02-03-2008, 11:22 PM | #1 |
Member Sales Rating: (23)
Member#: 118266
Vehicle:2007 Lexus IS250 RWD 6MT |
Tokico D-Spec
Well I thought I would make myself useful and give a review of my experience with the Tokico D-Spec Struts on my 06' impreza 2.5i. I currently have them paired with Tanabe GF210 springs(04' version).
Included in the box is the instruction manual, 4 d-spec struts, 4 adjuster caps and 1 adjuster tool. Installation is straight forward and just like any other strut install for the Impreza. One thing to note if you have a 2004+ Impreza you will need to purchase a spacer for the rear struts (Turn in Concepts sells them) because Tokico only manufactured the struts for the 02-03' Impreza and as most of us know Subaru changed the rear top hat design in 2004. Personally its not a big deal and the spacer is not expensive. On each strut top you will notice a screw on cap that comes off so you can use the adjuster tool to stiffen or soften the dampening. In the instruction manual I believe it states to keep it at 4 full turns from full stiff and work from their so thats where I started. Now to the important stuff. First driving impressions.....wow, huge improvement over the stock suspension. Of course I have a 2.5i so anything is gonna be an improvement over stock. Car feels a lot more stable, solid and planted to the ground. I took the car for a few miles around town and then parked and took out my handy adjuster tool and began to turn the dial and stiffen her up a bit. This is where I think these things rock. Unlike the KYB AGX Struts which only have 4/front and 12/rear settings for dampening the Tokico's are more or less infinite. There is no selected setting, you adjust them as much as you want so you can make very small adjustments. I think i'm set at 3.75/f and 4.00/r from full stiff and I like it. I have put about 26,000 miles on them and they seem just as good as the day I first put them on. I have 1 minor gripe which really is knit-picking but I wish they sold the struts with the rear extended adjusters that way you wouldn't have to take your backseat out every time you want to make an adjustment. I do not auto-cross so i'm not changing the dampening often but if you do and need to pull out the backseats it can become a pain in the ass. But this is minor and honestly its nothing. Overall I give them a 9.5 out of 10 only because they didn't make an individual kit for 2004+ Imprezas. This summer i'm gonna be installing Group N top hats which will only make these things better. Get the Group N top hats there worth it. I got them in my closet and they are made of harder rubber so they will help with handling and road feedback. If you want a new struts to work with the aftermarket springs out there get the Tokico D-specs you will not be disappointed. I'm sure i'm leaving something out but its late and if I think of anything I will edit it in later.
02-05-2008, 03:39 PM | #4 |
Member Sales Rating: (10)
Member#: 157532
Vehicle:2002 MY03 EJ207 E85 Dom 1.5XTR Twinscroll! |
http://www.mazdatrix.com/8shocks.htm
bottom of the page you can buy the extenders for the rear adjustment. |
02-07-2008, 02:38 PM | #5 |
Member Sales Rating: (17)
Member#: 90396
NWIC
Vehicle:2005 Legacy 2.5i Brilliant Silver Metallic |
Damn... my stock STi Struts give me a clunk in the rear... I'd like to buy a strut that won't clunk...
02-09-2008, 01:54 PM | #9 |
Member Sales Rating: (9)
Member#: 83765
Vehicle:2018 WRX PR WR Blue Pearl |
Nope, you won't. They only made them to fit the 02/03 WRX, but the 2004 STi parts all fit 04-07 WRX's. So, you're in the same camp as the guys who need spacers, but it should fit. If you were an 05+ STi, it wouldn't work at all.
02-13-2008, 07:02 PM | #11 |
Member Sales Rating: (25)
Member#: 87629
SCIC
I have this exact setup on my 04 sti and love it. I bought the struts used and they did not come with the adjuster tool...can I just use a pair of plyers or something? the guy I bought them from told me they were already all adjusted to match the gf210s, but now I want to play around with the settings..? tia
ben |
02-13-2008, 10:06 PM | #12 | |
Member#: 118266
02-19-2008, 09:44 AM | #13 |
Member Sales Rating: (3)
Member#: 90085
Vehicle:2009 |
How do these feel if you have them set at full soft? Smoother than stock or just way too much bounce as if your riding in a caddy?
I want to be able to have a car that rides super smooth for daily driving and also be able to firm things up if i'm in the mood for spirited driving. |
04-05-2008, 07:59 PM | #14 |
Member Sales Rating: (4)
Member#: 35104
RMIC
Vehicle:02 WRX TD0518G 7cm |
You can buy extenders for the rear from Turn In Concepts. I got 2 of them for $30 and love the ability to adjust them whenever I'd like!
04-12-2008, 11:44 PM | #15 |
Member Sales Rating: (32)
Member#: 88467
NESIC
Vehicle:2005 WRX All black everything. |
tubbytreats - when the adjusters are installed, where exactly are they placed? Are they something that a passenger could just mess around with in your backseat or are they kind of tucked away out of reach?
04-13-2008, 08:00 AM | #17 |
Member#: 35104
RMIC
1) Adjusters "poke" up through the seam that separates the foam seat from the metal divider between trunk and cabin area. Yes, passengers (or small kids or crafty pet monkeys) could play with the adjustments back there, but it is a cinch to fix back if it happened.
2) No clunks yet with the D-Specs on my 2002 WRX. I think alot of the clunking has to do with proper torque on the top 19mm bolt on the tophat/strut...as well as using the Scooby921 spacers to snug up the rear tophats. |
04-13-2008, 12:11 PM | #18 |
Member#: 121263
NWIC
Vehicle:02 WRX PSM |
Clarifaction
So the clunk happens to newer model wrx only or all? I have a bugeye and am looking at a set. Sorry just getting mixed messages. Oh and are the d-spec the same as hp?
04-13-2008, 01:10 PM | #19 |
Member Sales Rating: (7)
Member#: 108557
NWIC
Vehicle:2003 PSM WRXWgn STG2 05 OBM LEGACY SDN |
(Partial CrossPost from the Suspension Forum)
2003 WRX wagon 61k 4 turns front/3.5 turns rear for DD Tokico springs from DSK-513 kit 205f/170r Rideheight = 14 1/8" front - 13 5/8" rear Stock 03 WRX hats All stock for now except for dbl camber bolts in front/single camber bolt rear 3/8" PF rear strut shims 18x8x45mm w/225/40/18 Bridgestone S-03 Pole Positions -2.2 deg camber f/0 cross camber/1/32" toe in f/3.9 deg caster/0 cross caster -1.7 deg camber r/0 cross camber/0 toe The rear drop on the wagon w/ the Tokico springs is a little more than I was figuring on. Even with the rear set pretty firm if I hit a good sized undulating bump in the road @ speed I will get a little rub in the rear even with a major roll on the rear fenders. Part of this is due to the offset of the wheels as well as the wide section width of the tires. Wife does not complain about the ride on these settings except for the occasional rubbing. I have a 3/8" set of Paranoid Fabrication spacers that corrected the rear ride height. I will soon be adding a 20mm sedan rear sway poly bushings and Kartboy links to try and decrease body roll. Handling is vastly improved over stock. Suspension feels much tighter, and I have none of the reported clunking some had reported with D-Specs. Absorbs bumps well without being bouncy, and on these settings is not breaking teeth or hurting kidneys. I'm looking forward to my alignment on Wednesday so I can see what it feels like with the camber maxed in front and zero toe. I would recommend this upgrade to anyone wanting better handling, a more controlled ride, and the ability to adjust settings as driver skills improve. I added the alignment specs, and between the alignment and the shims there is no longer a rubbing issue. For the first time in the 3 years I've had the car it now longer tramlines in the Semi wheel tracks on the concrete freeway and I no longer feel like I am wrestling for control of the car. After the alignment the D-Specs really came to life. I drive the same on-ramp to work every day and I can hit it a good 10-15 miles an hour on the exit/merging speed than I could previously. So far I've got about 1k on them and tomorrow I'm taking a 300mile trip on the mountain passes and as long as there is no snow FUN,FUN,FUN! Last edited by QuikWgn; 04-13-2008 at 02:40 PM. |
06-13-2008, 01:28 PM | #21 |
Member Sales Rating: (1)
Member#: 153781
Vehicle:2007 WRX (Sold) 2000 4Runner |
I have no clunking in my 07...I've had them on for about 10k miles now and I love them.
tubbytreats - thanks for that link...That was my biggest complaint about the struts was how much of a PIA it was to adjust the rears. |
06-13-2008, 01:38 PM | #22 |
Member#: 87629
SCIC
I just want to add, no more clunking from my set of d-specs. the clunk is impossible to replicate now? weird, because the setup is exactly the same. great bang for the buck with these struts.
06-13-2008, 02:58 PM | #24 |
Member Sales Rating: (22)
Member#: 131996
SCIC
Vehicle:2006 CGM WRX Wagon Yimi Tuned 296AWP/322TQ |
wagon guys...as for adjusting...do you remove the metal caps that go over the strut tops or do drill a hole in it? i know these will reduce camber, but will these be ok as DD and spirited driving without extra camber bolts?
imma get these soon! real soon! |
06-13-2008, 03:27 PM | #25 |
Member#: 153781
I tried drilling the holes on my sedan but it just looked sloppy so I left them off. Now on the front i did make a hole in the little rubber cap so that dirt and grime didn't get in there.
Gauging interest: Tokico D-spec + new Swift R-spec springs | Turn in Concepts | Vendor 'Group Buy' Classifieds | 45 | 03-09-2008 10:55 PM |
New Tokico D-spec strut kit | masterrch | Brakes, Steering & Suspension | 30 | 02-16-2005 01:36 AM |
Just installed: Tokico D-specs and Progress Springs | anthonyrb98 | Brakes, Steering & Suspension | 24 | 02-11-2005 06:06 PM |
Tokico D-Specs? | BAC5.2 | Brakes, Steering & Suspension | 2 | 11-02-2004 06:28 PM |
Tokico d-spec struts | pyropretz | Brakes, Steering & Suspension | 12 | 09-22-2004 03:32 PM |
