#1 |
Member#: 3219
Vehicle:2004 Impreza WRX STi WR Blue Pearl |
#2 |
Member#: 47103
Vehicle:2000 2.0rs,04 usdm blue ridge pearl-sold |
![]() What year?
#3 |
Member#: 3219
![]() Lookin for 02 or 03. I finally got my harness and I completly unwrapped the front harness and the bulkhead harness. I took out one side of the SMJ the side where it connects to the actual engine harness. But now Im kinda stuck and dont know where to go from here.
I should look directly for engine wires correct? |
#4 |
Member#: 3219
![]() here is a pic of what I took out. This was pretty easy to take out actually none of the wires were tangled up it just came out like this.
#5 | |
Member#: 47103
![]() Quote:
#6 | |
Member#: 47103
![]() Quote:
#7 |
Member#: 3219
![]() Wow thanks for the motavation.
I have some more questions on wether or not I should keep these wires on the RS wiring harness or use the WRX wiring harness. Should I keep the VSS wire from the RS harness or can I just cut it out use it on the WRX harness. Ignition switch--I asume to keep the RS wire Thanks Andy |
#8 |
Member#: 47103
![]() Well the same goes for your RS harness. Get out your RS ecu i/o listing and lable every wire coming out of your RS ecu. Most of the wires that come out of your RS ECU will get spliced right there with that wrx harness your working on. EX.... fuel tank level sensor wire,your RS harness has one and your wrx harness has one also, cut and splice them together. I think this wire is even the same color/stripe in both harnesses! Alot of wires you will simply cut and through out of your RS harness they are the wires that go to your old RS engine ( the two big connectors one brown and one white on the right rear of your old RS engine) Be careful here though,there are two wires here that you want to keep and they don't go to your old RS ecu at all,they are your oil press and collant temp wires. If you don't splice these in you won't get any readings on your dash.
#9 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() i-speed has the 02 WRX wiring diagrams on there web site
#10 |
Member#: 3219
![]() Thanks a lot. Do you think it would be a good idea to label those wires on the RS harness the ones inside the engine bay? The 2 main connectors I mean. Are their any other wires by the main RS harness I should be aware off?
Also the coolant temp line I can tap at the WRX ECU side but the oil pressure I have to tap at the instrument cluster since their are no connections at the ecu correct? Thanks Last edited by AndyM; 03-14-2004 at 11:18 PM. |
#11 | |
Member#: 47103
![]() Quote:
#12 | |
Member#: 47103
![]() Quote:
#13 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
![]() Try to minimize cutting off as many of the factory plugs as possible. Definately use the Brown and Black connectors that go to the left side of the engine. It will make it alot easier in the long run. If you need to shorten up the harness do it at the SMJ as that plug is not really needed. As far as the coolant and oil temp wires that come off of the SMJ they just need to be spliced into the appropriate wires on the RS harness. These are for the gauge and the idiot light on the dash.
Do youself a favor and get both of the diagrams before you go any further. It will help you a lot and you won't be shooting in the dark. You can download both of these from Subaru for a fee or just go to your local dealer and buy the book itself. I recommend the download so you can print it out oversized so you don't go blind as you are attempting to flip through the 11 pages of the WRX manual and the mouse print of the RS manual. Z |
#14 |
Member#: 26658
South East
Vehicle:1 Love Grassroots NASA Rally Sport FTW! |
![]() techinfo.subaru.com
Download all the wiring diagrams you want for $20 Anders |
#15 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() yup as anders said .. and follows the polcies of the board ..
#16 |
Member#: 3219
![]() Thanks a lot guys seriously this is a huge help for me to advance my process in the swap. I want to get as much done to the WRX harness as I can before I actual start to tear down the RS related stuff. This is my only car and have to use my time wisely
#17 | |
Member#: 26658
South East
![]() Quote:
Anders |
#18 |
Member#: 3362
![]() Make sure that your engine is complete beforehand then in addition to all the wiring. Make sure every little nut and bolt is there and that it's completely assembled. I was in the same situation and I my car was not running for a period of 25 hours. Figure out what wires you are going to need to splice what to on the two harnesses and make up a sheet on a note pad and check them off as you do them it goes alot faster that way and it's alot less confusing.
Z |
#19 |
Member#: 3219
![]() Yes I hear you guys out. I do have a time schedule down. I wont actually start the swap process until the end of May (thats when school ends and I have 3 weeks to work with and my work is only 5 min. walking distance). My motor is near complete besides some sensors that I need which are MAF, Rear 02 sensor, and boost selenoid, thats about it. I have taken all of the advice and now Im in the process of tracing the wires that start at the ECU connectors and cutting them. Yes I do know that I may need to keep some connectors I double check with my wiring diagram before I make the cut. So far its working out pretty good, but man is it time consuming.
#20 |
Member#: 3219
![]() Hey guess made a lot of progress last night. Im almost finished tracing all the wires from the ECU connectors. Most of the wires left are going to the SMJ. Is it ok to cut these that are going to the SMJ? I dont think I have a choice because their all tangled up around other wires so I cant pull it out easy like the one I did with the other side of the SMJ.
#21 | |
Member#: 47103
![]() Quote:
#22 |
Member#: 3362
![]() You may want to wait on doing that until the car is up and running so you don't end up with an extra 3 feet of wire in the passenger compartment. I still have yet to remove my SMJ from my car. It's just neatly placed up along the firewall behind the strut tower.
Z |
#23 | |
Member#: 47103
![]() Quote:
#24 |
Member#: 3219
![]() Hey Im still around, just got back from Spring break. Wiring is going smooth. I think I have all the necessary wires seperated from the rest of the harness. Im going to start this weekend to label all the wires in my RS.
here are some pics of my progress |
#25 |
Member#: 8042
Vehicle:MY00 WRS - '04 WRX 2002 Dragon slayer :) |
![]() Hey guys. I am the guy that bought all of the above from Andy. I do have the engine installed completely. Now all I need is to splice ECU wires from the RS to the WRX eh?
~Anthony. |
Can someone send me a font? | Sharkbait | Off-Topic | 4 | 05-07-2006 12:53 AM |
can someone send me some files? (ST) | darksands | Engine Management & Tuning | 0 | 06-13-2005 04:36 AM |
Can someone send me their E-Manage MAP... | Jaredm83 | Engine Management & Tuning | 1 | 01-11-2005 06:53 PM |
Can anyone send me a 1998 wiring diagram? | Jerry Hong | Subaru Conversions | 3 | 04-30-2003 12:13 PM |
Can Someone Send Me a Copy of Rear Brake Pad? | Jason | General Forum Archive | 0 | 08-04-2000 08:52 AM |
