Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 05-26-2003, 01:04 AM   #1
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
Default how to upgrade a 93 1.8 fuel pump?
howdy
so i went to change my 1.8 fuel pump to a nice used WRX one ...
the 1.8 pump is huge ... and not even close to the same size as the WRX pump and they are not interchangable not even close
any ideas .. i don't want to go to the junk yard .. but that may be the only way
Old 05-28-2003, 01:11 PM   #2
Imprezd
Member#: 3357
size the only difference?
Imprezd is offline   Reply With Quote
Old 05-28-2003, 04:19 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
no
the diamater and length are both differnt and the pickup sock up won't connect ..
Old 05-30-2003, 10:47 AM   #4
Diz
Member#: 874
2017 Focus RS
05 S2000
I think the best way to do it is fabricate a jumper. The jumper would have the male clip that slides into the pump on one end and a smaller male clip that slides into the recepticle(sp?) on the tank access panel on the other end.
As for where to find these clips, I'm not too sure. I was able to find one pre-made. Good luck.
Diz is offline   Reply With Quote
Old 05-31-2003, 03:33 PM   #5
Aspen
Member#: 145
Banned to
Housework for Summer
go to the Junk yard and find '92+Civic or '90+ Integra and pull out the rear seat. You will find an access cover in the center where the fuel pump is. You will need to cut the connector to use on your new fuel pump and you can also use the tubing and filter bag from it as well. There are other cars that use the same connector but they are harder to access.
You will have to splice in the new connector to your existing wiring and change out the tubing as well as fit the filter bag onto your new pump. As for securing it, I ziptied my fuel pump against the metal bracket.
Aspen is offline   Reply With Quote
Old 05-31-2003, 04:30 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
What year did Subaru switch to the compatible fuel pickup/wiring etc?
-Jon
stimpy is offline   Reply With Quote
Old 06-02-2003, 10:38 AM   #7
Diz
Member#: 874
2017 Focus RS
05 S2000
I think it was 95 or 96.
Old 06-02-2003, 03:43 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Excellent...
-Jon
How does a car idle without a fuel pump? railguy Built Motor Discussion 9 08-05-2007 10:17 PM
JDM ver.7 or 8 Fuel Pump? Smoby Subaru Conversions 1 05-06-2006 06:21 PM
Is the AP safe to run with stock injectors and fuel pump on an STi? Irishman Engine Management & Tuning 5 08-30-2004 02:10 AM
1.8 fuel pump NicEJ25 Normally Aspirated Powertrain 2 04-11-2003 11:46 AM
how to upgrade MY96 ej25 to MY97 & up biggreen96 Normally Aspirated Powertrain 2 06-13-2002 09:43 PM
