Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2025
Old 03-31-2004, 03:48 PM   #1
bailey454
Member#: 36474
Default helix dp and borla hush-back?
i was just curious if the helix downpipe and borla hush back (on an '04 WRX sedan) will mate up without any modification. i did a bit of searching and i'm hearing conflicting reports....
bailey454 is offline   Reply With Quote
Old 03-31-2004, 04:08 PM   #2
Rickyh
Member#: 40453
mine bolted up with no problem. no lleaks.
Rickyh is offline   Reply With Quote
Old 03-31-2004, 06:09 PM   #3
Takashi
Member#: 2536
2012 STi Hatch
as your search indicated, i've heard that it doesn't fit up correctly. the helix dp and borla midpipe dont have the same flange or something. i think one uses a douhnut flange like the stocker, and one has a flat flange.
i'm not positive on this though.
Takashi is offline   Reply With Quote
Old 03-31-2004, 09:25 PM   #4
Rickyh
Member#: 40453
here is the deal. the helix pipe has a flat flange on the end. the borla also has a flat flange on the end. what it also has is a portion of the pipe that the donut gasket fits into that will protrude past the flat flange. it will slide into the helix pipe and you can bolt it up. so basically the cup portion of the borla that holds the donut gasket protrudes past the flat flange and will slide into the helix. i will try to take a few pix friday to show you what i am talking about. (i won't be able to get under my car until then)
Old 04-12-2004, 04:27 PM   #5
BrianH
Bing user
Member#: 44383
got those pics?
BrianH is offline   Reply With Quote
Old 08-08-2004, 05:04 AM   #6
senomar
Member#: 47636
01 rsti v7
blue
thought i'd throw this back up again, and see if there were any pictures of this.... got my helix/borla combo, and they seem like they go together fine... the borla fits into the helix, which has a lip inside that stops the borla from going any further... and they look like they'll bolt together fine as well...??? i know this has been gone through quite a bit... but i'm wodering if maybe they changed the design recently, or something else..?? any comments/pictures would be appreciated...
senomar is offline   Reply With Quote
Old 08-09-2004, 06:24 PM   #7
Silver04DE
Member#: 57106
2004 WRX Sedan(sold)
VF39, Protune
bump for interest as well
Silver04DE is offline   Reply With Quote
Old 08-10-2004, 03:23 AM   #8
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
yes i'd like to see pics.....everyone says they won't connect or i'd have to have a shop weld the correct flange on.
Bishop is offline   Reply With Quote
Old 08-10-2004, 09:16 AM   #9
Rickyh
Member#: 40453
It will bolt up without modifications. the borla has a flat flange with a portion that protrudes outward that would hold the donut gasket if you were going to use the stock downpipe. With any 3 inch aftermarket dp, the part that protrudes outward will slip into the mouth of the downpipe, allowing the flange of the borla to be bolted up normally. the problem (if there will be one) with the helix dp is that on some of them the flange isn't straight. This results in any catback leaking. Trust me on this. I bolted a helix/hush setup on my car without cutting or welding anything. It will work.
Old 08-10-2004, 09:20 AM   #10
mrbigisbudgood
Member#: 54378
2023 WRX
This is what I did.....
downpipe - flat flange gasket with steel ring insert - stock dount gasket - borla
No leaks, no problems.
mrbigisbudgood is offline   Reply With Quote
Old 08-10-2004, 10:21 AM   #11
senomar
Member#: 47636
01 rsti v7
blue
steel ring insert? where'd you get one of those? do you have pictures possibly?
rickyh seems to be the only one who's done this without any modification (which is awesome), is there anyone else? the pieces i have do seem to go together fine.... whether or not they still line up when they get on the car is another story, i guess.
Old 08-10-2004, 11:17 AM   #12
Bishop
Member#: 59993
Ass, grass or cash
pics would be perfect!!
Old 08-10-2004, 11:20 AM   #13
mrbigisbudgood
Member#: 54378
2023 WRX
Like this.
Old 08-10-2004, 11:24 AM   #14
Bishop
Member#: 59993
Ass, grass or cash
can you take a pic at a different angle?
Old 08-10-2004, 12:03 PM   #15
senomar
Member#: 47636
01 rsti v7
blue
...is that the steel ring insert sitting on top, or is that one piece?
WTB: Cobb Catted DP and Borla Hush Eppster Private 'Wanted' Classifieds 0 07-06-2007 06:56 PM
helix dp with borla hush crosta21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-29-2005 08:50 PM
Helix dp and Borla Hush problem Kos08 Mid Atlantic Impreza Club -- MAIC 2 03-21-2005 05:35 PM
FS: Helix DP and Borla Catback - turboback solution ludecrous Private 'For Sale' Classifieds 25 02-20-2005 11:54 AM
helix dp and borla exhaust? gizmodude311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-01-2004 11:25 PM
