Welcome to the North American Subaru Impreza Owners Club Thursday May 24, 2018
Old 05-29-2003, 12:15 PM   #1
NewbyScooby
Member#: 33710
Question Are aftermarket brake systems for a wrx compatible with 95 impreza awd L?
Hi,
I was wondering if a big brake system for a wrx will fit and function properly on a 95 awd L. I just want to make sure that the master cylinders are the same and the brake lines will fit.
NewbyScooby is offline   Reply With Quote
Old 05-29-2003, 03:25 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
the master cylinders ARE differnt
the hard line to flex line fittings are the same but the layout is differnt
this post should be in brakes/suspension
Old 05-29-2003, 07:34 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
One possible problem that legacy777 and I were talking about is that the fluid demands of the WRX brake systems are over twice that of the standard L system. What is more, the master cylinder is 24.0mm without ABS and 25.4mm with ABS versus 26.99mm on the WRX. I have heard of many, many L/Outback Sport owners driving with a successful WRX brake conversion, but numerically, we are probably at or just beyond the limits of the stock fluid capacity.
I'm personally awaiting my rear hubs before I can do my conversion. They seem to be delivered to the wrong state...
-Jon
stimpy is offline   Reply With Quote
Old 05-29-2003, 10:37 PM   #4
Matt
Allergic to turbos
Member#: 181
Thumbs up
You could try upgrading the front calipers/rotors from an RS. They're two pot calipers and should help. Stainless steel brakelines will help too. However I don't believe they will fit under standard 13/14 inch wheels. Legacy 15 inch alloys will work. I've run them as autocross rims off and on last year.
Matt is offline   Reply With Quote
Old 05-30-2003, 08:39 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Keeping in mind that the RS calipers and the WRX calipers are the same. The only difference is that the WRX caliper bolts on to a slightly longer bracket so it can utilize the larger rotors. I believe the brake lines in the front are different from that of a WRX and you must use the RS lines. The rears should be the same.
-Jon
Old 05-30-2003, 04:33 PM   #6
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
I just did a rear brake swap, drum to disk.
I used WRX rear hubs/knuckles. Everything lined up fine, even the e-brake cables (just need to adjust them now). I already have brakes from a Legacy turbo on the front (same as RS). So far I have not noticed any adverse effects from using these brakes with my stock master cylinder.
may the stopping force be with you
Team ARG!
Scoobyslack1 is offline   Reply With Quote
Old 06-02-2003, 09:46 AM   #7
Diz
Member#: 874
2004 STi
2017 Focus RS
I'm running WRX rotors, calipers & lines up front. They fit fine. I need to get off my butt & install the SS lines. Laaaazy.
The rears (formerly drums) have knuckles from a legacy, RS rotors, RS calipers and SS lines.
Nice score on the e-brake cables. I don't have one for the left side. No biggie. It's an auto.
Diz is offline   Reply With Quote
Old 06-02-2003, 10:07 AM   #8
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
apparently the WRX cable are slightly longer...the e-brake works, but I have to pull it all the way up.
So no e-brake turns for me
Team ARG!
Old 06-02-2003, 02:45 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
D'oh! There isn't enough play to remove the slack?
I actually got my rear WRX hubs on Thursday so I'm just waiting on some rear lines and I'll be doing my install.
-Jon
Old 06-02-2003, 02:52 PM   #10
Scoobyslack1
Member#: 2780
junk yards rule!
Question not sure....
I have to play with it some more, but I just wanted to at least get it to work for now.
Team ARG!
95 impreza awd with aftermarket downpipe azn0boi04 Subaru Conversions 1 03-08-2008 10:59 PM
95 impreza awd with aftermarket downpipe azn0boi04 Transmission (AT/MT) & Driveline 1 03-08-2008 10:47 PM
Swap WRX calipers with 95 Impreza without changing rotors? Impretzle Brakes, Steering & Suspension 3 03-22-2005 07:36 PM
WTB: Aftermarket Brake Pads for 03 WRX 15secWRX Private 'Wanted' Classifieds 0 11-05-2004 04:15 PM
Am I missing anything for a WRX drivetrain into 95 impreza wagon conversion? ruskiyab Subaru Conversions 3 03-17-2004 04:56 PM
