
- Whiteline steering rack bushings
- Whiteline outer tie rods
- Kartboy rear subframe locking bolts
- Cobb front shifter bushing
- Cobb rear shifter bushing
- eBay front strut bar
- WRX 17mm rear sway bar
- 2015 STi 13:1 steering rack
- L&E steering column linkage
Brakes & Wheels
- 205/55 Michelin X-Ice Xi3 tires with OEM RS 5 spokes in silver 16x7 +55
- 215/45 Michelin Pilot Super Sports with OZ Prodrive P1s 17x7 +52 - powdercoated 'Gold Metallic' 3/1/2018
- OZ Prodrive center caps (missing one )
- Muteki black lugnuts
- USDM WRX 4-pots repainted Titanium Blue
- USDM WRX 2-pots repainted Titanium Blue
- Centric premium rotors
- Stoptech street performance brake pads
- Stoptech SS brake lines
- Kartboy rear 2-pot adapters
Notes
- Cluster swap #1: Mileage of v6 cluster: 167,948km / Mileage of stock RS cluster: 139,758mi
- Cluster swap #2: Mileage of V6 cluster: 199,XXXkm / Mileage of STi cluster: 191,398km
Parts Wanted
- Prodrive P1 rear doorcards
- Rear glass with wiper and components
Bast is offline   Reply With Quote
Old 08-27-2015, 07:54 PM   #2
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Dealer Photos & First Mods
July - September 2013:
Here's what the dealer replaced prior to my purchase (all repairs done at ~124,000 miles):
  • New OEM Subaru head gaskets
  • New OEM intake manifold gaskets
  • New OEM Subaru cam seals
  • New OEM thermostat
  • New OEM thermostat gasket
  • New OEM oil pump o-ring
  • New valve cover gaskets
  • New spark plug tube seals
  • New washer rocker grommets
  • New drive belts
  • New timing belt (OE Gates brand)
  • New spark plugs (NGK)
  • New oil and filter
  • New anitfreeze
  • New ACL rod bearings
  • New ACL main bearings
  • New piston ring set
  • Transmission flush with Redline
When I took it for a test drive, the driver's side amber corner light flew off. They replaced those with the depo black corners (yuck!). It had fading pin stripes, slight rust, a busted driver's side mirror and awful deflectors on the hood and moonroof. That said, it was a diamond in the rough and I had to have it.
Within the first couple weeks I swapped out the orange bumper lights and black corner lights. Also locally purchased a v6 grille and put that on.
Purchased brand new JDM tails from flatirons and installed. Totally changes the rear end!
RA mudflaps.
There was a great 2 month span with little to no issues. Then come Friday the 13th in September 2013 and I woke up to this:
And the following Sunday.. Noticed the rear tire was flat.
A good $1,600 in damage and luckily insurance took take care of it; including 4 new tires (which I had to fight for).
Old 08-27-2015, 07:54 PM   #3
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Suspension
October 2013:
For awhile I hoarded all my suspension stuff until I had everything I needed. I was given v5 STi springs from a friend, bought KYB Excel-G struts off Amazon, Group N top hats from SubaruGenuineParts and various hardware from the local dealer.
Everything installed:
Replaced the DEPO crystal clear corners with JDM clear corners.
The car was detailed and all the pin-striping was removed (thank god)
And some random photos:
v
Old 08-27-2015, 07:55 PM   #4
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default JDM Smooth Rear Bumper & Spats
November 2013 - January 2014:
I picked up a JDM smooth rear bumper with spats and a couple months later installed it. During this time I also moved from Portland, OR to the Bay Area, CA. The install was thankfully very straightforward. The bumper had already been cut to fit the USDM beam so it was a matter of removing the stock bumper and installing the JDM one.
I tried out red mudflaps for a bit and installed the pink grille badge.
I went to the full extent of 'Basic Subaru Owners Guide' and plasti-dipped my wheels white. The only nice thing about it was that it covered the major rash on all my wheels.
Old 08-27-2015, 07:55 PM   #5
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Black Diamond Pearl Respray
February - March 2014:
California was good to me and I found a replica v6 spoiler for $30.
But, I was also a complete idiot and took a corner too sharp in a parking garage. Luckily during this time I was shopping for a paintjob.
I decided to go with Maaco (yeah, I know, I know..) for a few reasons. One being cost and the second; this car will never be a show car and is 14+ years old. I can't justify saving up $3,000 - $10,000, or more, to take it somewhere more reputable/quality. That said, I did choose the Maaco with the 'best' reviews in the area. I had the complete car, all my parts and some rust repair for $1,500.
We took off all the lights, grille, scoop, vents, moldings (with new ones to put on), window trim, bumpers, sideskirts and whatever else we could in the parking lot. This was in hopes to make sure the parts were painted properly and not just taped off.
On March 13th I picked up the car and reassembled it in the Maaco parking lot. I had forgotten to take photos of how it looked when I got there and the process. I didn't have any help and didn't want to be there until dark so I just installed what I could to get it home.
They had ordered me a new hood and since they didn't have the lights or grille it wasn't aligned correctly and wouldn't latch. One of the employees had told me to 'take side streets home and don't go fast,'. Uhhh, yeah, no. I basically raged my face off on him and they fixed the hood so it would close completely but slightly dented it in the process. **** it, whatever.
It took me a few days to get all the small bits (moldings, foglights, etc) back on the car due to school and traveling.
There were two major spots that they clearly ****ed up but I didn't bother taking it back in.
While the car had been in paint, I purchased a set of STi pedals from Australia.
Old 08-27-2015, 09:21 PM   #6
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default V6 STi Spoiler
April - May 2014:
Installed a few more things (spats and moldings). Yes, one wheel is silver. Don't worry, all the plasti-dip was harmed and removed and never reapplied.
In May we finally installed the v6 wing. Since it's a replica it's not a perfect fit (the base bows a bit away from the trunk) but it stays on and I haven't had any issues with it.
Old 08-27-2015, 09:30 PM   #7
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
June - July 2014:
I decided to ruin the looks and reinstall the red mudflaps. I also installed rear 02/03 WRX seats.
Installed Prodrive shift knob and Cusco rear subframe brace.
And some random photos at the Alameda Naval Base.
Old 08-27-2015, 09:37 PM   #8
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Cluster, Pedals, Locking Bolts, etc
August - December 2014
Sometime in August I installed the pedal set
My birthday rolled around in September and I received/installed a v6 cluster
Mileage of v6 STi cluster: 167,948
I also started acquiring more parts - full set of aeroguards, Cusco ladder bars, 4/2 pots...
Installed Whiteline rear endlinks, Kartboy subframe locking bolts and HD sway bar mounts towards the end of December.
Old 08-27-2015, 10:08 PM   #9
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
CCCCCCCCCCCC Combo Breaker
pho_shizzle is offline   Reply With Quote
Old 08-27-2015, 11:39 PM   #10
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Lolol, you would..
Old 08-27-2015, 11:45 PM   #11
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Aeroguards, Foglights & Brake Prep
January 2015:
I had the aeroguards painted and installed them. I also bought and installed the ion yellow foglights
We disassembled the brakes and started stripping them for paint and rebuild. It was kind of a pain stripping them.
Old 08-28-2015, 02:41 PM   #12
AWDenvy
Member#: 202140
2007 Fozzie
Grey
4pots are going to look goooood. Biggest regret I had with my 98 RS was never upgrading the brakes.
AWDenvy is offline   Reply With Quote
Old 08-28-2015, 07:15 PM   #13
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
The 4/2 pots are one of my favorite upgrades!
Old 08-28-2015, 07:22 PM   #14
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Fog Light Covers & Flat Fuel Door
February - April 2015
I bought some STi decals for the replica fog covers and sampled them on the car. Since I love the foglights so much, I never really installed the covers, haha.
Late March I installed my flat fuel door that had been sitting around for about a year. We also finished up painting the brakes. All ready for install!
The start of April brought the brake install!
The hardest part of the install was getting the rotors off and the brake line bolts off (without stripping them). Other than that, I think it took us about 2 hours for each set, all said and done.
I took it upon myself to clean up the springs, not that it really matters. But it's nice to seem them cleaned, haha.
[img]https://farm8.staticflickr.com/7665/17036624642_f16bc3e5c6_b.jpg[/img
Old 08-28-2015, 07:25 PM   #15
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default 4/2 Pot Caliper Install
April 2015
Old 08-28-2015, 07:37 PM   #16
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Incredible looking RS man.
Old 08-28-2015, 07:41 PM   #17
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default GD Carpet
June 2015
For a couple months I didn't really do anything to the car until I purchased a black 2006 WRX carpet. Man, that thing was gross! Someone must have driven through a pine forest and 10 shedding dogs. So many hairs. I took about an hour or two just cleaning it and there's still hair stuck in the threads.
Once clean, time to uninstall poopy RS carpet.
Seats out
Console out
Carpet out
Carpets side by side
Carpet thrown in
The passenger side was super cramped so I had to cut it to match the old RS carpet
The rear of the driver side fits haphazardly, mostly due to the backing of the carpet
Old 08-28-2015, 07:43 PM   #18
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default GD Carpet
June 2015
The trunk release area had to be cut in order to fit as well. The cut was made behind the release.
I used the cut fabric and just stuck it in front.
I had to cut holes for the seat belt bolts. I didn't really get good photos of that. If you do this, you'll figure it out.
Started to put things back in
The biggest fitment issues (for coupes anyway) is where the GD carpet would meet the B pillar in the sedan/wagon.
The passenger side is much worse for some reason
Driver side, not too bad, but still an eyesore
I wasn't able to get the RS carpet clips stapled onto the GD carpet so it's not as secure as it could be, but the door trim seems to keep it in place until I get a staple gun.
Some other issues.. the dead pedal area sticks out quite a bit
Passenger side area is a bit short
The GD seat belt holes are ugly looking as well.
The GD footwell area isn't the same as the RS, so it's not completely flat. Kinda bulgy and awkward. But your feet go there... so, it's all good.
I also had some issues with the front seat holes. I had to cut the holes a bit bigger so that the bolts wouldn't get stuck. I didn't take any photos of the front seats back in since I was mad about a couple troubling bolts and stripped threads. At some point I'll fix all the gaps, most likely with black carpet cut from somewhere.
Old 08-28-2015, 07:44 PM   #19
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Thanks! It's come a long way since I bought it, haha. I still have quite a ways to go too.
Old 08-28-2015, 07:51 PM   #20
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Limited Trim & Tint Removal
July - August 2015
I bought some GD STi mats and tried my hand at vinyl wrapping. I bought some aluminum brushed vinyl to do my HVAC face panel and it came out OK.. I clearly cannot cut smooth circles haha. But it'll do for now until I get over it. Sadly, I ripped a piece of it when installing the center console back in. That steering wheel is an eyesore and I can't decide between the STi v7 or v4.
I also bought a limited shifter trim with the badge. The empty holes were bugging me, haha. Sent out from Japan on 8/3 and arrived today. I took the badge off the one that came in and put it on the brand new piece already in my car. Pardon the cell phone photos..
I found my window tint to be peeling and did what any child would do and ripped it off.
Old 08-28-2015, 07:57 PM   #21
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default Prodrive P1 Seats
August 2015
Now we're almost up to date.
In July I had won an auction on eBay for a complete set of Prodrive P1 seats and doorcards from the UK. It took a little over a month and a half to arrive by sea and go through customs/travel across the U.S. Picking up the seats was the biggest headache EVER. In total the trip to get them from customs and the warehouse was about 4.5 hours. Mostly because it was a bit of a drive to the port and then the man "helping" us at U.S. Customs was a total prick. Then of course the warehouse had to take their sweet time too.
Anyway.. the company who sold the seats wrapped them beautifully and there didn't appear to be any damage from shipping. Unfortunately I didn't get a whole lot of time today due to other circumstances to install everything. I got as far as the front doorcards and audio panel. I started removing all my tint (yay fishbowl!) and got the rear windows removed before the seats arrived. The rear glass had of course decided to be a ****. I ran out of light before I could really get a good start on it and it's not peeling off like I would like it to.
Old 08-28-2015, 08:01 PM   #22
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
August 2015
I spent way too much time removing my rear tint; lots of scraping away leftover bits of old, purpled tint. But, now I have a fishbowl and I like it.
I spent basically all day in the garage installing everything and the car looks so much newer. One of the rear door cards needed to be fixed (missing some clips) so I used my old card to donate some. There is a slight stain/dirt spot on the rear seat but I didn't have anything to clean it and I barely notice it. Some scratches on all the cards but overall in much better condition that my OE ones.
The rear tint was suuuuuch a bitch.
I accidentally cracked my C pillar when removing it.. Not stoked on that but oh well. Rear cards in:
Rear seat:
Front seats go in:
It is so so nice to have chassis specific seats back in the car. I no longer feel like I'm sitting in a semi and towering over the steering wheel. And the hug. Hugs for daysss from these seats.
Now I need to source some Prodrive P1 17in wheels, P1 fog lights and covers, P1 lip, P1 spoiler... and a better looking steering wheel.
Prodrive all things!
Congrats, now we're all up to date.
Old 09-02-2015, 04:47 AM   #23
dbagmandk
Member#: 356483
2005 STi
Very clean and nice, i like it!
dbagmandk is offline   Reply With Quote
Old 10-08-2015, 07:11 PM   #24
Bast
Member#: 329493
1999 Impreza 2.5RS
Black Diamond Pearl
Default 2015 STi Rack & GT Spec Fender Braces
September - October 2015
Got the '15 STi rack bolted up and the steering lines sorted out. I originally bought the Flat4 Motorsport steering line kit but the provided fittings kept leaking. We ordered some Russell and Earl fittings but still ran into problems with lines not feeling secure at all. And leaks..
Eventually we just gave up and put the stock lines in. But what do you know, they leaked too.. So, ordered brand spankin' new lines and no leaks!
2015 STi rack was prepped to go in with adapters to run the shorter RS lengths.
Old and busted rack came out
Whiteline bits in. Gonna need to do the ball joints separately since we don't have the proper tool and need to update to GC8 LCAs anyway.
I also bought a set of GT Spec fender braces. Ugh, such a nice product.
Got the braces both in. I followed this guide for removing the fenders: http://www.rs25.com/forums/f105/t118...r-removal.html
Very straightforward except for 3 pesky bolts that would not come off. The bolt at the bottom of the fender (underneath the side skirts) was a pain on both sides. Had to blowtorch them to get them off. There was another bolt in the engine bay that is so stripped and ****ed up that we just worked with the fender still on.
The install itself was fine, but the doors are no simple task to keep in the right position. Damn coupe doors are heavy! Now they're not aligned.
The rack and braces made a great improvement; now the biggest thing holding the car back are my tires.
Old 10-09-2015, 03:53 PM   #25
ratedz03
Member#: 374915
2000 Impreza 2.5rs
great RS.
ratedz03 is offline   Reply With Quote
