Welcome to the North American Subaru Impreza Owners Club Wednesday November 21, 2018
Old 07-22-2006, 04:43 PM   #1
karandom
Member#: 99125
Default Helix DP question
I bought a helix catted downpipe used and my hush just came so I will be doing the install in a few days. Of course I have ready every install guide I have come by. One thing that confused me is that on my DP right in the belmouth there is a bolt threaded on both sides that is hallow. It looks like something is suposed to attach to it, but I have seen no mention of it in any of the guides. Any help would be apreciated.
The picture shows what I am trying to describe.
karandom is offline   Reply With Quote
Old 07-22-2006, 04:46 PM   #2
turboscooby13
Member#: 56280
2003 M3
Maybe I'm wrong, but it looks like someone perhaps had an EGT sensor there? I know when I bought my Invidia DP, it had a bung for the O2 sensor closer to the back.
turboscooby13 is offline   Reply With Quote
Old 07-22-2006, 05:12 PM   #3
littledrummerboy
Member#: 94408
17 STI Sport-Tech
17 Impreza Hatch Touring
isn't that bung where a wideband 02 sensor is supposed to go?
littledrummerboy is offline   Reply With Quote
Old 07-22-2006, 05:13 PM   #4
karandom
Member#: 99125
I think it may be an egt sensor. After looking at a pic from gruppe-s it apears there would normally be a bolt there. The question is what size bolt (lenght and diamater) and whats the best place to get one.
Also, for furture reference when I get an EGT gauge, would that be a suitable sensor location?
Old 07-22-2006, 07:07 PM   #5
Crawdads
Member#: 30907
SWP GDB-G
The pipe comes with a plug for that bung in the bellmouth, the bung is for a wideband a/f sensor.
I hope that the picture you posted is not your pipe, because it looks like somebody welded in a different bung to fit another type of sensor.
to answer your question about EGT pyrometer placement, no, the downpipe is not a good place. The most common (and pretty easy to fit-up) place is on the drivers side exhaust manifold. There is a small casting button that is perfect for fitting the egt probe. (you will have to remove, drill and tap the manifold, but this is super easy.)
Crawdads is offline   Reply With Quote
Old 07-23-2006, 12:41 AM   #6
karandom
Member#: 99125
Yes it is.
I hope I can find a bolt that matches the hole or some sort of cap for the fitting. The problem is the half of the bolt going into the pipe has a special very closley spaced threads that home depot doesn't carry. They said try napa, but they were closed by the time I got there.
If I can't think of some kind of solution then I'm in trouble because I wanted to install this on wednesday, which is my next day off.
Here is another close up of the problem area. Now that you mention it, it does look like someone welded something in there since the weld doesn't match the rest of the ones on the pipe. Thanks Saucemaxx.
Old 07-23-2006, 11:45 AM   #7
geeboy
Member#: 96892
2005 STi
Doubt your going to find the right part to cap it at a hardware store. I know Napa is closed on sunday's where I live and they usually have a good selection of automotive nuts/ bolts and problem solving parts. Try Kragen or Auto zone or whatever chain Automotive store you have in Rhode Island, they may have something. I wouldn't worry to much. Just a side note, when you install the DP, for alignment purposes bolt the DP to the turbo first then work your way back or it can turn into an alignment pain in the ass. Good Luck.
geeboy is offline   Reply With Quote
Old 07-24-2006, 08:57 AM   #8
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
that may be some kind of pipe thread.
if so, no 'normal' bolt/cap will work.
look for pipe fittings.
ekw is offline   Reply With Quote
Old 07-24-2006, 10:16 AM   #9
spooln407
Member#: 97054
MY05 WRX
damn...doesn't look too good...
spooln407 is offline   Reply With Quote
helix dp question kool168 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-15-2004 11:38 AM
Helix DP Question Cronos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-17-2004 02:56 AM
Just installed my Helix DP, questions that need answers skiblur Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-20-2003 10:58 AM
Helix DP questions???? camz911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-29-2003 10:18 PM
